#855 |
Drives: GT86
Datalog for OTS Stg1 and Wayno's Stg1 customized for A00G
Hello everybody,
this is my first post in this forum. Usually, I'm active in the german forum for BRZ/86 owners, so please forgive me to post a question here without further introduction of myself, which I'll do later. Recently I purchased the OFT and started to test the OFT OTS Stg1 tune on my car that is basically stock on the drive train except for a Cosworth air filter and a N1 catback exhaust. I'm currently driving on non-premium 98 octane, which I assume is similar to US 91oct. Because I just started learning to read and interpret logs, I wonder if someone in this forum could take a look at the logs I've recorded with the OTS and Wayno's v98 map that I customized for my A00G rom to be sure that the engine runs safe. Currently, It's about 35 degrees Fahrenheit. Once it gets warmer, I'll also try 102 octane petrol and E85 (of unknown quality) as well. This is the log from the first drive after flashing Wayno's work (city and highway): http://datazap.me/u/susurs/wayno-ron98?log=0&data=1 These are the logs for city driving using the OTS OFT v2.07 Stg1 map: http://datazap.me/u/susurs/mixed-traffic?log=0&data=1 and this is a 3rd gear pull when driving conditions allowed it: http://datazap.me/u/susurs/3rd-gear-pull?log=0&data=1 What do you think? Is it safe for me to drive with these maps? |
#856 |
Drives: JAWS
@Susurs I only looked at the third gear pull, but your AFR looks safe, and you don't have any significant knock correction that I can see. You want IAM at 1, which it is. In the future log FLKC.
So from my knowledge, your tune looks safe. |
#857 |
Drives: BRZ Limited; GR86
Hey guys can someone shine some light on my 2nd and 3rd gear pulls. much appreciated
http://www.datazap.me/u/shaynek/log-...og=1&data=1-10 |
#858 | |
Drives: GT86
#859 |
Drives: 2014 BRZ sterling silver
I just put an open flash header on and I flashed OFT stg2-93oct-UEL with Wayno's load limits quiet start and fan mods. I have an A'pexi drop in and a Greddy supreme SP cat back. It's only had about 10 miles on the tune but I thought I would upload the log's. http://datazap.me/u/oldgunfan/stg2ue...-2-3-4-5-6-7-9
#860 | |
Drives: JAWS
| The Following User Says Thank You to JB86'd For This Useful Post: | shaynek (01-17-2016) |
#861 |
#862 | |
Drives: FR-S Whiteout
I dont know why youre logging widband AFR as it's just flatline. And engine load is not being logged. I'd like to see the cam timings as well. The lean spot where maf voltage go up suddenly at 3000 rpms does not look good allong with the peak maf voltage being only 4.08v. I can hit 4.13v totally NA though the esc might have something to say about that. http://www.datazap.me/u/shaynek/log-...-10-11&mark=11
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 01-17-2016 at 07:29 AM. |
| The Following User Says Thank You to solidONE For This Useful Post: | shaynek (01-17-2016) |
#863 | |
#864 |
Drives: 15' Frs
I've got some more data. I'm running Stage 1 EL E85 my ADV is less than 1, do you think it is safe to have the tune on the car?
This was the one where i noticed the ADV was than 1. http://datazap.me/u/jlim7/knock http://datazap.me/u/jlim7/knock-2?log=0&data=1 I tried to keep the rpms as much as i could. http://datazap.me/u/jlim7/redline?log=0&data=1 Thanks |
#865 | |
#866 |
Drives: 15' Frs
There has been a couple of times where I filled the last bit of the gas stations gas.
#867 |
Drives: 15' Frs
Should I go back to 93?
#868 |
I'm not an expert but for reading the forums i have seen E85 that should be 85% ethanol it more like 60% and because we have had so much rain and ethanol absorbs water you may have bad fuel. By the way where are you getting 93oct gas in Atlanta? When i'm down there all I can find is 91 E10 or E15.
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 02:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 10:27 AM |
