Old 01-14-2016, 07:49 AM   #2507
Meanwhile...somewhere in Tennessee
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
babydriver (01-14-2016), go_a_way1 (01-14-2016), Tcoat (01-14-2016), Ultramaroon (01-14-2016), WingZer0 (01-14-2016)
Old 01-14-2016, 11:25 AM   #2508
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Originally Posted by babydriver View Post
Again, it doesn't matter in the case of a solid body electric guitar. That is because the body is supposed to be acoustically inert. It doesn't vibrate so it doesn't contribute to the sound. The sound is picked up entirely by the pickups from the strings. There is no acoustic resonanace in, say, a Fender Stratocaster.
The original electric guitar was the Gibson Les Paul. Les actually built a prototype electric guitar known as "the log", because it was essentially a neck, a set of strings, pickups, a bridge and a big chunk of wood for the body. Les' mother is credited with saying, "Les, no one will ever buy that -- it doesn't look anything like a guitar." So he adapted the design to look more like a guitar and the Gibson Les Paul was born. The shape of the body was completely irrelevant to the sound, but of course it did matter aesthetically.
This is not true with any sort of hollow body electric guitar; the resonant chamber will alter the sound significantly by acting as an acoustic filter on the strings, which is then subsequently picked up by the pickups. So I would suggest that the Millenium Falcon should be cast out of one piece of inert heavy plastic or perhaps ceramic. The deader the better. Electric guitar bodies are sometimes made of maple because it is very stiff and very dead acoustically.
And finally, the reason that a Les Paul sounds different from a Stratocaster is due mostly to the pickups; they are wound differently and have a different response curve. Kind of like two microphones sounding different. If you wanted to make a Millenium Falcon guitar or bass guitar, it could be done and would sound as good as a Flying V or an SG. The body shape is irrelevant as long as it doesn't vibrate.
not so much in the case of a strat (but it's basically a block of wood). In let's say a Gibson Les Paul (I've owned a few, they have a back and a top made of different material so they are better suited to my example), the cavity will affect the sound slightly as will the top/back (material combo) and the weight relief method used (whether it's one solid block, swiss cheesed or the new standards with an actual cavity weight relief.
Don't get me wrong, these affect the guitar very little for those guitars (aside from the new LP standard vs a traditional) but there is still a slight difference in tonality(and I mean very slight, most wouldn't hear it) when compared one next to the other (same pickups, same pots, same setting, set-up, string gauge, etc.). A lap steel doesn't sound the same as a solid body electric guitar even if the rest of the guitar is exactly the same. In that capacity the sound would be affected to a certain extent by the quality of the material used (in this case cheap plastic).
You can grab a cheap china made guitar and change everything in it (done it before) with the pickup, pots, etc. of a Gibson les paul or a fender strat, but you still won't be able to attain the exact sound of those two. Will it be close (to a point where someone who doesn't have an ear for music won't make the difference), probably yes but someone with a developed ear will make the difference between both. You will be able to get the millenium falcon guitar sounding good if you put the work in it, but it will never sound exactly like a flying v or explorer, even if you use all of the parts from a flying v.
Minor difference but a differences nonetheless. Anyways we can also agree to disagree and I will gladly agree with you that the parts of significant tonal value for a guitar are the pickups, bridge/saddle, pots/electronics, type of neck support (bolted vs set neck) and the nut (technically the tuners also since they help with sustain and keeping the guitar in tune)
fumanchu1 is offline   Reply With Quote
Old 01-14-2016, 11:28 AM   #2509
fumanchu1
Sound about right, unfortunately I had to sell my prized guitars when I bought the brz. Sold a fender strat, Gibson les paul and a Gibson es 135. Now I had bought an amp and a few pedals but have no guitar to play on... rofl
Old 01-14-2016, 11:38 AM   #2510
WingZer0
WingZer0's Avatar
The Following 8 Users Say Thank You to WingZer0 For This Useful Post:
Bobblehead (01-14-2016), Cars_&_Things (01-15-2016), Dadhawk (01-14-2016), Eighty 6 (01-14-2016), go_a_way1 (01-14-2016), Sarlacc (01-14-2016), Tcoat (01-14-2016), Ultramaroon (01-14-2016)
Old 01-14-2016, 12:39 PM   #2511
go_a_way1 (01-14-2016), Sarlacc (01-14-2016), Ultramaroon (01-14-2016), WingZer0 (01-14-2016)
Old 01-14-2016, 02:18 PM   #2512
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
The Following 6 Users Say Thank You to Sarlacc For This Useful Post:
babydriver (01-14-2016), Dadhawk (01-14-2016), go_a_way1 (01-14-2016), Tcoat (01-14-2016), Ultramaroon (01-14-2016), WingZer0 (01-14-2016)
Old 01-14-2016, 02:57 PM   #2513
Dadhawk (01-14-2016), go_a_way1 (01-14-2016), Sarlacc (01-14-2016), Teseo (01-14-2016), Ultramaroon (01-14-2016), WingZer0 (01-14-2016)
Old 01-14-2016, 04:00 PM   #2514
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
This is me in a single picture.
The Following 2 Users Say Thank You to ZOMFGAARON For This Useful Post:
go_a_way1 (01-14-2016), NWFRS (01-14-2016)
Old 01-14-2016, 04:10 PM   #2515
Wow that is 1 giant turtle!
Old 01-14-2016, 04:25 PM   #2516
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
That was great
Old 01-14-2016, 04:50 PM   #2517
zman
zman's Avatar
Drives: scion frs
zman is offline   Reply With Quote
The Following 4 Users Say Thank You to zman For This Useful Post:
Bobblehead (01-14-2016), clayrush (01-15-2016), go_a_way1 (01-14-2016), WingZer0 (01-15-2016)
Old 01-14-2016, 04:56 PM   #2518
Teseo
Drives: frs
Never unserstood your avatar pic, sorry
Old 01-14-2016, 05:39 PM   #2519
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
[ame="https://www.youtube.com/watch?v=CMNry4PE93Y"]Zombie Kid Likes Turtles - YouTube[/ame]
The Following 4 Users Say Thank You to BigFatFlip For This Useful Post:
go_a_way1 (01-14-2016), NWFRS (01-14-2016), Teseo (01-14-2016), Ultramaroon (01-15-2016)
Old 01-14-2016, 05:44 PM   #2520
Oh dude you need to get to other parts of the internet more often!
https://www.google.ca/search?q=i+lik...U8dvzPdDQbM%3A
Gun Showcase Thread (No Politics or Philosophical Discussions) TwinscrollGT35R Off-Topic Lounge [WARNING: NO POLITICS] 1087 04-01-2026 10:01 AM
