Old 01-26-2016, 10:13 PM   #1
MoreBoost
MoreBoost's Avatar
Drives: '15 Scion FR-S (Turbo'd)
Clutch issue. Need help with flywheel.
Had a question. My clutch just went out and I need a new one. Would I be able to use a Exedy Chromoloy Flywheel with a Crawford 86 street clutch?
MoreBoost is offline   Reply With Quote
Old 01-26-2016, 10:37 PM   #2
Hello @MoreBoost and welcome to posting.
I don't see why the two wouldn't work together ....... but I'm not sure.
I suggest you contact Exedy and Crawford and ask them.
Old 01-26-2016, 11:01 PM   #3
XscytheX
Drives: Scion FR-S
I would say yes, both the clutch and the flywheel have to meet manufacturing specs. at least the ones that matter (E.G. flywheel step, and clutch pressure plate throw). I highly doubt that they would be incompatible. BUT it only takes 5 minutes to contact exedy (who is also the OEM clutch manufacturer) and crawford and just ask.
XscytheX is offline   Reply With Quote
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
OEM Clutch And Flywheel with 14k. nickmerronesucks Transmission and Driveline 15 10-22-2015 04:57 PM
Competition Clutch Stage 3 clutch and flywheel, who has one and what do you think? OICU812 Engine, Exhaust, Transmission 2 05-17-2014 01:56 AM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
