#29 |
Drives: 2013 BRZ DGM
The springs need to have one open end and one closed end. You cut the open end and rotate it on the closed end. In this case there's no issue with how the spring will sit in the perch. If both ends are open, you need to be able to rotate at least of the perches to have the spring seat properly.
| The Following User Says Thank You to Chad_W For This Useful Post: | go_a_way1 (01-21-2016) |
#30 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
I am now legitimately interested to see how this turns out now. |
#31 | |
I'm not interested in the residual value of my vehicle, I am interested in customizing it to exactly the way I want it to perform on the streets that I spend most of my time driving on. One of the nice things about there being so many affordable out-of-the box solutions, is that there are tons of oem springs floating around for free or next to nothing. I have a free standing spring compressor and a garage, so swapping springs doesn't take me much time and I could easily go back to the stock suspension prior to sale if I wanted to. |
#32 | |
EDIT: You also make a good point about cheap springs and having a place to work on them. But really, why not just buy a set that's already stiffer and engineered to work properly? If the springs AREN'T progressive your ride heightwill be lower but your spring rate won't be higher, you will bottom out more and put excessive strain on your shocks |
#33 |
So I found some good info ( http://www.bluecoilspring.com/rate.htm ) and created a calculator in Excel. Using pictures of the stock springs and the known values published about them, I was able come up with reasonable estimates and tweak it to produce the factory specs. Then I'm able to "remove" coils and get the new spring rates.
What I found was that cutting .5 coils off the front will increase the spring rate from 153 to 170 and cutting the same of the rear will increase from 195 to 215. Ideally if I could figure out how much coil to cut to achieve my targeted ride height, then I could plug that amount in and find my spring rate. Unfortunately it seems like it would be incredibly difficult to accurately calculate that and it would probably be better to start experimenting if I want to move forward. |
#34 | |
Spring rate does go up as you remove coils, the question is whether or not the spring rate will increase enough at the desired height |
#35 | |
#36 |
I definitely will, I would just need to figure out the ride height change to have the complete picture... I know what cutting half a coil will due to the spring rate, I don't know yet how much drop it will yield.
#37 |
#38 |
That's a good starting point. Also I'm not driving my BRZ in the winter, so I have plenty of time to play and tweak.
#39 |
Not Bаnned Anymore
Go find a local giving away or selling their springs cheap so if you mess it up you got a fall back
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Chad_W (01-21-2016) |
#41 |
Killed Scion
Drives: 2013 FR-S Whiteout
Let the hate flow
Every time I see the title of this thread I just think of,
![]() Even in his voice too.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#42 | |
Not Bаnned Anymore
Step1: ![]() Step2: Cut springs, Go for test drive ![]() Step3:
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Cole (01-22-2016) |
| Tags |
| #builtnotbought |
| Cutting Sway Bar End Links | mcrane | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-18-2019 09:41 PM |
| Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers | b2autodesigns | Brakes, Suspension, Chassis | 818 | 09-10-2017 08:33 AM |
| Cutting apart the rear bumper | SavingManuals | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 06-19-2016 05:47 PM |
| Hesitation/Cutting out in 5th and 6th gear | WRBRZ | Engine, Exhaust, Transmission | 5 | 08-05-2013 12:21 AM |
| Waterjet metal cutting? | DarrenDriven | Northwest | 18 | 09-14-2012 10:13 PM |
