#6791 |
What catch cans are you guys running?
Also can anybody supply there dyno runs, i can't really find any. Also, anybody runnindg this with an OFT?
Yeah its an auto, deal with it.
#6792 | |
Drives: 2013 White FRS
#6793 |
AutoX-10/10ths every run
So I just realized that the Raceseng idler pulleys will fit perfectly onto the mounting hardware for the fixed add in idler pulley. You just need to remove the small washer that goes onto the shouldered machined piece. This is useful to those of us who are running the 69mm pulley as it increases the total belt wrap which may reduce the chance of throwing a belt.
The 69mm pulley is 6mm smaller in diameter than the stock 75mm that came with my unit. The original add in idler pulley that came with my kit was 70mm. The Raceseng is 80mm. I know it is 4mm larger in diameter (total), but I think this will allow the following benefits: 1) It brings back the total length of the belt wrap around the pulleys closer to the original configuration. 2) Due to 1), it moves the spring loaded idler pulley arm back closer to its original position. I *think* that means that the spring is closer to the ideal position to generate maximum tension. 3) It causes the belt to have more wrap around the drive pulley on the blower. This *may* help prevent the belt from slipping on the drive pulley. 4) The Raceseng pulley is wider than the original add in idler, which should allow the belt to have a greater margin to float on the surface. I've done a full autox weekend and a weeks work of daily driving on this configuration and I have had no issues so far.
| The Following 4 Users Say Thank You to whataboutbob For This Useful Post: |
#6794 | |
| The Following User Says Thank You to FT86RGV For This Useful Post: | whataboutbob (01-15-2016) |
#6795 |
Just the tip
Radium engineering is what I run. I used to run the dual catch cans but nothing ever dropped into the one that hooked up to the intake pipe so I took it off and sold it, so only running the one now. Best catch can on the market in my opinion, but all of there stuff is exceptional and worth the premium price.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following 2 Users Say Thank You to stockysnail For This Useful Post: | ort895 (01-15-2016), whataboutbob (01-15-2016) |
#6796 | |
#6797 | |
Just the tip
You can order either of their kits or both as they are the same it's just they are on one side or the other. You could plug either into either PCV or crankcase, as you can run the lines how you wish. That sounded better in my head but didn't get expressed in writing very well.
#6798 | |
#6799 | |
I just want to restate that this is a custom application of their product, and I've only had this on for a short time. So far it seems good, but I won't know if it is a good mod until I've done more long term testing to see if any unanticipated issues arise from this configuration.
#6800 |
Also, anybody running aftermarket hoods for more heat management?
#6801 | |
Drives: 4 wheels
![]() Running seibon DV. I saw my water temp go +230 at last track event and i have to end my session early. and I got a vented hood and next will be oil cooler. I went to track this time and water temp didn't even go above 190.
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
| The Following User Says Thank You to Pekingduck For This Useful Post: | ort895 (01-15-2016) |
#6802 |
That looks fantastic
| The Following 2 Users Say Thank You to ort895 For This Useful Post: | 86 South Africa (01-27-2016), Pekingduck (01-21-2016) |
#6803 |
Drives: Supercharged GT86
Update on my 335 build that has had a nasty ending after just 2,100 miles
http://www.ft86club.com/forums/showt...52#post2511652 |
| The Following 2 Users Say Thank You to smudge For This Useful Post: | CK_Bladesmith (01-16-2016), stockysnail (01-16-2016) |
#6804 |
Drives: 2014 Toyota 86
So boost levels - Has anyone got a boost curve for the 210 - I've done a search but found nothing.
I've recently had a dyno run and got a boost curve out of it - to say I'm disappointed would be the understatement of the century - but I would like to see some other boost curves before I start flinging shit. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
