Old 06-11-2012, 03:37 PM   #1
G4mb17
G4mb17's Avatar
17x7.0 vs 7.5
Looking for wheels, most of the ones I like at 7.5" (MR125), given I don't want to switch out the tires (yet), should I care? Will I notice this difference visually or dynamicly?
and when I do put new tires on, should I get 225s?
Riki
G4mb17 is offline   Reply With Quote
Old 06-11-2012, 04:22 PM   #2
Sasquachulator
Pavement Grey
215's work on 7.5
Thats what i have on my car right now.
PF01 17x7.5 +38 215/45/17
the 5x100 bolt pattern isnt available with the 17x7 which is why i have the 17x17.5
Old 06-11-2012, 04:38 PM   #3
G4mb17
G4mb17's Avatar
Originally Posted by Sasquachulator View Post
215's work on 7.5
And do you notice any difference visually or dynamicly? I'm pretty sure I'm going to do this, but just want to be sure.
And did you move over the TPMS from the OEM wheels?
Old 06-11-2012, 04:43 PM   #4
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Why would you want to mount those junks back on anyway?
chulooz is offline   Reply With Quote
Old 06-11-2012, 05:02 PM   #5
G4mb17
G4mb17's Avatar
Figure they put them on there for a reason, and did lots of testing with them - so the least I can do is try them out for a while, to get an understanding of how it handles with their setup before I go changing to something more sticky.
Old 06-11-2012, 06:21 PM   #6
vividracing
vividracing's Avatar
Go with the wider wheel. The extra .5" will add grip, but not enough to make the car handle worse.
vividracing is offline   Reply With Quote
The Following User Says Thank You to vividracing For This Useful Post:
G4mb17 (06-11-2012)
Old 06-11-2012, 06:26 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You'll be fine with the 7.5s as long as they aren't considerably heavier than the stock wheels. If they're lighter, even better. But a 215 can fit on a 7.5" rim no problem. You'll just notice a bit more stretch in the sidewall.
Old 06-11-2012, 06:33 PM   #8
G4mb17
G4mb17's Avatar
MR125 are 16.4lb, I was making sure I didn't go heavier, wasn't planning on going that much lighter, but just happen to like the look of them.
And when I do get new tires, would you say go to 225 or is this a non-issue?
Old 06-11-2012, 06:34 PM   #9
G4mb17
G4mb17's Avatar
Thanks for the simple reply - this is exactlly what I was hoping to near, touch more grip - but not stuffing up all the work Subaru/Toyota had gone to.
Old 06-11-2012, 06:38 PM   #10
Draco-REX
Corner Junkie
Draco-REX's Avatar
225 would be bump in grip due to the larger width, but you'll also be increasing the diameter. If you want to preserve as much of the acceleration as possible, stick with 215s.
Check out this thread: http://www.ft86club.com/forums/showthread.php?t=8270
Even if you stick with 215s, if you move to a true summer Max or Extreme Performance tire, you'll gain width as well as grip without increasing diameter.
Old 06-14-2012, 12:40 AM   #11
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
would it be 225/45/17 -- is that the next step up from stock ?
at what point do you change to 40's ?
can someone explain the offset ?
what are the stock offset ?
thanks -- id love to change it soon also but im a bit lost about all the options.
i would just want to do 1 or maybe 2 bumps up from stock -- what ever that is --- ??
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 06-14-2012, 01:32 AM   #12
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You don't NEED to change from stock size tire (215/45-17) to upgrade until you go wider than 8"... most 215/45-17 tires are designed to fit 7"-8" wide wheels. More important than changing to a larger/wider size [which also INCREASES weight, negating some of the lightweight wheel savings!] is changing to a better performance class of tire. If you want a serious upgrade from the mediocre and overpriced stock tires, step up to 215/45-17 Hankook RS-3's or Kumho XS's [while spending ~1/2 the price of the Michelins!]
Whatever tire size you go with, the goal is to keep the tire diameter as close to the original [which is 24.6" for the FR-S/BRZ] as possible, slightly smaller is better as is finding the lightest tire you can. If you don't choose carefully you could easily increase weight 5lbs a corner just from the tires.
There's a nice sticky thread for wheel information if you haven't seen it:
http://www.ft86club.com/forums/showthread.php?t=3062
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
Fly Guy (06-14-2012), michaelosx (07-10-2013)
Wheel Directory: Velox VX-6R 17x7.0 +42 jdrxb9 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-13-2013 11:35 AM
17x7 RPF1s are coming!! NYC BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 02-25-2013 08:06 PM
Buying OZ Superleggera 17x7 - Do I need hub rings? NYC BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-10-2012 03:56 PM
Volk Racing GT-C 17x7 and Gram Lights 57 Optomise 17x7 xravexboix Wheels and Tires 0 05-24-2012 08:04 PM
