Old 01-14-2016, 12:50 PM   #15
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Subbed, I'm also in the process of making an oil temp gauge. Work has been kept me pretty busy lately, so hopefully by summer I should have something working.
There's already libraries that can talk OBDII already, so it shouldn't be too bad.
Books is offline   Reply With Quote
Old 01-14-2016, 04:08 PM   #16
Mazikowski
Drives: 2013 GBS BRZ Limited
I've been tossing around an idea for some gauges but would really need to be able to directly interpret the CAN messages instead of polling OBDII data.
Mazikowski is offline   Reply With Quote
Old 01-14-2016, 05:48 PM   #17
Sly_Don
Sly_Don's Avatar
Drives: 2014 BRZ
While I haven't played around with CAN stuff on mine yet, I believe the Spark Fun board I linked above can interface with CAN.
Sent from my D5833 using Tapatalk
Sly_Don is offline   Reply With Quote
Old 01-14-2016, 10:14 PM   #18
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Computer Engineer major here, subbed for interest!
nova.86 is offline   Reply With Quote
Old 01-15-2016, 09:50 AM   #19
Mazikowski
That's the board I was planning on using, at least during prototyping. If I get past that I may look into using the same chip but shrinking the overall form factor a bit.
Hey, me too!
Old 01-24-2016, 01:05 PM   #20
mabviper
Drives: WRB BRZ
I've done some work on the canbus and extracted a bunch of stuff. Let me know if you need help analyzing the data.
http://www.ft86club.com/forums/showthread.php?t=100430
mabviper is offline   Reply With Quote
Old 01-25-2016, 01:47 AM   #21
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
A little project I started last year but never went anywhere. But then again I'm the type with solutions looking for problems
Good luck on the project! I'd like to see how it turns out.
mike_ekim1024 is offline   Reply With Quote
Old 01-26-2016, 11:41 AM   #22
Mazikowski
That's a neat prototype device you've got there... which shields are you using?
I thought about just using a serial LCD and maybe an Adafruit neopixel ring for testing...
Old 01-27-2016, 03:09 AM   #23
mike_ekim1024
Just a proto shield, led rotary encoder, some 7 digit LEDs. The case is kind of cool: https://www.sparkfun.com/products/retired/11667
Seems like many of the parts are retired.. it didn't seem like THAT long ago
Old 01-28-2016, 02:04 PM   #24
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Here is a WiFi SOC with Bluetooth, AtoD and CAN bus:
https://docs.particle.io/datasheets/photon-datasheet/
Definitely a cheaper (and more compact) option than a Arduino with a CAN BUs shield.
justatroll is offline   Reply With Quote
Old 01-29-2016, 03:16 AM   #25
Futaba
Futaba's Avatar
Drives: GT86
Interested in this too.
If you can get the thing small enough, throw it in a JDM edgeless rear view mirror and run an LCD display behind it, display the info on it like smartmirrors.
Heck even if the unit itself was a box somewhere under the dash, you could run a wire to the rear view mirror for the LCD and possibly some touch sensors for input.
And a random mockup of what i'm imagining.
Futaba is offline   Reply With Quote
Old 01-29-2016, 12:57 PM   #26
Mazikowski
That's an interesting idea, for sure. I wonder how difficult it would be to modify the mirror...
I did a little research on using CAN on the Photon. It looks like it "supports" it, but you have to add a transceiver and there aren't currently any code libraries to work with it. I could have missed something, though.
Old 01-29-2016, 02:47 PM   #27
mabviper
Drives: WRB BRZ
This photon looks like a pretty interesting piece of hardware. The STM32 they're using isn't too shabby either. I may just use this for my project later.
Old 02-04-2016, 08:15 PM   #28
Vladimir Tutin
Vladimir Tutin's Avatar
Drives: '13 Hot-Lava FR-S
I've been working on something like this myself, pretty much have everything working that I want displayed. Just need to come up with a design for the output that looks nice.
http://freematics.com/store/index.ph...&product_id=30
This is the OBD-II to UART adapter I've been using.
https://en.wikipedia.org/wiki/OBD-II_PIDs
This page is also very helpful.
When the weather is nice I'm gonna be resuming the project.
Vladimir Tutin is offline   Reply With Quote
Gauge cluster with Oil Temp Gauge Jetbill Interior Parts (Incl. Lighting) 1 10-06-2015 02:41 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
Dashlinq4 and Arduino: LED Control System nickw14 Electronics | Audio | NAV | Infotainment 6 01-05-2015 03:31 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
