Old 06-09-2012, 10:54 PM   #15
ssmtsx
Drives: Ultramarine 6MT FR-S
I have noticed this on my mine as well. It's only done it a few times.
I'm having an issue with coasting in neutral though. I was going down a hill the other day in neutral and the stick shift started to vibrate(badly)--the engine also made a noise sort of like a lawn mower sound. It immediately stopped when i pushed the clutch in. I haven't had the stick vibrate again but I have heard the "lawn mower" noise a few more times while coasting in neutral. My car has about 300 miles on it.
ssmtsx is offline   Reply With Quote
Old 06-09-2012, 11:23 PM   #16
Celicadude
Drives: Celica gts
I've had this same issue on my Celica and it almost never happens regularly, but exactly as you mentioned as either at a stop or approaching a stop. Maybe it's a toyota thing although the motor is mostly subaru on the FRS so I'm not even sure about that one. I'd keep an eye on it since you said its happened 6 times already (I had it happen 6 times over 10 years probably). It could also be bad gas so try switching up brands and see if anything changes. Oh and stay away from any cheapo brand gas stations.
Celicadude is offline   Reply With Quote
Old 06-09-2012, 11:25 PM   #17
AzFranz
Az to Nm to Az
AzFranz's Avatar
Mine has done the same thing...I am on my first tank of gas after the dealers first tank. I notice it with or without a/c on. I have a manual as well. Not sure which gas station the dealer used for the 1st fill up, but all of my cars use Chevron...Uncle worked for them for 30 years. If we had Exxon I would use them as well. I believe it is normal. I am at 355 miles.
AzFranz is offline   Reply With Quote
Old 06-09-2012, 11:30 PM   #18
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by yayforaddison View Post
I only have about 170ish miles on my FRS, but lately, at a few lights or under deceleration while clutch is pushed all the way to the floor, the RPMs have dropped below 500 (maybe even 400), and the car shakes for a second or two as if it wants to stall, then bounces back up to about 900-1000 RPMs before going back to the normal 700ish. Could this be part of the break-in period? Computer still learning? Normal for boxer engines?
I wasn't worried about it the first time or two, but it happened again today on my way to a car meet. Today was roughly the 5th or 6th time.
I am a bit stumped
did this to me too, the fact the engine can recover from 400 rpms is pretty impressive lol...
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
The Following User Says Thank You to carbonBLUE For This Useful Post:
Guff (06-12-2012)
Old 06-09-2012, 11:42 PM   #19
FRSCoupe
Drives: Toyota
I'm a little concerned with this issue, not quite acceptable to have idle dip or stability issue.. for a direct injection car with modern ECU idle should be rock steady... didn't they test these cars besides thrashing them around the track?
FRSCoupe is offline   Reply With Quote
Old 06-09-2012, 11:45 PM   #20
carbonBLUE
Reverse Burnouts
they did, its a part of the calibration i guess, engine trying to figure out how low it can idle without dying i guess :P new engines and ecus are weird...
(wont forget you)
2011 Infiniti G37x
Old 06-09-2012, 11:48 PM   #21
yayforaddison
yayforaddison's Avatar
Drives: Whiteout FR-S
Well I am glad I'm not the only one with this issue. It may be part of the break-in tho, but the only way we will ever know for sure, is a thousand or so miles after its over. It may even become a recall if so many people are having this issue even after the break in.
yayforaddison is offline   Reply With Quote
Old 06-09-2012, 11:54 PM   #22
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
More likely it'll become an ECU flash update "campaign" to be done whenever a customer brings their vehicle in for other reasons.
R8 is offline   Reply With Quote
Old 06-10-2012, 12:03 AM   #23
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Mine does the same thing only just at start up for a very brief moment after the cold start idle up it states in the owners manual that this sort of behavior is normal during start up. If it bothers you I would have it checked out, a good dealership should be willing to check it out maybe open a tas case could result in a ecu reflash for everyone ; ). Btw it's not uncommon to see multiple tsb updates for ecu reflash for drivability, throttle response, fuel consumption etc .
Touge Monster is offline   Reply With Quote
Old 06-10-2012, 12:47 AM   #24
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Exhaust is offline   Reply With Quote
Old 06-10-2012, 01:02 AM   #25
whiteout fr-s
Drives: 2013 scion fr-s whiteout
Exclamation let's start a recall
What you are experiencing is not normal, I have started the same thread on another forum. I picked up my car this last week and within about 20-30 miles I started to experience the same problem you are describing except my car actually stalled and the car displayed a check engine light. I took my car to a local toyota dealership and the car stalled in their bay. After restarting the car every light in the dash was illuminated including the check engine light. I have not had the FR-S even one full day, I haven't pushed it beyond any normal means and have only hit 65 MPH. They had to have a scion and toyota rep stop by the shop and now the car has been with them for 2 days and they still don't know what is causing this issue. They are doing a live diagnostic with a rep from California on Monday to determine the ECU fault and possibly correct the problem. If you are still experiencing this issue you should take it to your dealership before further damaging anything in the engine. Ill keep you posted on the outcome.
whiteout fr-s is offline   Reply With Quote
The Following 5 Users Say Thank You to whiteout fr-s For This Useful Post:
ahausheer (06-10-2012), blur (06-10-2012), Marrk (06-24-2012), ShoGun (06-25-2012), ZmZMWagon (06-10-2012)
Old 06-10-2012, 01:12 AM   #26
adamturbo
Drives: mitsubishi evo 9
even with the ac off the unit will still kick in. see if it still happens with the interior fan switched off as that will turn of the ac also. ( i just found this out in my evo as i was having a similar issue.)
adamturbo is offline   Reply With Quote
Old 06-10-2012, 01:20 AM   #27
ahausheer
Re-member
Drives: Toyota camry
Keep us updated ^.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 06-10-2012, 01:27 AM   #28
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I gonna be a bit lazy and not read all the posts... but if you same OP problem start the counting along w current mileage. If we have enough, I gonna send email to higher up SCION rep (prob Monday) & see if they can answer any concern of these.
Marrk (06-24-2012)
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-28-2012 11:38 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 12:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 12:58 AM
