Old 01-11-2016, 03:32 PM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
Rpf1 lugnuts and hub centric rings?
Are the OEM lugnuts good to use with a set of RPF1's? What do people recommend for hubcentric rings? My RPF1 set will see AutoX and HPDE so I feel like it would be wise to try and find metal centering rings, due to higher than average heat. Am I wrong?
Keenercarguy is offline   Reply With Quote
Old 01-11-2016, 03:39 PM   #2
kch
Senior Misanthrope
kch's Avatar
Yes, they'll be fine. Not sure about the rings.
Old 01-11-2016, 07:18 PM   #3
SHIFTEVO
Drives: Lightning Red
Yes if you autox you are better off with metal hub rings. You can find them on ebay, your application is fairly common so it should be fairly cheap.
SHIFTEVO is offline   Reply With Quote
Old 01-11-2016, 09:51 PM   #4
wparsons
wparsons's Avatar
You don't need rings, but you'll definitely want metal if you do get them. Plastic will definitely melt on the track.
With properly torqued taper seat lugs centering rings aren't necessary, three summers of tracking RPF1's on mine and zero issues.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Cole (01-15-2016), Keenercarguy (01-12-2016)
Old 01-11-2016, 09:53 PM   #5
KevinK121
Miata traitor
KevinK121's Avatar
Drives: 2002 Miata SE
Tire shop stretched every last stud of mine. You'll NEED longer lugs. You may be able to get away without but heed my experience.
Actually, thinking back on it. The stock acorns are very much so too short. You can achieve the correct torque with them but it will absolutely be at the expense of your studs. I can't remember the size off hand but I bought some plain guerrilla spline drive lugs.
KevinK121 is offline   Reply With Quote
The Following User Says Thank You to KevinK121 For This Useful Post:
Old 01-12-2016, 02:56 PM   #6
Keenercarguy
Mountain Runner
What lugs do you use?
Old 01-12-2016, 03:55 PM   #7
wparsons
wparsons's Avatar
Muteki SR48, nothing fancy but they're durable and work.
flickr
Keenercarguy (01-13-2016)
Old 01-14-2016, 07:59 PM   #8
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Depending on the size you choose you might want to consider extended aftermarket lug nuts. For example, on my 18x9.5 with the stock lugs I found that I sometimes chipped paint off with my socket because the lugs were so inset.
tyler_win_photo is offline   Reply With Quote
Old 01-14-2016, 10:54 PM   #9
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I use TF-Works aluminum hub rings:
http://www.tf-works.com/tf-aluminum-...56-1mm-x-73mm/
And McGard SplineDrive lugs, part number 65554. I got mine from Amazon.
The Following User Says Thank You to NLSP For This Useful Post:
opramwew (01-15-2016)
Old 01-15-2016, 11:01 AM   #10
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I have a question... with hub centric rings do the RPF1 center caps still fit?
hubcentric rings, lugnuts, rpf1, track, wheels
Hub Centric Rings Fitment? Hentai Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-20-2015 01:42 PM
WTB: 65mm to 56.1mm Hub Centric Rings alexvc Want-To-Buy Requests 1 01-24-2015 05:57 PM
WTB Hub centric rings 65mm-56.1 Brinks Want-To-Buy Requests 2 08-27-2014 10:11 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 08:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 08:52 PM
