#267 | |
Drives: GT86 Cosworth
You simply cannot have your cake and eat it. What ohlins have done is make a kit that has good performance on the road and track and thats a compromise right there between silly firm springs and nice soft complaint ride with lots of damper travel. If you already have loads of suspention bushes, gearbox and engine mounts and a very loud exhaust then you might notice it less than us, but its no velvety smooth ride. You'll love them on the track though. They also feel amazing over pot hols when set to -15 clicks. Sent from my GT-I9300 using Tapatalk |
| The Following 2 Users Say Thank You to ajc209 For This Useful Post: | BigFatFlip (01-14-2016), DocWalt (01-14-2016) |
#268 |
Drives: 2014 GT86
BTW, can someone get official response from Ohlin if dampening is same between MP20 & MI20 kits? I wonder if it isn't simpler to get 'real kit' by adding cascams & changing coils for 'wrong kit'. But seeing spring rates to differ so much between the kits, i'd love to first hear official word if dampening is really-really same between them, to not get as result underdamped coilovers after adding higher spring rate coils.
#269 |
Drives: '13 FRS - STX
fwiw going to camber plates on my stock suspension resulted in no noticeable decrease in ride quality, running them on my Bilsteins it cancels the little road noise better than stock and it's only the big bumps that are worse (stiffer springs and off the shelf bilstein damping I'd accuse, the byproduct of monotube).
The OE top hats are quite stiff, either Ohlins damping is letting some people down or their top hats are real cheap. |
#270 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Regarding all the harshness being mentioned, I've had mine (with top hats) for about a year now and have not had any problems with it. I would say I drive on relatively bumpy roads (mostly canyon, very little track), sure, it rides a bit stiffer than stock due to the springs, but nothing like others are mentioning. I would agree though that it can use more travel, I've hit the bump stops more often that I'd like and its not a very good feeling. |
#271 | |
The ohlins work very very well and alot of people don't notice what we are talking about. Sent from my GT-I9300 using Tapatalk |
#272 | |
My MI20s are too soft (underdamped - to much bounce) at -20 and too firm (overly firm - wheel cant move fast enough sp you lose grip) at 0 clicks. Definetly plenty of room for increasing or decreasing rates but not 33%. Sent from my GT-I9300 using Tapatalk |
#273 | ||
Drives: '22 BRZ
Also, I've not spent much time messing with damper settings and I'm on snow tires, so there's definitely plenty to be gained with real tires and time tweaking things. I'm more than happy with what I've settled on. Everyone that's ridden in my car has commented on how good it feels for being so much stiffer than stock ![]() Quote:
![]() I've got no new rattles now |
| The Following 2 Users Say Thank You to DocWalt For This Useful Post: | stoked_on_spool (01-17-2016), strat61caster (01-14-2016) |
#274 |
FWIW, and I'm sure I've posted this before, but we liked our Ohlins on our car. We ran them with the off the shelf springs and then with firmer 450 lbs/in springs. Fairly comfortable most of the time and excellent all-around handling. There are some things we would have changed though.
It was difficult to lower the car much, especially with the firmer springs. Travel was overall a little bit lacking. We would have preferred that they came without camber plates which has been something we've always thought with Ohlins standard plates. Running with stock top mounts would have been nice or subbing in a higher quality camber plate with caster adjustment. Overall, very good coilovers that with a few changes would be great coilovers. Softer springs and valving is not a change we would have made and I'm surprised that's the direction they went. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | solidONE (01-15-2016) |
#275 |
Please don't let my negative comments make you think im not impressed with these. Far from it, but some of the reviews for these make them sound like they are some kind of super suspention and I wanted to be honest about how I feel. I know a couple people that were unhappy with ohlins for various reasons. One person was unhappy with the handling balance compared to stock and the other didn't think they had enough bump travel for the roads he likes to drive.
As the new mp20 kit is cheaper, whats stopping people getting them valved for the 60N springs with the money left over and using stock top mounts. Also I should add I have plenty of rattles on the stock suspention too so it not like I had none and all of a sudden I have tons. They've just been made worse and the glove box properly rattles now. It's on my list of things to fix. As far what other coilovers have I tried. Well ive been in and driven a car with hks hypermax coilovers and I prefered stock to be honest. I've been in a car on rce yellows and a car with tein streetflex (I think). None of them were as comfy as the ohlins and low speed damping was what they really lacked on road undulations. Sent from my GT-I9300 using Tapatalk |
| The Following 2 Users Say Thank You to ajc209 For This Useful Post: | Racecomp Engineering (01-15-2016), stoked_on_spool (01-17-2016) |
#276 | |
And it's worth mentioning that this may very well be the dark side of adjustable dampers, there's more 'wrong' settings than there are 'right' ones.
#277 |
Not much you can do wrong with a single adjustable.
#278 |
Drives: 86
Anyone here experiencing some clunking noises on the stock MI20 Ohlins Top Hats?
I have a slight "clunk" noise at low speeds and was wondering if its the bearing failure on the top hats. If so, is there anyone with the stock spherical specs so i can buy a replacement. Ohlins SG is charging me an arm and a leg for it. Cheers! |
#279 | |
Drives: FR-S Whiteout
If you have some calipers it shouldnt be too hard to measure the OD and thickness with the top hat off. ID should be slightly larger than the portion of the shaft that goes through it. Just curious. How's the auto aftermarket in SG? Seems like modified cars are few and far in between when I last visited.
Intent > Content
cowardice is the mother of cruelty. |
#280 |
Drives: 2016 FR-S
Mine have loosened a couple times; just tighten the top bolt
| ohlins road and track shock absorbers | CyberFormula | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 11-11-2014 05:00 AM |
| >> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! | Circuit Motorsports | Brakes, Suspension, Chassis | 90 | 08-16-2013 12:39 PM |
| Ohlins Road & Track Coilovers - IN STOCK!!! | RallySport Direct | Brakes, Suspension, Chassis | 7 | 05-28-2013 04:11 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| Ohlins Road & Track Subaru BRZ and Scion FR-S | HP Autowerks | Brakes, Suspension, Chassis | 0 | 04-24-2013 03:27 PM |
