Old 01-26-2016, 08:05 AM   #12923
Lorico
Drives: 2015 FRS
Originally Posted by DIM View Post
That HVAC panel looks dope. you should make a DIY. And what does each switch do?
It's a secret
Lorico is offline   Reply With Quote
Old 01-26-2016, 08:23 AM   #12924
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
Originally Posted by hello. View Post
The more I look at this, the more I like the 5AD spoiler. Looks pretty amazing and accentuates the rear end really well.
The pictures don't do it justice. This in my opinion is the best spoiler in it's style. The fit is perfect (doesn't have that small gap over the garnish like some TRD style ones), and just accents the car perfectly.
If you are interested in one go to their website and fill out the contact forum. They are no longer making them, but it's possible they may have some painted ones still. I got it at a significant discount, cheaper than anywhere I've seen (even the members classified when used).
Vladimir Tutin is offline   Reply With Quote
The Following User Says Thank You to Vladimir Tutin For This Useful Post:
stevesnj (01-26-2016)
Old 01-26-2016, 07:11 PM   #12925
ringo16
Drives: 15 Asphalt FRS
WHAT DID YOU DO TO YOUR FRS TODAY?
Originally Posted by trexx0411 View Post
Are these bright enough during the day? I want these but all the videos ive seen of them look really dim in the daylight. I just don't want any dumb drivers rear ending me
Sent from my LG-D801 using Tapatalk
Here are pics of the Valenti Brake lights during the day
ringo16 is offline   Reply With Quote
The Following User Says Thank You to ringo16 For This Useful Post:
trexx0411 (01-27-2016)
Old 01-26-2016, 10:05 PM   #12926
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by Lorico View Post
installed a kill switch, i as;so can start the car without having to use the key kinda line the ones in the EVO's MR
also the wireless door lock and unlock funtion still works. thanks to my bro kam
Interesting that they fit that well
lbroskee is offline   Reply With Quote
Old 01-27-2016, 12:59 PM   #12927
trexx0411
trexx0411's Avatar
Drives: 2015 Scion FRS
Cool thanks for the pics.
trexx0411 is offline   Reply With Quote
Old 01-27-2016, 02:12 PM   #12928
brzzy
@anthonysestito
brzzy's Avatar
Drives: 2013 Sterling Silver Metallic BRZ
Rear fog light install. A la F n' A Automotive.
2013 BRZ LIMITED STERLING SILVER METALLIC
IG: @ANTHONYSESTITO
brzzy is offline   Reply With Quote
The Following User Says Thank You to brzzy For This Useful Post:
D_Thissen (01-27-2016)
Old 01-27-2016, 06:24 PM   #12929
johnbstill
johnbstill's Avatar
Drives: 2013 Silver Scion FR-S
Shaved her ass and did some bondo work .. Sanding and primer application tomorrow then leting her dry till friday for her D6S application .. Clearing her out on Saturday then reinstalling on Sunday.
Sent from my LGLS990 using Tapatalk
johnbstill is offline   Reply With Quote
Old 01-27-2016, 06:26 PM   #12930
johnbstill
johnbstill's Avatar
Old 01-27-2016, 06:26 PM   #12931
johnbstill
johnbstill's Avatar
Old 01-27-2016, 10:47 PM   #12932
mizzta21
mizzta21's Avatar
Drives: 2014 whiteout, scion fr-s
Plasti dipped
Plasti dipped black accents under the fog lights, what do yall think??
mizzta21 is offline   Reply With Quote
The Following 2 Users Say Thank You to mizzta21 For This Useful Post:
trexx0411 (01-28-2016), VirginiaBRZ (01-27-2016)
Old 01-27-2016, 11:28 PM   #12933
xsl27x
Drives: 2015 Scion FRS, Firestorm
Not today, but this week I'm on vacation, so I'm installing my huge pile of parts I have amassed all year.
- 1320 header + op
- Perrin big MAF
- Energy rear shifter bushing
- Mtec shifter + clutch springs
- Whiteline positive shift kit
- Perrin transmission insert (yes I bored out the Whiteline bushing)
- clutch slave cylinder swap
And I've been reading up in the tuning thread and looking at wayno's tweeks for different tunes. I think that's it...
Sent from my LG-D800 using Tapatalk
xsl27x is offline   Reply With Quote
The Following User Says Thank You to xsl27x For This Useful Post:
weederr33 (01-27-2016)
Old 01-28-2016, 10:20 AM   #12934
trexx0411
trexx0411's Avatar
Looks good. I did the same thing to mine.
The Following User Says Thank You to trexx0411 For This Useful Post:
mizzta21 (01-28-2016)
Old 01-28-2016, 04:19 PM   #12935
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
Originally Posted by johnbstill View Post
Attachment 130015
How difficult is this? I really want to try it.
Johnny. is offline   Reply With Quote
Old 01-29-2016, 07:18 AM   #12936
johnbstill
johnbstill's Avatar
Its not hard. I purchased primer paint and clear coat from #automotivetouchup.com
A couple screws hole the piece on , just unscrew. Take some fishing line and slide it behind the scion emblem to cut the adhesive. Then it will pop off . Sand the piece lightly with some 240 grit , mix some bond and fill in the holes. Once dry , prime it with auto primer ( light coats ) 7 or 8 should do . Mark my words if you put it on heavy the primer will crackle! Onec you have a solid primer piece sand the piece with 1000 grit and wipe it with a auto paint tack cloth. Apply light coats of your cars finish color , then wet sand with 2000 grit then apply a final finish coat . once dry apply clear coat 3 times lightly. BAM !
