Old 09-26-2015, 05:19 PM   #323
Pekingduck
Drives: 4 wheels
I added Seibon DV carbon fiber hood, I notice the vent make a difference I average on level surface cruising about 70mph about 175f and with the hood about 165-170.
Pekingduck is offline   Reply With Quote
Old 12-05-2015, 02:56 PM   #324
Pekingduck
Drives: 4 wheels
Added Tomei 80 exhaust
[IMG][/IMG]
Old 12-05-2015, 03:23 PM   #325
Pekingduck
Drives: 4 wheels
Added TRD Carbon Fiber Fender garnish
Old 12-13-2015, 02:13 AM   #326
Pekingduck
Drives: 4 wheels
Old 12-16-2015, 10:51 PM   #327
Pekingduck
Drives: 4 wheels
added aero catch hopefully my hood won't fly off at the track
Old 12-26-2015, 04:41 PM   #328
Pekingduck
Drives: 4 wheels
Got the hood painted and installed the aerolatch
Old 01-24-2016, 12:38 AM   #329
Pekingduck
Drives: 4 wheels
Added tomei 80mm titanium, great workmanship
Old 01-24-2016, 12:05 PM   #330
HaloFRS
Drives: 2020 Subaru BRZ Limited
Why take of the splitter? It looked so clean with it.
Thanks
HaloFRS is offline   Reply With Quote
Old 01-25-2016, 02:19 AM   #331
Pekingduck
Drives: 4 wheels
The car kept oversteering at high speed cornering without a wing. I am trying to figure out a way without adding a wing to the car
Old 01-25-2016, 04:13 AM   #332
HaloFRS
I was actually thinking about getting the same body kit. Then i was like " You know what would look clean? Adding the APR splitter." I googled to see if it would fit and bam someone already did it haha. I plan on getting the nur spec wing to it too. Nice car man, I will follow your build!
Thanks
Old 01-25-2016, 10:14 AM   #333
Pekingduck
Drives: 4 wheels
I think nur spec wing would go well with the style of the five axis and hopefully correct the high speed stability. When I saw the car with kit I thought it was to tame for sema so I call up apr and they added it for me.
Old 02-16-2016, 10:20 AM   #334
Pekingduck
Drives: 4 wheels
My goal orginally was a single exit mainly for looks and weight reduction. I switched from a DC Sports exhaust to a Tomei 80mm. I ran the exhaust for about two months but would like to state my FRS is not a daily driver. Having no cat on the header and replacing the front pipe made my car a screamer and it drones from 3.5-5.5k. At cold start my car would be 108db and when I recently dynoed it at Evasive it was at 114db. Needless to say I got pulled over for the Tomei being too loud on the way to the track. Due to this I began my search for a 70mm and stainless steel exhaust once again and decided to hit up my friend at Evasive to pick up their exhaust.
Initially I didn't like how the exhaust connected but since its slip joint, it allowed me to adjust the position of the exhaust and the tip. The note of the exhaust is perfect, absolutely no drone in any rpm which is helpful when going up a hill with a wide open throttle without the downshift. The exhaust is a lot quiter and cold start measured at 100db. Exhaust seem to have good welds. The exhaust does hang low so I have to be aware when going over speed bumps. The exhaust is nice when put on a lift.
In conclusion great exhaust for people concerned about noise in relation to catless header and straight front pipe, budget friendly, and want a 70mm size.
http://www.evasivemotorsports.com/mm...-INTAKEEXHAUST
Old 05-01-2016, 07:14 PM   #335
HSC
Drives: Whiteout FR-S
I have this exhaust...have had it for about 3 yrs now. Be careful with the fitment as it could cause damage to your rear bumper.
I like the note of the exhaust but have been extremely disappointed with fitment. The tip is off center regardless of how I play around with the slip-joints and only gets worse over time (I.e., after I adjust closer to the center, it slowly offsets itself again over time). Even the pics of the EVS BRZ with this exhaust show how it's off to the side of the cutout. For me, it eventually began to melt the area around my rear bumper after an autocross and got worse after a track day. Just be careful.
HSC is offline   Reply With Quote
Old 05-01-2016, 07:23 PM   #336
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Really like how you painted the hood. I've been thinking about getting that same hood and painting it in a similar fashion... I think i'd bring the white down into the exhaust grooves a little further tho.
I can tell the painter didn't get the color just right.. My painter for my satin white pearl brz didn't get the color right either on my rb kit... It actually looks just like your hood ( a lot more white and less tinted pearl ). I wonder what it is about this color that gives body shops a hard time...
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
olsonpg is offline   Reply With Quote
First FR-S delivery to PekingDuck @ Longo Scion xravexboix Scion FR-S / Toyota 86 GT86 General Forum 3 05-04-2012 04:22 PM
What are people's impressions? TriForce BRZ First-Gen (2012+) — General Topics 46 04-19-2012 06:04 PM
Test Drive Impressions and MSRP confirmation engee BRZ First-Gen (2012+) — General Topics 19 04-09-2012 11:37 PM
FR-S Driving impressions Guaruja Scion FR-S / Toyota 86 GT86 General Forum 30 02-29-2012 05:20 PM
Accurate Engine Impressions S2KtoFT86 Other Vehicles & General Automotive Discussions 1 12-16-2009 12:05 PM
