Old 06-10-2012, 02:29 PM   #225
Vanguard
Drives: Ford F-150 (not for long)
Scooby, did you change out the bolts yet for a better alignment? I'm surprised the camber was so different corner to corner. And the toe settings.... *sigh*
Also, with the turn-down...its hard to tell exactly where it is compared to the bodywork. I've heard of miatas having similar setups and the exit is too close to the plastic panels causing serious meltage. Be careful!
Vanguard is offline   Reply With Quote
Old 06-10-2012, 03:56 PM   #226
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
cant wait to see some vids! great job the car is coming together so well!!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 06-10-2012, 10:38 PM   #227
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Car getting ready for battle..
Scooby South is offline   Reply With Quote
Old 06-10-2012, 11:03 PM   #228
Scooby South
Conedancer
well Results are up.... Not sure where they got a EVO in STS...last I knew...I was in 5th......oh well..Still Happy ...got some Great seat-time..
results for AutoX 6/10
Old 06-10-2012, 11:20 PM   #229
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Braunsen has a FP evo. Was he running it? Based on your times vs his i would assume he switched to a sts car, i would have thought hed have a bigger raw spread than 2 seconds in FP. If not, kudos!!
Sccabrz192 is offline   Reply With Quote
Old 06-10-2012, 11:47 PM   #230
Scooby South
Conedancer
He musta broke then... Car is a Blast... Sooooo Balanced... on the Stock Suspension...a 16 mm WRX bar is perfect..predictable.....the rear end steps out...and actually helps the car rotate....its an awesome feeling.... my co-driver felt a little more comfortable on the RS3's that I did... I havn't run a RWD Street tire car in LONG time.. went for it on the last run... had it going til I got a bit of Snap oversteer and swaked a cone...oh well...FUN FUN FUN... The power is good to a point... more times than none I felt I was ahead of the car on Throttle and response... and the Car was ahead of me on handling... it definitely is a drivers car...soooo smooth... and precise...goes pretty much where you point it... but the flat spot in the powerband hurts it tremendously..:/ if it came on the power a bit earlier..its would be an automatic contender in STR or STX ... even on the stock suspension... the only thing we changed was the rear bar.... the 19mm made it to twitchy..
Bill
Old 06-11-2012, 01:19 AM   #231
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm subbed for updates!
Old 06-11-2012, 09:11 AM   #232
AX_FRS
Drives: 05 Ford Focus ZX4
What's the "P" for? Also, coming from timing and scoring, please don't do white on white! I'm guessing the P doesn't actually make a difference to them though. Probably for prototype or something like that since the car can't actually compete yet, right?
*Nevermind looked at the results, I'm thinking "Pro-Index." You really should get a color other than white, the havok it can cause in timing and scoring is a pain. I understand that they may do things a little differently where you are though.
Nice of you co-driver to out-drive you.
AX_FRS is offline   Reply With Quote
Old 06-11-2012, 09:17 AM   #233
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Nice running Bill!!
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
The Following User Says Thank You to NYC BRZ For This Useful Post:
Scooby South (06-11-2012)
Old 06-11-2012, 01:26 PM   #234
Scooby South
Conedancer
Its not white...its the angle...its actually 'aluminum' color...and shows up fine from the very side..... and Yes Pro index.. My Co-driver has more experience that I do on Street Tires...He felt a little more comfortable that I did, since I havn't run Street Tires since like 2003... Pretty much been on R'comps since... so It will take some time to get used to..I did go for on my last run...but Swacked a cone and got a bit off line..Vids and pics are downloading as we speak.. ..I am glad that my co-driver found the limits...now I know where I need to be as the driver... Didn't do to bad with Stockish suspension...*Rear Bar and links and Tires and wheels...thats it..
Bill
Old 06-11-2012, 01:40 PM   #235
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Any pictures of it in a steadystate corner? and which rear bar you had on it at the time?
Old 06-11-2012, 01:41 PM   #236
Scooby South
Conedancer
16mm rear bar... pics are uploading to FB as we speak...On lunch hour..it will be this evening before I can get to the VIDS..
Bill
Old 06-11-2012, 01:56 PM   #237
kanundrum
Drives: 2013 Whiteout FR-S
BTW forgot to ask do you have the TRD Door Stabilizer ? Is it worth the money?
Would love to see the review of the sway bar what brand is it ?
Old 06-11-2012, 02:21 PM   #238
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Looks like on r comps there may be potential to lift the inside rear. Its got more dive than i thought it would, really unloads the rear tires, not good for torsen lsd. We'll have to keep an eye on that.
Cool pictures! Thanks for sharing!
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 09:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 06:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 06:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 04:38 PM
