Old 12-31-2015, 09:06 AM   #197
churchx
churchx's Avatar
Drives: 2014 GT86
Originally Posted by adprokid
ZE40 17x9.5 +40
Can you tell the weight of it?
Old 01-01-2016, 12:00 AM   #198
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
The wheel and tire weights 41.2 lbs on my old scale, the tire alone is 24lbs according to Tire Rack charts, so the wheel should be 17.2 lbs.
adprokid is offline   Reply With Quote
Old 01-01-2016, 10:36 AM   #199
churchx
churchx's Avatar
Drives: 2014 GT86
adprokit: thanks.
I wonder how much 17x8 may weight then. Even if 17.2lbs is for 1.5" wider, seems these won't be among the very lightest ones unless some "SL" version is made . Pitty, as i like the looks of these ..
Old 01-13-2016, 09:07 PM   #200
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
BUMP!
Speed Element is offline   Reply With Quote
Old 01-14-2016, 02:20 AM   #201
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
Here's a photo of my most recent wheel:
-Volk Racing RE30 Clubsport II 18x9.5 +40
R2RO is offline   Reply With Quote
The Following 3 Users Say Thank You to R2RO For This Useful Post:
Metabrz (03-16-2016), pcuerpo (06-16-2016), Yzu (01-15-2016)
Old 01-14-2016, 03:45 AM   #202
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
TE37SL BE 18x9.0, 45
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
R2RO (01-15-2016)
Old 01-15-2016, 05:54 AM   #203
azynneo
what fenders are those?
azynneo is offline   Reply With Quote
Old 01-15-2016, 11:27 PM   #204
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
So i have a question about anyone that purchased gramlight wheels. I just purchased a set of gramlight 57 extremes. Brand new from a vendor here. I received them, and they look good, seem legit. Inside of each wheel box was a small clear plastic box with a black valve stem inside, the valve stem looked like what i expect, but did not say Rays on the cap, or anything. All the pictures i have seen seem to say rays right on the top cap. Can anyone confirm this, did they maybe stop doing that? ETc.. Im just worried that if thats not correct, then maybe the lug nuts are not legit, hell, maybe even the wheels are not?
gdrider77 is offline   Reply With Quote
Old 01-16-2016, 01:13 AM   #205
R2RO
R2RO's Avatar
If you want us to give you accurate feedback and not just speculated answers, you need to post photos of said wheels & valve stems.
Old 01-16-2016, 10:13 AM   #206
gdrider77
gdrider77's Avatar
I will post some pics, but asking about the valve stems that others got with their wheels wouldn't really need that, you took the time to respond to my post, but didn't actually answer. Do you have volks, rays, etc? If so, would it have been that hard to just answer about your valve stems? Speaking about your particular wheels and what your valve stems looked like is not speculating.
Old 01-16-2016, 01:51 PM   #207
dj2020
I hope this helps. These are the valve stems that came with my Gramlights 57c6 along with the clear plastic box. No 'Rays' on valve stem caps.
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
gdrider77 (01-16-2016)
Old 01-16-2016, 05:08 PM   #208
gdrider77
gdrider77's Avatar
Exactly what I was looking for, those are exactly like the one so got, same boxes as well, thank you.
The Following User Says Thank You to gdrider77 For This Useful Post:
dj2020 (01-16-2016)
Old 01-18-2016, 04:25 PM   #209
CrazyWookiee
Drives: Whiteout FR-S
They look to be INGS+
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 01-19-2016, 10:03 AM   #210
stevo_12v
INGs+ fenders
TE37SL Red $2799 - Rays Volk Racing & GramLights, Advan RSII, Eibach Spacer eauto Wheels and Tires 316 10-15-2014 01:41 PM
Wheel Directory: Volk Racing GT-M 19x8.0 +?? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 09:35 PM
