Old 01-29-2016, 10:05 PM   #71
Kostamojen
So did we find someone with the correct upper spring perches to do this yet? I'm about ready to try it.
The Following User Says Thank You to Kostamojen For This Useful Post:
JoeHK (01-30-2016)
Old 01-30-2016, 02:58 AM   #72
JoeHK
JoeHK's Avatar
Drives: Raven Toyota GT86
Also still waiting, since it's winter time now i'm not in ahurry. We'll see what Racecomp has to offer soon
Sent from my Potato using Tomato
Toyota Corolla E12 Hatchback (2005) - GONE
Toyobaru GT86 ハチロク - CURRENT
JoeHK is offline   Reply With Quote
Old 01-30-2016, 03:52 AM   #73
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Well you'd probably want camber plates in the front if you didn't want to deal with making an adapter for OE top hats anyway so that should be relatively straightforward if you're willing to spend for the Raceseng and a minor inconvenience to figure out if other brands will mate up (vorshlag, beatrush, whatever)
The rears again you've got Raceseng that should accept a smaller diameter spring quite easily although it won't be a perfect fit you'll want some level of compression on the spring to make sure it doesn't shift when unloaded into a bad position or budget for tender/helper springs (whichever are supposed to completely collapse), upside is you'll be 100% that the hardware all mates up. (Nut on the top of the shock, shock shaft to bearing/bushing, bottom of the top hat to the top of the damper shaft)
I've just realized that Beatrush makes rear top hats specifically for 60mm and 65mm ID springs but I have no idea how well the top nut will mate and center the shock in the pillowball bearing/bushing with the B14, looks like they're made for KW's. Worth noting this site lists that it fits an 86 as well as various WRX's (makes sense given the heritage) so you may be able to find more robust catalog investigating parts for those cars or a better solution on NASIOC.
https://www.rallysportdirect.com/par...lowball-mounts
http://www.raceseng.com/shock-top-re...ubaru-brz-2013
Personally I've got Raceseng CASCAMs up front so the spring perch can be swapped and I'll be trying an adapter ring for the rear OE top hats and as I'm not going low they should be adequate.
Edit: Could also get in touch with Robispec, he did a set of rear tophats for KW V3's and may be able to undercut raceseng or rallysport with a simpler design he's already worked out but since it's a custom job I doubt it'll be that much cheaper.
https://www.facebook.com/pages/Robispec/180542078631882
http://www.ft86club.com/forums/showthread.php?t=37158
And Mooresport has something as well, but again not clear on all the specs so you'd have to call and they're the same price range as Raceseng and Beatrush.
http://www.mooresport.com/indexe.php...ble-top-mounts
ineedyourdiddly
Old 01-30-2016, 04:17 AM   #74
Kostamojen
Theoretically, since both the KW's and the Bilsteins are designed to use stock tophats, wouldn't KW upper spring perches work with the Bilsteins?
Old 01-30-2016, 04:33 AM   #75
strat61caster
You're right, for some reason I thought that the KW's came with their own rear top hats and the shafts were different sizes, seems like they're the same so that Beatrush top hat I linked should be a good fit assuming you want 60 or 65mm ID springs.
ineedyourdiddly
Old 01-30-2016, 04:37 AM   #76
Kostamojen
Now to find someone that sells those front sprung perches separately....
(I want to test this on the front coilovers first with the stock tophats)
Old 01-30-2016, 06:16 AM   #77
JoeHK
JoeHK's Avatar
For me most importantly are the front shocks too
So need to find a solution for there first
Old 01-30-2016, 01:09 PM   #78
Kostamojen
I actually want to try linear up front and keep the progressives in back, to test it out and see how it works. Right now its mostly the front that doesn't cooperate, but the rear of the car is quite nice. Of course that will probably change as soon as I try this, but I always like doing one thing at a time for testing purposes.
Old 01-30-2016, 01:22 PM   #79
JoeHK
JoeHK's Avatar
For me it's mostly fitment problems in the front lol, don't worry, no crazy stance shnizzle, the wheels are 9,5 squared and with the 44 offset they hit the springs up front, that's why i'd like linear springs so if only front is possible and handling is still good that's how i'll be doing it
Old 02-03-2016, 01:32 PM   #80
Kostamojen
BTW Racecomp confirmed the KW front upper spring perches fit the Bilsteins and listed them on their website:
http://www.racecompengineering.com/i...bled-sets.html
I bought a pair and found some ~225lbs springs to try up front. Racecomp has some 280lbs springs listed too that they say work just fine, but im going to test it with the 225's first and see how it is and go from there.
The Following 3 Users Say Thank You to Kostamojen For This Useful Post:
H1C (11-12-2017), JoeHK (02-03-2016), Racecomp Engineering (02-03-2016)
Old 02-03-2016, 02:52 PM   #81
JoeHK
JoeHK's Avatar
Be sure to let us know what your findings are
Old 02-03-2016, 03:06 PM   #82
strat61caster
That looks like an awesome solution for keeping the OE top hats, the OE upper spring perches are basically the same thing as that: big stamp steel cups so these should work great.
ineedyourdiddly
Old 02-03-2016, 08:05 PM   #83
burdickjp
Drives: 2013 ultramarine Scion FR-S
That is a very good deal.
Didn't Subaru make some competition 60mm spring hats for the impreza that were inexpensive?
Crap. I didn't realize you guys were on the hunt for spring hats. You can get the from nearly any suspension manufacturer. Eibach makes 60mm hats, and 60mm springs to suit, but like I said, that's a good deal from racecomp.
burdickjp is offline   Reply With Quote
Old 02-03-2016, 10:08 PM   #84
strat61caster
Link for the hats? I'm still on the hunt for a cheap easy solution for the rear top hats... Right now it's either Raceseng or custom spacer, Beatrush would be good but I'm not doing 60mm springs and it's just as expensive as the Raceseng.
ineedyourdiddly
**NEW**Bilstein B8 HD Struts and Shocks Released FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 118 09-12-2016 01:54 PM
Bilstein B6/B8 and B14 shocks setting Mars2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-26-2014 10:24 PM
Swift Spec R with Bilstein B8 shocks? JMoore412 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-23-2014 01:52 PM
Bilstein shocks & struts Fizz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 10-31-2013 02:56 AM
Bilstein Shocks wahsaihin Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-23-2013 03:12 PM
