Old 01-22-2016, 03:52 PM   #57
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
Originally Posted by Chad_W View Post
I believe we're having a gentleman's discussion here.
[YOYO] is offline   Reply With Quote
The Following 5 Users Say Thank You to [YOYO] For This Useful Post:
GeorgeJFrick (01-24-2016), go_a_way1 (01-22-2016), Hyper4mance2k (01-23-2016), KR-S (01-23-2016), turbos86 (01-24-2016)
Old 01-22-2016, 03:58 PM   #58
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Mr. Sheep you are ba-aa-aad
You're so funny.
Instagram: trevor.parque
Old 01-22-2016, 04:04 PM   #59
Ashikabi
Ashikabi's Avatar
You're so funny.
It was sickening wasn't it
The Following User Says Thank You to Ashikabi For This Useful Post:
Old 01-22-2016, 04:10 PM   #60
MisterSheep
Killed Scion
Old 01-22-2016, 04:11 PM   #61
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
broken pic
MisterSheep (01-22-2016)
Old 01-22-2016, 04:13 PM   #62
MisterSheep
Killed Scion
broken pic
Not broken for me.
Old 01-22-2016, 04:15 PM   #63
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Not broken for me.
might be a work computer block. I don't understand what they block cuz I can still get to all the good corners of the internet
Old 01-22-2016, 04:16 PM   #64
MisterSheep
Killed Scion
@go_a_way1 How about now?
Old 01-22-2016, 04:18 PM   #65
Ashikabi
Ashikabi's Avatar
For once I can actually see it
Old 01-22-2016, 04:22 PM   #66
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
all good now
Old 01-22-2016, 04:27 PM   #67
MisterSheep
Killed Scion
all good now
Good.
Old 01-22-2016, 06:43 PM   #68
Gunman
Drives: 2019 Mazda Miata RF
I figured out the calculations on the previous page, the variable is still how much coil to cut to achieve desired ride height.
I was referring to the mattress spring comment.
Old 01-23-2016, 09:19 PM   #69
Jahris
Drives: 2013 Scion FRS
Back in the day cutting springs was the norm. It never hurt a thing. You just have to be careful to only cut what you want with a grinder. Do not hit any other part of the spring. If you cut bushing on the strut shaft you will not bounce or bottom out. I cut 4 1/2 coils off Suspension Technique lowering spings for my '91 civic and had no problems. Drove like that for years. I also accompanied the cut springs with Tokico blues. The ride was very stiff but I never bottomed out the struts once.
Jahris is offline   Reply With Quote
The Following User Says Thank You to Jahris For This Useful Post:
Gunman (01-23-2016)
Old 01-24-2016, 12:15 AM   #70
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
After tearing an airbag, as a temporary replacement I cut an oem spring and re-installed it. About two inches lower with no bottoming out, no scrub, no spring failure. Ride and handling both fine...
lukey86 is offline   Reply With Quote
#builtnotbought
Cutting Sway Bar End Links mcrane Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2019 09:41 PM
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Cutting apart the rear bumper SavingManuals Cosmetic Modification (Interior/Exterior/Lighting) 32 06-19-2016 05:47 PM
Hesitation/Cutting out in 5th and 6th gear WRBRZ Engine, Exhaust, Transmission 5 08-05-2013 12:21 AM
Waterjet metal cutting? DarrenDriven Northwest 18 09-14-2012 10:13 PM
