Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
Ground Control Camber Plates
FOR SALE: $300 including shipping
I purchased these Ground Control camber plates in Oct 2015 from a good friend who originally bought them in Dec 2014. I actually bought them before I purchased my BRZ recently. I won't be putting coilovers on the car anytime soon so I need a different setup. These won't work with stock shocks unless you have a coilover conversion kit, which Ground Control also sells. If you look closely at the pictures, you'll notice they have a very handy modification with a thru bolt / set screw setup that keeps the bearing from suddenly moving when loosened and doing an alignment. This allows you to fine tune the camber setting easily. ![]() ![]()
2015 Subaru BRZ
2008 NC Miata with 2.5 swap Building 1963 289 Cobra Le Mans Replica Cobra Replica Build Pics Chin Chief Instructor www.ChinTrackDays.com |
#2 |
2015 Subaru BRZ
#3 |
Drives: 2014 FRS
Will this work with a KW V3 coilover? And does this let you adjust caster too?
#4 | |
You can adjust camber and caster. See the picture below and check your spring size.
2015 Subaru BRZ
#5 |
In the slipstream
You'd need the 60 mm perch, which you could buy from GC. They adjust caster and camber.
#6 |
taicho
Drives: The rEd Fr-S
Are these compatible with st's
#7 |
Cool Stuff
Drives: Cool Car
PM'D
#8 |
I don't know. Best bet is to contact the vendor of your shocks to confirm. Reference the spring perch measurement in the picture I posted and note that 2.25" and 60mm spring perches can also be acquired from Ground Control.
2015 Subaru BRZ
#9 |
***SOLD***
2015 Subaru BRZ
| Ground control Camber plates | -Phil | Brakes, Suspension, Chassis | 13 | 01-14-2016 07:08 AM |
| FS: RCE Tarmac 2 Clubsport coilovers, Ground Control Camber Plates/rear mounts | gatorac | Brakes, Suspension, Chassis | 5 | 08-25-2015 01:31 PM |
| Ground Control Camber Plates and Eibach R2 | ReThink | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 04-20-2014 09:54 PM |
| Testing Waters: FS KWV3s with Ground control camber plates and robispec rear mounts | YDNA | Brakes, Suspension, Chassis | 0 | 01-25-2014 02:34 AM |
| Vorshlagg plates (vs) ground control thoughts and question | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-05-2013 02:23 AM |
