Old 12-23-2015, 04:38 AM   #393
swarb
Originally Posted by wizzo View Post
Will you be able to tell us which of the piper cams will work with OEM pistons, and if they do not, how much additional clearance are we after?
Also, i wonder if we will need to use some sort of phaser limiter like the mustang 5.0 guys etc.
Why don't you ask the people who make the cams? The would be the best way to get an accurate answer.
Old 12-24-2015, 11:50 AM   #394
celek
Resident Gear Head
celek's Avatar
I saw them at PRI ofcourse I am fully assembled already but my rod bearing is from a RB26 Nissan
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
FRS Justin (12-24-2015)
Old 12-26-2015, 07:30 PM   #395
burdickjp
Drives: 2013 ultramarine Scion FR-S
Originally Posted by Tim Radley View Post
Colorfabb XT-CF20. I've also got some Taulmann high temp nylon to try. The CF20 will take boost pressure without issue.
Nylon likes to absorb moisture. Not sure on Taulman's specific versions.
burdickjp is offline   Reply With Quote
Old 01-14-2016, 12:02 PM   #396
celek
Resident Gear Head
celek's Avatar
Winter is here and its killing me!
Old 01-18-2016, 04:00 AM   #397
Fricke
Drives: Toyota GT86
Have been following your thread and just have a suggestion
Why not buy some secondhand BMW M throttle body's from s38 or the s50 or S54 thes throttle body's are very common too use in Europe for custom builds.
Do they can be handed for as little as 100$
Djust a thought.
Fricke is offline   Reply With Quote
Old 01-18-2016, 10:42 AM   #398
celek
Resident Gear Head
celek's Avatar
Djust a thought.
Not a bad Idea but obtaining a matching result for velocity and cylinder filling with a specific design can yield better results. I am sure BMW did the same math with a 3.2+ liter engine.
Old 01-26-2016, 05:26 PM   #399
celek
Resident Gear Head
celek's Avatar
Plus you need to match the port shape and getting the spacing right on drive by wire throttles won't be easy. The stock ecu needs to see a stock drive by wire throttle body. Aftermarket ecu you could go to a cable throttle and find itb's more easily but if doing that then why not fit carbs and a distributor lol
Not looking forward to a $5k+USD Motec so I would rather struggle with Stock ECU
Old 01-27-2016, 12:52 PM   #400
celek
Resident Gear Head
celek's Avatar
So what is your plan to control all 4 then? Drive by wire is complex to mess with and will crap itself very easily. I considered using the stock body motor with two arms going to each side controlling butterflies but then realised bringing that to stock ecu people represented a big problem so its not a production item. So now i'll just build something that works the way I want and Motec can take care of that.
2 possibilities you mentioned 1 with linkage rods going both ways.
The other option is a custom made electronic controller with either 2 or 4 motors that can be balanced. Using OE ECU signal in and 2-4 outs which can be tuned and balanced.
Old 01-27-2016, 02:13 PM   #401
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
The electronic controller will be much more difficult than anticipated, mostly in order to prevent CELs for throttle body motor current being too low or too high. Same for both the plate position sensors, especially if you try to send voltages from left and right side to the stock ecu. You could make something with power resistors and DACs attached to you controller though...
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 01-27-2016, 02:15 PM   #402
celek
Resident Gear Head
celek's Avatar
Could the stock ecu integrate with such a controller seeing as its doing the entire input, control and feedback? Two pairs of position sensors and a motor driver which is high current. If you can crack that then I think it would be a saleable product. Just not sure what Ecutek allows you to do with throttle inputs as I've never used it. Anyone chime in with a screen grab or information on this?
Theoretically the Box does the work and acts as a single motor and directs multiple motors to function based off an input signal. Its only signal in and out, I keep bugging my Electrical engineer buddy to help and he is throwing fancy terms at me like PIC controller and FETs
I know what they are and how to function the problem is putting them in a box and making them work.
All you need to do is convert voltage IN and modify each output to sync the individual motors.
Old 01-27-2016, 03:45 PM   #403
mcbrawr
Drives: 2014 BRZ Limited
Honestly if that is what you're trying to do, why not pick up an Arduino and handle it on the cheap? Get a motor shield / a motor controller IC for the arduino to talk to and you SHOULD be set if I'm reading your requirements correctly.
'14 BRZ Limited | SBD500X + HRI Tuning | Tanabe Concept G Exhaust | XXR 527 18x8.75 | Hankook Ventus V12 EVO2 245/40/18
mcbrawr is offline   Reply With Quote
Old 01-27-2016, 11:39 PM   #404
celek
Resident Gear Head
celek's Avatar
I have thought about it but unsure of the amperage capability
Old 02-01-2016, 03:10 PM   #405
celek
Resident Gear Head
celek's Avatar
Sent in another (4th) email to Piper, I am afraid somehow it is ending up in Spam Unfortunately they are like a +6 hour time difference so calling them means I have to do it before my morning coffee kicks in. I may have to resort to that.
Old 02-01-2016, 05:52 PM   #406
Hawk77FT
Drives: GTS 86
Have your morning coffee earlier! Problem solved.
YOU can do it!
Hawk77FT is offline   Reply With Quote
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
