Old 01-16-2016, 09:56 PM   #141
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
I did this DIY (with one Quik Latch Mini on each side) in October and still holding up great: http://www.ft86club.com/forums/showthread.php?t=95624
Phaedrus29 is offline   Reply With Quote
The Following User Says Thank You to Phaedrus29 For This Useful Post:
Antuono (01-20-2016)
Old 01-16-2016, 09:56 PM   #142
NahumCC
Drives: 2013 FR-S 10 Series
Originally Posted by why? View Post
has anyone tried 3m tape? Or I had a Saab Viggen that used to scrape on everything and I used what was basically zip ties behind it to hold the bumper up, it looked totally stock from the front until they broke every few months.
How low did you have you viggen to need something other than the saab bumper supports? I never had a problem and I was on the full koni kit.
I seriously miss the simplicity and ease of taking off the front and rear viggen bumpers compared to this setup.
NahumCC is offline   Reply With Quote
Old 01-18-2016, 12:19 AM   #143
raptorhunter89
personally i think that looks like shit, looks worse than just having a sagging bumper. Obviously Functional if you need to take it off and on often but not really a solution for me..
raptorhunter89 is offline   Reply With Quote
The Following User Says Thank You to raptorhunter89 For This Useful Post:
BRZGM3 (01-18-2016)
Old 01-18-2016, 12:33 AM   #144
Phaedrus29
Phaedrus29's Avatar
OK, just trying to help. On my DGM you can barely see the latches, and my panels finally look like they fit correctly. (They make a number of different colors that might match better depending on your paint: blue, red, white, etc.)
It isn't very functional though, since removing the bumper is still a process on this (relatively easy to install) DIY. The latches just hold the bumper in place.
Old 01-20-2016, 12:20 AM   #145
Antuono
Drives: 2014 BRZ
Awesome write up, my car is black so this is perfect!
Antuono is offline   Reply With Quote
Old 01-20-2016, 07:09 AM   #146
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Why do we take off our bumpers so often that this is a problem?
RichardsFRS is offline   Reply With Quote
Old 01-20-2016, 10:25 AM   #147
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Well people have to do things to their cars you know etc. turbo install, cold air intake, oil cooler/radiator, some even take them off for lip installs. I have never taken off my front bumper and i have that gap because when i scrape it pushes the tabs outwards. Pretty sure this is happening to most of us guys who haven't even touched their bumpers. Shitty ass Subaru tabs/clips
Old 01-20-2016, 05:00 PM   #148
shodan
shodan's Avatar
Drives: MY15 Toyota 86 GTS
Furthermore, considering the cars lowered out of the factory, the thing does scrape often enough. Someone above already said that the dealership highlighted the scrapes under the bumper and said that that's mostly why the bumpers effed up (and more worryingly, declined any warranty repair for it)
shodan is offline   Reply With Quote
Old 01-20-2016, 05:27 PM   #149
RichardsFRS
I've scraped mine a few times. I'll keep a watch on it. I'm stock height. If I lowered it, u wouldn't be able to drive around here
Old 01-21-2016, 02:31 PM   #150
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
It was totally stock. I just kept scraping on hills and the like and clips broke off completely. Since a new one was $800, we just cheaped out and redid it every year or so.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
NahumCC (01-21-2016)
Old 03-23-2016, 05:51 PM   #151
YouSmellBad
So, is there a permanent fix or once you get the bumper sag it'll come back regardless?
YouSmellBad is offline   Reply With Quote
Old 03-23-2016, 09:55 PM   #152
shodan
shodan's Avatar
Wonder if they've addressed it in the new bumper design for the 2017 86
The Following 2 Users Say Thank You to shodan For This Useful Post:
Bramick (03-25-2016), dj2020 (03-23-2016)
Old 03-24-2016, 06:26 PM   #153
covance
Drives: 2015 BRZ series.blue
So in summary this is a issue of how the bumper is made.
Just got a new bumper cover put on after someone hit my car in the parking lot and noticed the gaps. Shop guy showed me how clips are used instead of nuts and bolts on a different Subaru and said can't really do much about the gap so I wanted to make sure this was not a issue the shop caused.
covance is offline   Reply With Quote
Old 03-25-2016, 07:21 PM   #154
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
If they removed it improperly then they could have caused it. It's hard to prove if you don't have evidence it was correct before the shop worked on it. Once you have it it'll never go away until you replace the bumper.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Front Bumper Black Vinyl Juanito08 Exterior Parts (Aero, Lighting, Etc.) 37 09-18-2015 04:09 PM
Front bumper holes... BRZ88 BRZ First-Gen (2012+) — General Topics 29 08-14-2012 12:19 PM
Other than SR front bumper this is the only other one I like Hanzo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-09-2012 03:30 PM
BRZ to FR-S front bumper swap? r4m3n Cosmetic Modification (Interior/Exterior/Lighting) 4 04-20-2012 05:29 PM
Buy this front bumper for G37 Coupe? WhatIs86For Other Vehicles & General Automotive Discussions 12 02-26-2011 02:24 AM
