Old 01-21-2016, 12:25 PM   #43
DAEMANO
Time Traveller
RS-R Down Sus = -0.6" drop - $219
https://www.rs-r.com/product/subaru-...-springs-2012/
Racecomp Yellow = -0.8" drop - $299
http://www.racecompengineering.com/i...a-yellows.html
The Following 4 Users Say Thank You to DAEMANO For This Useful Post:
Cole (01-22-2016), new2subaru (01-22-2016), Shark_Bait88 (01-21-2016), soulreapersteve (01-22-2016)
Old 01-22-2016, 12:29 PM   #44
Chad_W
Drives: 2013 BRZ DGM
RS-R Downs are very interesting. It seems like that basically what I want without having to use a spacer and the spring rates are very mild increases...in fact the initial rear rate is less than that of a stock FRS. Of course those rears are progressive which means that the final spring rate is higher. I contacted RS-R to find out what the final spring rate is, but they have to get the info from Japan.
I'm going to find out a little more about them, before I make a choice. In respect to cutting and maxing stock spring rate, it seems like BRZ springs up front and FRS springs in the back would be best. I know that people will say that it's upsetting the balance, but while the two vehicle have different spring rate and dampening rates front and rear, all the after market parts are only for both vehicles and therefore would be upsetting that balance just the same.
Chad_W is offline   Reply With Quote
Old 01-22-2016, 01:44 PM   #45
Racecomp Engineering
The listed spring rate is probably the final rate for the RSRs.
Stock BRZ front and FRS rear actually is pretty good. Shocks are the same between the two cars.
Did you look at the JDM STI pinks?
-Andrew
Old 01-22-2016, 02:47 PM   #46
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
While on the subject of changing / modifying coils, I was thinking of using old mattress springs as I'm on a tight budget. What spring rates do you guys think I would get with this set up?
[YOYO] is offline   Reply With Quote
The Following 2 Users Say Thank You to [YOYO] For This Useful Post:
GeorgeJFrick (01-24-2016), go_a_way1 (01-22-2016)
Old 01-22-2016, 02:50 PM   #47
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
found this. seems relevant
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Hyper4mance2k (01-22-2016), [YOYO] (01-22-2016)
Old 01-22-2016, 03:20 PM   #48
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
If he wanted to cut the springs, he would have cut them. What he wants to do is argue with people on the internet about cutting springs.
Hyper4mance2k is offline   Reply With Quote
The Following 4 Users Say Thank You to Hyper4mance2k For This Useful Post:
Cole (01-23-2016), GeorgeJFrick (01-24-2016), go_a_way1 (01-22-2016), turbos86 (01-24-2016)
Old 01-22-2016, 03:21 PM   #49
Gunman
Drives: 2019 Mazda Miata RF
Calculate it yourself:
Spring Rate = GD^4/*ND^3
G=11.25*10^8
D=Wire Diameter in Inches
N=Number of Active Coils
D=Mean Coil Diameter in Inches. Mean Diameter is:
I.D. = 1 Wire plus inside Diameter
O.D. = 1 Wire minus outside Diameter
8=A Constant for all Coil Springs
Just speculation, the rate won't be high enough. I'd just cut the stock ones.
The Following User Says Thank You to Gunman For This Useful Post:
[YOYO] (01-22-2016)
Old 01-22-2016, 03:28 PM   #50
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Hey OP @Chad_W !
Theres a guy selling his OEM springs off of his FRS, his name is... @HueyLooie . I have a 2003 Honda Civic Hybrid that I use for DD but I want to lower it. Will the oem springs from an FRS fit on my honda if I cut them? I know you have experience with cutting as you cut the same springs. I'm looking to lower my civic a couple inches and was wondering if you could help
Instagram: trevor.parque
The Following 3 Users Say Thank You to MisterSheep For This Useful Post:
Chad_W (01-22-2016), GeorgeJFrick (01-24-2016), go_a_way1 (01-22-2016)
Old 01-22-2016, 03:36 PM   #51
Ashikabi
Ashikabi's Avatar
Hey OP @Chad_W !
Mr. Sheep you are ba-aa-aad
Old 01-22-2016, 03:44 PM   #52
Chad_W
-Andrew
Hi Andrew, I know the drop is pretty mild, do you know the spring rate and cost?
Old 01-22-2016, 03:44 PM   #53
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
http://www.ft86club.com/forums/showthread.php?t=100055
Yeah may have found that the same day he was selling his rims... and may have made a post...
Old 01-22-2016, 03:45 PM   #54
Chad_W
G=11.25*10^8
I figured out the calculations on the previous page, the variable is still how much coil to cut to achieve desired ride height.
Old 01-22-2016, 03:46 PM   #55
Chad_W
Originally Posted by Hyper4mance2k View Post
If he wanted to cut the springs, he would have cut them. What he wants is to argue with people on the internet about cutting springs.
I believe we're having a gentleman's discussion here.
Old 01-22-2016, 03:47 PM   #56
[YOYO]
Amazing Member
[YOYO]'s Avatar
G=11.25*10^8
The number of active coils definitely wouldn't work. I'd have to JB Weld some extra ones on.
go_a_way1 (01-22-2016), rosol16 (01-22-2016)
#builtnotbought
Cutting Sway Bar End Links mcrane Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-18-2019 09:41 PM
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 08:33 AM
Cutting apart the rear bumper SavingManuals Cosmetic Modification (Interior/Exterior/Lighting) 32 06-19-2016 05:47 PM
Hesitation/Cutting out in 5th and 6th gear WRBRZ Engine, Exhaust, Transmission 5 08-05-2013 12:21 AM
Waterjet metal cutting? DarrenDriven Northwest 18 09-14-2012 10:13 PM
