Old 01-23-2016, 10:21 AM   #15
Teseo
Drives: frs
If you will dd, why bother with coilovers?
Get RCE springs and koni strut
Old 01-23-2016, 11:52 AM   #16
wise345
Slow I am, boost I must..
wise345's Avatar
Drives: Whiteout 2013 FRS
Flex Z can't beat the bang for your buck
wise345 is offline   Reply With Quote
Old 01-23-2016, 11:54 AM   #17
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Also very true
86kahl is offline   Reply With Quote
Old 01-23-2016, 12:31 PM   #18
NahumCC
Drives: 2013 FR-S 10 Series
Additional flexibility of wheel choice.
NahumCC is offline   Reply With Quote
Old 01-23-2016, 12:32 PM   #19
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
tein flex z is my personal choice!
malubawla is offline   Reply With Quote
Old 01-23-2016, 02:03 PM   #20
Scracho
Drives: 2018 Subaru BRZ
So many choices, so many different ways to spend money...
I had KW V3 w/ Raceseng Camber plates and rear top hats prior to parting out my car and enjoyed them on the track for their flexibility and range of adjustments, but for street use I found them especially noisy with the spherical bearings in the top mounts. You felt everything on the road and large potholes made you pull over in fear thinking your strut was coming through the hood. The build quality and reliability of KW's are much better than anything made in China, Taiwan, Korea, etc. but you get what you pay for.
After successfully parting out my car and not actually selling it I decided to buy parts for it again - This time I decided to go with Tein Control Master Flex (Made in Japan) and honestly I prefer them on the street to the KW's. They also came with top mounts with spherical bearings and a rubber bellows dust shield (KW hard plastic that always cracks) but soak up the bumps and potholes with a more linear feel and less noise. Their "one twist" adjustment for dampening and rebound is idiot proof and with adjustable spring perch and strut/shock body mounts allows for a fair amount of adjustment. HOWEVER they offer "reasonable" track performance but the KW's are superior here to the Tein.
In closing the KW V3 ran me $2700US vs. the Teins at $1350US - Literally half the money and honestly you can't beat Tein for the money in my opinion.
On my fourth 86... and everything in between
Scracho is offline   Reply With Quote
Old 01-23-2016, 04:41 PM   #21
Dream20b
Y u do dis?
I'm just gonna throw this out there... OEM!
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 01-23-2016, 07:09 PM   #22
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
This thread is worthless without specific settings. These are the settings I've been using on my KW V3s for the past 8 months and they are just as comfy as an oem setup while still being ~1.5" lower and providing less roll in corners:
Calum is right...a little tuning and the KW V3s will ride and handle really well.
Raise the car a little bit and use these settings:
"FRONT REBOUND: 12
FRONT COMPRESSION 13
REAR REBOUND : 14
REAR COMPRESSION : 9
*** ALL OF THESE SETTINGS ARE FROM FULL STIFF ******
So adjust the adjusters to FULL STIFF( CLOCKWISE ) then back it off these numbers of clicks.
Myles"
We developed these settings a few years ago and they work really well.
- Andy
These work great as a daily driver. Obviously you'll feel it a bit more if you hit potholes or speedbumps at speed, but in normal cruising on highway and around town, it's the comfiest aftermarket suspension setup I've ever driven. It's a little soft for track use but by no means bad. Thanks to Racecomp Engineering for giving me these settings back when I initially complained about my KWs.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 01-24-2016, 04:55 AM   #23
Northwest86
Drives: Velocity Orange 86 GT
Just as a heads up MCA blues are $1550 aud so under 1100 usd. Becomes extremely competitive even with shipping. Over here theres probably about 10-20% of cars max that don't run MCA's.
Northwest86 is offline   Reply With Quote
Daily Drivers with coilovers comment here Thunderleg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 04-28-2016 09:11 PM
Best coilovers for daily driving/durability Hentai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-24-2015 01:32 PM
Dedicated Daily Commuter Thread Monogram Scion FR-S / Toyota 86 GT86 General Forum 66 01-25-2014 02:08 AM
Springfield Plaza Commuter Lot Sargy Mid-Atlantic 4 10-02-2012 11:52 AM
FRS vs. BRZ as a commuter car DrakeM FR-S / BRZ vs.... 44 09-01-2012 09:50 PM
