| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2014 FR-S
| The Following 2 Users Say Thank You to sirwiggles For This Useful Post: | DarrenDriven (03-31-2014), Thekaylakrunkk (09-05-2014) |
#16 |
Kosmos
Drives: Scion FR-S
soon ill have coils and my white cosmis wheels on
#17 |
Kosmos
Drives: Scion FR-S
Sent from my SM-N900P using Tapatalk |
| The Following 2 Users Say Thank You to Kosmos For This Useful Post: | sirwiggles (03-24-2015), Thekaylakrunkk (09-05-2014) |
#18 |
i kill cones.
Drives: around cones in a parking lot
I've been thinking about these wheels. Can anyone give some thoughts/review on them?
Fitment issues, how they're holding up, etc. Thanks guys Edit: and any more pictures if possible
2013 SSM BRZ Limited 6MT
#19 |
XE Autosport
Drives: 2013 Scion FRS Whiteout
Mine are amazing! Holding up perfectly. I'm on coilovers and have like 2-3 degrees camber for perfect fit. Theyll fit w no camber but you'll poke. I'm thrilled w my choice on wheels.
| The Following 2 Users Say Thank You to Thekaylakrunkk For This Useful Post: | BRZ21 (06-30-2014), sirwiggles (09-05-2014) |
#20 | |
i kill cones.
I saw a little while ago you wanted to sell them right? You changed your mind?
#21 |
XE Autosport
Yeah I was going to. But after my coilovers and alignment I've decided to keep them. They fit the way I want them to now lol
| The Following User Says Thank You to Thekaylakrunkk For This Useful Post: | BRZ21 (06-30-2014) |
#22 | |
Kosmos
Drives: Scion FR-S
+ They look amazing fit perfectly when you are on coils and go low. I have 18x9 +25 And lowered it 3 inches and an alignment Spc ez cam camber bolts Maxed out negative camber for the fronts |
| The Following 2 Users Say Thank You to Kosmos For This Useful Post: | BRZ21 (06-30-2014), SlammedSilly (12-04-2015) |
#23 |
XE Autosport
Mine isn't cambered nearly that much.
#24 | |
i kill cones.
I'm not planning on having nearly as much camber cause I have to use oem crash bolts to stay in my autocross class. Hopefully ~2°
#25 |
Kosmos
Drives: Scion FR-S
I have -2 in the fronts. And -3 in the rears
#26 |
Drives: 2014 WR Blue BRZ Lmtd
Just got these installed today. Bronze on WRB wrapped in bfg sport comp 2 225/40/18
Showing how deep the lip is. It's actually flat for only about an inch then angles in. How it looks on the shaded side Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to kdmxdgt For This Useful Post: | rookietopro_frs (10-05-2017) |
#27 |
what type of lugs/locks did everyone else use? i tried to install varrstoen v48 lugs and locks but the socket would not fit inside the bore for the lugs. i had to have generic lugs installed in the style of a standard muteki lug.
thanks |
#28 | |
Drives: 2020 Subaru BRZ Limited
Did you figure it out? Im planning to get these but not sure what lug pattern to choose. 5x100 or 114 Thanks! |
| Wheel Directory: XXR 527 18x9.75 +20 | 4Running Daily | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 45 | 02-05-2017 11:55 PM |
| Wheel Directory: STR 603 18x9.0 +40 | malubawla | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 05-06-2015 01:05 PM |
| Wheel Directory: Cosmis Racing Wheels 18x8.5 +22 | BugeyedWagon | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 38 | 03-06-2015 07:15 PM |
| Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 | mav1178 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-13-2014 04:09 AM |
| Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 03:15 AM |
