Old 01-15-2016, 09:33 PM   #1
KevintheGrizzly
Talking First Time ever Tuning
Hey, this is my first time tuning any car I've driven. I currently have a 2013 Scion FR-S and I got the OFT. Now, I do have a couple mods, a Perrin Cold Air with the inlet tube addition, a full exhaust from Invidia including the downpipe, and tomorrow I'll be adding the Tomei Expreme UEL catless headers. I did an initial tune tonight to have everything ready for tomorrow and because I'm horribly impatient. I've been reading these forums like a fiend and you guys are amazing at the level of expertise and help you offer so I'm going to throw myself out here. I've set the Stage 1 map since I'm running 93 oct, and no header, yet. Here's my first log after I reflashed and went on a test drive. I know it's probably not much to go on, but I wanted someone who knows this stuff inside and out to take a peek and make sure nothing went horribly wrong and I'm good to go so far. I WILL be tuning to E85 this weekend so I want to catch anything wrong early and make sure I'm ready to roll come E85 time. So thank you ahead of time for those that will take a look!
http://www.datazap.me/u/kevinthegriz...g=0&data=1-5-6
KevintheGrizzly is offline   Reply With Quote
Old 01-15-2016, 09:46 PM   #2
Cole
Not a troll
Cole's Avatar
I can't speak on how the log looks. But I do believe that there are some differences between regular petrol and e85 for the tunes. So, I'm not sure if seeing something iffy on a 93 tune would indicate there could/would be a problem with e85.
Best of luck, hope it all works out for you!
Edit: If I'm wrong, please correct me. I'd love to learn a thing or two.
Cole is offline   Reply With Quote
Old 01-15-2016, 10:59 PM   #3
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
@steve99 is really good with this stuff.
Looking at your Ignition advance multiplier at least we know your fuel is good because it stays constant at 1. Also this is a good post to read up on that he made:
http://www.ft86club.com/forums/showthread.php?p=1842501
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Cole (01-16-2016)
Old 01-15-2016, 11:08 PM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
The main thing I'd look at between tunes is the LTFT numbers. You can sometimes spot an exhaust leak.
But yeah, the maps between Stage 1 93 octane and Stage 2 E85 are pretty different, so it's hard to say if things will be the same or different post flash.
The log looks fine for the most part. It looks like there's a tiny bit of knock correction, but nothing serious enough to affect IAM.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
Cole (01-15-2016)
Old 01-16-2016, 03:24 AM   #5
KevintheGrizzly
Excellent, I'm super happy with the input and it definitely doesn't feel like its rough. I'm putting the UEL headers on tomorrow morning and then tuning for E85 and I'll post the logs for that after we're done. I've read through the posted resources, especially steve99's posts but I'm hella new to this so my understanding of it is very minimal. I expect I'll understand more as I play with it and it all starts to match up to what I'm seeing as I tune. Thank you so much for the input. Every bit of it helps me!
Also, as far as the LTFT and STFT numbers go, what am I looking for?
Old 01-16-2016, 08:02 AM   #6
steve99
Drives: FT86
The ltft and afr look pretty good considering you have an aftermarket intake
have a read of the ECU logging link below its got basic stuff to look for
Old 01-16-2016, 11:42 AM   #7
KevintheGrizzly
I did read a good bit of those posts, but a lot of it doesn't make too much sense to me yet. I'm picking up a little bit at a time but this it my first time ever doing any of this or tuning in general. I'm a bit late to the party.
Old 01-16-2016, 03:46 PM   #8
KevintheGrizzly
So here's the retune with the headers on STG 2 for UEL 93 OCt. I noticed my LTFT drops to -14 solid during idle. But corrects when the throttle is on. Is this normal?
The Following User Says Thank You to KevintheGrizzly For This Useful Post:
FRSure (01-16-2016)
Old 01-16-2016, 03:50 PM   #9
jawn
jawn's Avatar
Did you just install the headers? Did you use new gaskets? -14 likely points to a small exhaust leak.
Old 01-16-2016, 04:13 PM   #10
KevintheGrizzly
New gaskets, definitely correct but I used an O2 spacer on the second sensor, would that cause it?
Old 01-16-2016, 04:16 PM   #11
jawn
jawn's Avatar
Only if it weren't tightened.
Old 01-16-2016, 06:02 PM   #12
KevintheGrizzly
We used a torque wrench on everything so I feel like it's probably good, could it be I was low on fuel?
Also, did the final step for today, tuned for E85. It's a short run but this might help since it's my actual final modification.
http://www.datazap.me/u/kevinthegriz...ne?log=0&data=
Old 01-16-2016, 07:18 PM   #13
steve99
Drives: FT86
The fuel trims may stabilise a bit on next tank of e85 as their will be less residual petril they should trend a bit more ppsitive after that if 02 sensors gaskets not leak
Ing its likely due to the aftermarket intake so will need maf scaling
If fuel trims ztabilize below 8% and yor afr on e85 follws om
MNxed afr well it will be fine
Old 01-16-2016, 08:48 PM   #14
KevintheGrizzly
It generally starts off with the LTFT at close to 0%. On a cold start. Once it warms up, it's getting to around -17% then dropping to around -13% and stays there. It will goto 0% when under throttle until around 4kRPM and it will drop down to around -9% and fluctuate. I don't know if that helps, also, I grabbed another log to see if you can spot what the deal is. I found the Perrin Intake MAF scaling but I have absolutely no idea how to utilize it or how to scale at all and the directions to get RomRaider even open to where I can see everything is a bit confusing.
http://www.datazap.me/u/kevinthegriz...0&data=1-10-11
Element Tuning's Time Attack Roll Cage. MA-Motorsports Review Element Tuning Tracking / Autocross / HPDE / Drifting 21 04-25-2017 01:51 PM
Open Road Tuning Black Friday Sale!!!! Get your Air Suspension for an all time LOW! Chaz@ORT Brakes, Suspension, Chassis 9 12-05-2014 03:17 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Rev Speed presents: Tuning Car Time Attack 2nd Round - Tsukuba AVOturboworld Scion FR-S / Toyota 86 GT86 General Forum 2 04-19-2014 01:53 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
