Old 01-15-2016, 12:19 AM   #3711
rj101592
Drives: 2013 scion frs
Originally Posted by Rulin View Post
I was just about to call up CJ and discuss this exact thing with him. Going e85 on c30 or upgrade to c38
Sent from my Nexus 6 using Tapatalk
Keep us updated
rj101592 is offline   Reply With Quote
Old 01-15-2016, 04:43 PM   #3712
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Anyone have a leaking oil problem from the oil bottle?? Filled oil, check it and the cap of the bottle is somehow not tight enough to and now oil leaking from the cap.
scionfr_s is offline   Reply With Quote
Old 01-15-2016, 04:57 PM   #3713
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Kraftwerks Supercharger Owners Thread
Is it possibly over filled?
Could the fittings be leaking?
Maybe the filter is plugged?
But I haven't had that issue. Sorry
Freeman is offline   Reply With Quote
Old 01-15-2016, 07:10 PM   #3714
OMJM
OMJM's Avatar
Drives: Scion FRS
OMJM is offline   Reply With Quote
Old 01-15-2016, 07:43 PM   #3715
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
It might be over filled but just checked it and now the oil is just 2 marks above the min mark and oil still leaking out the bottle,
Old 01-15-2016, 07:45 PM   #3716
Freeman
Freeman's Avatar
If it's a new install you might want to double check the hoses are routed/installed the correct way.
If none of that i would call Kraftwerks ASAP and go over it with them.
Old 01-15-2016, 09:15 PM   #3717
rj101592
If you are talking about the oil reservoir leaking, it is most likely over filled. I had the same problem... took it all apart, cleaned all the washers and fitting and its been fine since.
Old 02-01-2016, 10:42 PM   #3718
Jusjones
Drives: 2013 Subaru Brz Satin White Pearl
Just got my c30 kit installed looking and running good!Name:  uploadfromtaptalk1454384542976.jpg
Size:  453.9 KBName:  uploadfromtaptalk1454384553728.jpg
Sent from my SM-G900V using Tapatalk
Jusjones is offline   Reply With Quote
Old 02-01-2016, 11:16 PM   #3719
kato1337
Drives: 2013 Raven Black FRS
Anyone here run Kraftwerks Blow-Off Valve?
Instagram: Kato1337
kato1337 is offline   Reply With Quote
Old 02-01-2016, 11:21 PM   #3720
Jusjones
Yea it comes with the kit
Old 02-02-2016, 08:34 PM   #3721
Jusjones
Pretty sure the first page of this thread has a link to spare belts or you can just call KW and order one
Old 02-02-2016, 08:43 PM   #3722
Freeman
Freeman's Avatar
Originally Posted by Sgtfluffy16 View Post
is there a part number for the belt? I feel like i should get one as a back up
Calling KW might be the easiest way but if you have the 100mm crank pulley and the 75mm SC pulley the part number is "Gates TP1200-8MGT-20 PowerGrip GT2 Twin Power Belts 9232-0041". You can find it on amazon for like $70.
Old 02-02-2016, 08:44 PM   #3723
Jusjones
Yea I was more or less calling to get the for sure part number, yea I got the 128 95 set up
Old 02-02-2016, 08:45 PM   #3724
Freeman
Freeman's Avatar
If they give you the part number for that belt please share it
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
