Old 06-10-2012, 03:20 PM   #1
Lil Abner
Drives: 2013 FR-S, 6MT, Ultramarine
DIY-Changing Clock/HVAC LEDs on FR-S
DISCLAIMER: I am NOT responsible for any damage you may do to your car.
DISCONNECT THE BATTERY!!
Remove the screws in the cup holder area
Pull straight up (towards the sky) on e-brake boot
Remove shifter boot
Disconnect the wire to the panel
Pull boot up, and it will come off
Remove 2 screws
Remove panels (one on each side). Pull straight out (towards the outside of the car)
Reach around, and push the USB/Aux plug out. Then unplug.
Pull panel out
Remove 2 screws
Remove the center console. Remember, the 12V plug needs to be unplugged. Here is the center console area.
Remove radio trim with plastic pry bar. The panel needs to come straight out, so take it slow!
Remove 2 screws
Remove side panels. The panels come straight back (towards the rear of the car. Grab the front and rear, and pull
Remove 2 screws
Pull panel out
Remove wire plugs
Remove the cable mounts. Each has 2 tabs as shown
Take the panel inside to your bench. Remove the components from the panel. NOTE. If you have NOT done this before, take your time!! Then tabs break easily!
First the clock. Remove the rear cover with 2 screws and 4 tabs
First remove the screws circled in red. They are in tight, and are easier at this stage. Then remove the blue circled screws.
Remove the board
The LEDs on the right are for the airbag system. They are the same package as the rest of the LEDs.
Choose your own adventure! It's up to you on how to access the LEDs under the white plastic piece under the LCD panel. Here is a picture of the LEDs that need to be replaced.
Once complete, reassemble the clock.
Now the HVAC. Remove the 2 white twist base lights, one in each of the mechanical units (left and right). This is a regular bulb with a yellow condom. Replace this with whatever you want. I chose to do below.
Now the fan module. Remove the tabs shown, plus the ones on the other side. 6 tabs total. Remove cover. Remove white slider.
Rotate/tip the circuit board to remove
Remove the red circle LEDs. The blue one is for the defrost button, and can be changed at your discretion.
After reassembling, you will have a RED clock and HVAC!!
What LEDs did I use? 2PLCC size. Here is the link: Digi-Key
After seeing the color, I might change the temperature knob to white. The red LED kills the blue color.
**UPDATE (13JUN12)***
Night shots
Lil Abner is offline   Reply With Quote
The Following 61 Users Say Thank You to Lil Abner For This Useful Post:
Asphalt~86 (12-25-2012), Bonburner (07-25-2012), brian_c_m (11-07-2012), BRZranger (07-24-2012), Chaetagnath (06-16-2013), Chenslee (06-11-2012), chulooz (06-10-2012), civicdrivr (06-14-2012), colHolm (06-10-2012), CxG (04-01-2017), Dadhawk (06-10-2012), DAEMANO (01-09-2018), DjDATZ (11-05-2013), dj_mallu (07-25-2012), dsgerbc (06-10-2012), encity5 (06-10-2012), enjoi23 (11-24-2012), EvoFanatic (07-25-2012), Fascist Fish (06-10-2012), finch1750 (11-07-2012), Fly Guy (07-09-2012), FriedRicr (03-27-2013), GaN-MaN (07-23-2012), Guff (06-11-2012), Hawk77FT (01-10-2013), Ice_Man (07-17-2012), Jayp (06-10-2012), JeffForSale! (04-06-2025), JollyJON (07-25-2012), Khyron686 (06-24-2012), kludger (12-19-2012), kwood9000 (06-12-2012), lordtakuban (07-25-2012), luxmn (06-10-2012), M&M_Hwy9 (06-13-2012), mattles (06-10-2012), mezdup (06-24-2012), michaelahess (06-10-2012), Mooseknuckle44 (04-14-2014), Nails (03-11-2017), NeedsmoreCowbell (06-12-2012), nibor33 (06-11-2012), Pdub86 (08-15-2012), punchdrunkjuice (06-10-2012), roguetadhg (07-02-2012), RRnold (06-11-2012), scionfrs2014 (04-16-2014), Scooby (06-12-2012), Shipwreck (03-30-2013), spgrizz22 (03-27-2013), SuperTom (03-12-2022), TheRipler (09-02-2012), TPO (06-17-2012), ts87 (09-02-2013), Turbowned (09-07-2012), Username (06-28-2012), WingsofWar (06-10-2012), WolfSongX (12-20-2012), YinYang1980 (07-01-2012), zohare (11-22-2012), zoomzoomers (08-25-2012)
Old 06-10-2012, 03:41 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Most impressive! Great write-up!
michaelahess is offline   Reply With Quote
Old 06-10-2012, 04:39 PM   #3
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Killer job. Night pics now!
chulooz is offline   Reply With Quote
Old 06-10-2012, 04:59 PM   #4
Lil Abner
I will try and get some once the sun goes down.
Old 06-10-2012, 05:59 PM   #5
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Bad as* I was going to do the same thing!!! I did it on my Tc and was thinking of doing it on the Fr-s. Could you take some pics of the removal process?
Juanito08 is offline   Reply With Quote
Old 06-10-2012, 06:01 PM   #6
Lil Abner
What do you mean the removal process? Removing the LEDs?
Old 06-10-2012, 06:05 PM   #7
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Removing the panels and such.
Old 06-10-2012, 06:07 PM   #8
Lil Abner
I guess I'm confused? The DIY above shows the steps of the panels to remove. Do you see those pics?
Old 06-10-2012, 06:09 PM   #9
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Sorry I see them now Internet Explorer was being gay -____-
thanks!
Old 06-10-2012, 06:10 PM   #10
Lil Abner
thanks!
You're brave to still use Internet Explorer!
The Following 6 Users Say Thank You to Lil Abner For This Useful Post:
GaN-MaN (07-23-2012), gkubed (04-08-2019), Guff (06-11-2012), SirBrass (02-05-2014), StarsGarrador (08-26-2012), zohare (11-22-2012)
Old 06-10-2012, 06:19 PM   #11
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
Lol I tried to give there new browser a chance and it failed me yet again.
Do you have and idea of what size bulb it might be?
Old 06-10-2012, 07:12 PM   #12
GodSays
GodSays's Avatar
Drives: Beater
Bravo!
read the leds are smds
so u had to solder the new ones on? I was hoping it would just be plug n play
GodSays is offline   Reply With Quote
Old 06-10-2012, 08:58 PM   #13
Lil Abner
The bulb measures 5.11mm diameter, 10.4mm tall (base to tip). Wire spacing is 1.5mm. The bulb receives 12V, so any LED would need a resistor.
The Following User Says Thank You to Lil Abner For This Useful Post:
Juanito08 (06-10-2012)
Old 06-10-2012, 08:58 PM   #14
Lil Abner
Originally Posted by GodSays View Post
Bravo!
Yeah, look at the picture above. The 2PLCC package isn't as small as some dash LEDs. But tweezers help!
Changing Premium to Limited? zygrene BRZ First-Gen (2012+) — General Topics 32 10-09-2012 11:58 AM
I'm changing my order from World Rally Blue to Lightning Red Subie BRZ First-Gen (2012+) — General Topics 26 06-12-2012 12:59 PM
Changing order, does it require a new order? xwd BRZ First-Gen (2012+) — General Topics 11 03-21-2012 12:57 PM
LEDs that convert heat directly into light... serialk11r Off-Topic Lounge [WARNING: NO POLITICS] 12 03-10-2012 12:08 PM
