Old 01-22-2016, 05:37 PM   #253
Kostamojen
Alright, I have a couple questions. I'm interested in the Stage I or II fronts with the STI rotors and the Sport Performance rears:
1) Do the Sport Performance rear calipers have the Yellow option that the other calipers have?
And
2) How well are these kits working in conjunction with the Traction/Stability control and ABS systems for daily driving and in non-dry conditions?
Kostamojen is offline
Old 01-23-2016, 08:37 AM   #254
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
And
Yes, we can do yellow calipers for the Sport Performance kits... not a problem.
We can absolutely assure you full compatibility with OEM stability/ABS systems in the dry or the wet. One of the motivations for the SP kits was to offer 86 owners a reasonably priced BUT fully ABS compatable alternative to the popular STi caliper retrofit -- which we know does not work well on 86 cars due to the change in bias.
Rafi
Rafi@RR-racing is offline
Old 01-25-2016, 09:39 AM   #255
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Does someone know if the stage 4 fits inside ? :
TE37SL 17*8,5 +45
CE28N 17*9 +40
Thanks.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline
Old 01-25-2016, 01:13 PM   #256
ハチロク
ハチロク's Avatar
Drives: 2014 Ultramarine FR-S
Has anyone installed any of these kits themselves? what does the install procedure look like? Are there any instructions or anything like that included?
please post pictures of the install in progress if anyone has them. Thanks!!
ハチロク is offline
Old 01-25-2016, 02:39 PM   #257
frslee
Just drive it
Drives: 13' FR-S
Install procedure is pretty much the same as replacing a caliper. 17mm to remove OEM caliper, remove brake lines, reinstall with new bolt. There is really good DIY on how to change brake pad/rotor in DIY section. Bleeding is a bit different since there are 2 valves on each caliper. Bleed from outside, then inside.
frslee is offline
The Following 3 Users Say Thank You to frslee For This Useful Post:
ハチロク (01-25-2016), DAEMANO (01-25-2016), Lynxis (01-25-2016)
Old 01-25-2016, 03:27 PM   #258
ハチロク
ハチロク's Avatar
do I need to cut or remove the factory dust cover for either the front or rear kit?
ハチロク is offline
Old 01-25-2016, 11:59 PM   #259
double0seven
Drives: FRS
Nope don't need cutting. Make sure you have a flare wrench!
double0seven is offline
The Following User Says Thank You to double0seven For This Useful Post:
ハチロク (01-26-2016)
Old 01-27-2016, 12:46 AM   #260
Kostamojen
Wait, can someone explain this in more detail?
Old 01-27-2016, 06:37 AM   #261
Rafi@RR-racing
Drives: Toyota GT86
TE37SL 17*8,5 +45
CE28N 17*9 +40
Thanks.
I would be willing to bet YES, those wheels tend to be really good for brake clearance.
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
MaximeT (01-27-2016)
Old 01-27-2016, 06:40 AM   #262
MaximeT
MaximeT's Avatar
Thanks, that's what I thought. Especially the te37sl.
MaximeT is offline
Old 01-27-2016, 10:14 AM   #263
frslee
Just drive it
Drives: 13' FR-S
Let me correct this a bit. There's 4 bleeders on each caliper (at least for mine) but you'll only be using the top 2. Then bleed from outside, then inside.
[ame="https://www.youtube.com/watch?v=RD017fGqmJs"]Wilwood Brakes - Brake Bleed - YouTube[/ame]
frslee is offline
Old 01-27-2016, 01:45 PM   #264
Fenix
Fenix's Avatar
Drives: 2013 Scion FR-S + 2011 Yamaha R6
I should mention that we did all of our development work on the Element Tuning Time Attack FRS. We would really like to thank Phil Grabow for his experience and feedback on this project! Currently Element Tuning is running our Competition Stage IV in the front, and our high downforce Competition Stage II kit in the rear.
I hate music in car videos. Insta'skip. Just sayin'.
Fenix is offline
Old 01-28-2016, 06:26 AM   #265
Rafi@RR-racing
Drives: Toyota GT86
I do inside first, then outside, but I also alternate a few times, and I tap the calipers with a plastic mallet to make sure all the bubbles rise to the top. You never bleed the lower bleed screws.
Rafi
The Following 2 Users Say Thank You to Rafi@RR-racing For This Useful Post:
frslee (01-28-2016), gkubed (03-23-2017)
Old 02-01-2016, 01:03 PM   #266
Carlos_M
Carlos_M's Avatar
Drives: 2014 BRZ Limited
@Alan,
I'm also located in DE and wanting to jump up to the RR-Racing setup this year. Would be awesome to meet up with you and pick you brain on it!
-Carlos
Carlos_M is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
