Old 01-08-2016, 02:48 AM   #155
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Originally Posted by Koj View Post
Pouet de Paris
It s when you want for a run @Les Ecuyers and try 2mn04
We will test your BT+Torque Apps, and my Brodit Support + "Harry's LapTimer Petrolhead" + my new geometry.
I ll be maybe saturday afternoon @Les Ecuyers but not sure. Let me know.
PS : nice wheels
Sadly the track day is cancelled this Saturday. There is one next Saturday.
2.04 looks fast o:
I never had the opportunity to have clean lap on new tires, clean track with the fully built Lotus.
I drove 2.02.5 with a damaged gearbox.
I drove 2.05.3 with a passenger, dead tires and slightly wet track with all the parts on the car.
You saw an 86 drive 2.04 so far ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 01-08-2016, 02:49 AM   #156
MaximeT
MaximeT's Avatar
Originally Posted by RichardsFRS View Post
I want to hear what you think of the new car compared to your lotus. Lotus is nice but that lil red car is hot
You'll love it in no time! I
I will hopefully be able to drive it properly soon and report
Old 01-08-2016, 03:48 PM   #157
Koj
Koj's Avatar
Drives: Toyota GT86
Maxime,
I don't know. I never checked the time until last week coz I recived my new Brodit support. I plan to go on track soon.
Say me when you go on track days
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 01-08-2016, 03:51 PM   #158
MaximeT
MaximeT's Avatar
Maxime,
I go at Les Écuyers next saturday.
Old 01-08-2016, 08:18 PM   #159
Koj
Koj's Avatar
Drives: Toyota GT86
ok rdv is took
Koj
My Journal/Garage
The Following User Says Thank You to Koj For This Useful Post:
MaximeT (01-09-2016)
Old 01-09-2016, 03:48 PM   #160
Iceman
Iceman's Avatar
Drives: GT86
Originally Posted by MaximeT View Post
I only drove slowly on the road so far. Brakes still need to be properly cooked.
The steering feel is a bit better, more accurate, especially off center. But it's still not good. I guess the car needs bushings and ball joints mounted suspensions.
As i would expect, but if i were you i wouldn't be able to get out of the car until it's all properly bedded in and tested
Regarding the steering feel and wheels...
The steering as soon as you get rid of the Primacy's, it gets WAY better. I'm on 215/45 Super Sports and it is really nice, however i'm becoming more and more fond of the stock wheel specs(not the tires), i'll try to explain:
With the ATS and a more aggressive offset, grip is good but you loose adjustability and it's not as progressive when going from oversteer to understeer in certain situations, for example. Same Super Sport tires on stock wheels were way better balanced and grip/feel was spot on.
So i'm curious to know how it handles with such a wide tire and the offset you're running...
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
Old 01-09-2016, 03:52 PM   #161
MaximeT
MaximeT's Avatar
We are going to the track next Saturday to find out
That was my last hot lap attempt with worn out tires :
The Following User Says Thank You to MaximeT For This Useful Post:
Iceman (01-09-2016)
Old 01-09-2016, 04:02 PM   #162
Tor
Tor's Avatar
Drives: Toyota GT86
Looks like a nice track.
Tor is offline   Reply With Quote
Old 01-09-2016, 04:14 PM   #163
MaximeT
MaximeT's Avatar
Yes, it's the best near Paris. There is off camber turn all over the place. That's a nice challenge.
Old 01-09-2016, 06:12 PM   #164
Iceman
Iceman's Avatar
Drives: GT86
Ecuyers, right? I'd like to go there someday, seems like a fun track.
I'm waiting for videos next week then
IG: @oscarfaraday
Old 01-10-2016, 04:54 AM   #165
MaximeT
MaximeT's Avatar
Yes, Les Écuyers.
Old 01-16-2016, 01:30 PM   #166
MaximeT
MaximeT's Avatar
I had the opportunity to drive on track today.
It was dry, between 1 and 3°C with black ice at some critical spots around the track
Lap times were pretty much meaningless.
At track speed, the steering is fine. Not Lotus quality, but I guess it will be good with ball joints top mounts and the right bushings.
When I had the opportunity to have some grip, the ad08r were moving the stock suspension all over the place. Definitely way too soft.
They look like really good tires.
I had corner entry oversteer, not crazy, but unexpected on a stock suspension. Definitely a drift car.
Pedal dance is a pain to do. I had it right once. I drove without after that. I need that magic box to make it automatically.
Without the dance, slight ABS activation makes the driving line inaccurate.
The Ice was more of a pain than that, so I changed my braking a bit for today.
The RR works fine. That was a easy day for them. It needs more testing.
The gas pedal calibration is total journalists crap. 2nd gear was totally useless in this conditions. Feels like you have 50% torque with 1% travel.
The rain started at the end of the midday break. So I went home, missing the opportunity to shoot a video on the non icy track (sorry about that)
Even with the 1Hz GPS, Racechrono predictive lap timing worked great. That's one hell of a tool. I need that 10Hz sensor :p
At the end of the day, that's a great car with massive potential. It drives exactly like the spec sheet says.
I was really happy driving back home in the rain, not being in the Lotus on worn out a048r.
I guess I miss Lotus ABS which is faster.
The car is a lot easier to catch thanks to the weight distribution. But the soft springs make the catch less accurate.
Edit: I drove 2.22.00 for an optimal lap of 2.21.86
Given the conditions that's OK. In the dry in the Lotus on new a048r I guess I can drive 2.00.00.
The 86 might do 2.05 - 2.07 I guess. 2.10.00 is totally sure.
DAEMANO (01-16-2016)
Old 01-16-2016, 06:09 PM   #167
Tor
Tor's Avatar
Drives: Toyota GT86
Did you get opportunity to form an opinion on the 245 tire width?
Old 01-17-2016, 03:45 AM   #168
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
It looks that he answered partially. Suspension is too soft with these tires. Factory mentioned some time ago that you can go up to a 225 tire with stock suspension ...
Lotus Exige anyone? blackhawkdown Other Vehicles & General Automotive Discussions 37 09-25-2014 11:32 PM
FRS/BMW 1 Series M/ Lotus Exige Tanuki FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 09-24-2012 05:53 PM
vs. Lotus Exige SevenTenSplit FR-S / BRZ vs.... 33 03-30-2012 11:16 PM
Considering Lotus Exige, need help! 2jz-gte4life Other Vehicles & General Automotive Discussions 11 10-11-2010 07:23 PM
