Old 01-11-2016, 02:37 PM   #3417
wparsons
wparsons's Avatar
Originally Posted by Tofu-86 View Post
When learning an unfamiliar track, how do you find the optimum point to start braking and the point to get back to power?
Start braking earlier, then lap after lap brake a bit deeper (5-10 feet, not 50 feet) until you're either out of guts to go deeper, or are entering the turn too fast. Keep in mind braking points will vary with entry speed, pavement temp, tire temp, etc.
Also, I've been in an accident when I attempted to drift but overcorrected the car. How should I avoid similar situation (overcorrection/ fish tailing) technique wise?
The best way is to practice in a safe environment until correcting something like that becomes completely intuitive and doesn't require thinking about corrective action. Wet and/or snowy pavement are great as well if you can find any.
flickr
Old 01-11-2016, 04:22 PM   #3418
Uplink
Uplink's Avatar
Drives: anything you let me
Also remember, when you get one corner 'right', your approach speed to the next braking zone will be higher so be prepared to adjust accordingly.
See if your local track / car clubs are offering skid pad / car control clinics. They will usually pair you with an instructor which speeds up the learning curve, and the surface will be properly prepared (wet/soap/etc.) to allow you to easily induce skids at slower, more controllable speeds. Then build from there.
Uplink is offline   Reply With Quote
The Following User Says Thank You to Uplink For This Useful Post:
wparsons (01-11-2016)
Old 01-11-2016, 06:40 PM   #3419
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
This is a big one for me. You nail a turn then come in hotter on the next turn. Apply the same thought process. When in doubt start early and ease into deeper braking.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
Old 01-17-2016, 02:20 PM   #3420
dp1
driving smoother faster
Drives: Sold
Brake fluid comparison chart:
https://www.lelandwest.com/brake-flu...ison-chart.cfm
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
DocWalt (01-17-2016)
Old 01-20-2016, 04:06 PM   #3421
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Posted this in the wheels/tires section, but figured I'd share here too:
I'll be taking delivery of my new wheels in the next couple months (5-6 months is such a long wait time ) And In the meantime I'm debating tires.
The car will be daily driven and taken to a decent number of track days throughout the year, hoping to do at least one a month for this season. The wheels are 17x8 +35, and I'm currently debating between 225/45 and 235/40 ZII*. I prefer the meatier/wider tire with the 235, but in a discussion with a US rep from the company he mentioned that with the +35 offset I may have fitment issues with a 235, I imagine he was referring to rubbing issues, and have to run a 225 or 215. The car will be lowered around 1" on coilovers, and I will also have camber plates and new LCAs installed at the same time. Currently thinking of running between -2 to -2.5 camber in the front and -1.5 to -2 in the rear.
From folks with similar sized wheels out there who daily and track, would you expect there to really be any issues running a 235/40 tire? What benefits and drawbacks might there be to either size?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-20-2016, 04:15 PM   #3422
Uplink
Uplink's Avatar
Which wheels? I personally run the RPF1's in a 17x8 with 245/40 Z2's (3 sets so far) on bone stock suspension with no rubbing at all, track, AX, or street. That setup has been absolutely fantastic all year long since the car is a daily and I'm too lazy to swap wheels.
From what I've heard, coilovers actually give you more clearance. Guys with 255's have needed to go CO for fitment.
Old 01-20-2016, 04:23 PM   #3423
Shark_Bait88
RS-Watanabe F8. Going for a bit of the old school look.
Old 01-20-2016, 05:15 PM   #3424
Uplink
Uplink's Avatar
Nice!
Actually, just double checked, the RPF-1's are a 45mm offset. That 35mm might put you close to the fenders but should definitely keep you away from suspension components.
Shark_Bait88 (01-20-2016)
Old 01-20-2016, 05:18 PM   #3425
Shark_Bait88
Nice!
Yeah, I think the fender is where the rep was implying I might have an issue. His direct quote from our email correspondence is:
"17x8 35 offset which is lightly aggressive size. you may required narrow size tire which is 215 or 225 wide size and rolled fender and suspension kit to make lowered and negative camber. if you go to slam lowered and super negative camber then you can fit wide and lower offset however you can not drive daily with wider than this size of wheel. so this is aggressive size but still you can drive daily."
Old 01-20-2016, 05:19 PM   #3426
CSG Mike
CSG Mike's Avatar
225/45/17.
Not because of fitment, but because you'll get better respone out of the tire.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
DAEMANO (01-26-2016), Ultramaroon (01-20-2016), Uplink (01-20-2016)
Old 01-20-2016, 05:22 PM   #3427
Shark_Bait88
225/40/17.
Is that because the only tires I can find in that size are r-comps? lol
Old 01-20-2016, 05:24 PM   #3428
CSG Mike
CSG Mike's Avatar
Typo! 225/45/17
Shark_Bait88 (01-20-2016), Ultramaroon (01-20-2016)
Old 01-20-2016, 05:25 PM   #3429
Shark_Bait88
Typo! 225/45/17
Haha I figured.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
CSG Mike (01-20-2016)
Old 01-26-2016, 02:56 PM   #3430
Campo
Campo's Avatar
Drives:
on the street I run 255/30-19 on a 19x8.5 +45 on stock suspension without rub anywhere (Pirelli PZero Nero - all tires have different shoulder widths than the spec, so you actually have to physically measure to make sure you clear). Your +35 offset combined with the 20mm thinner tire than mine *should* put your width (not width) outside shoulder at exactly the same as mine, but I'm not sure how your aspect will relate to the height. I went 30 series to stay shorter...
edit=your width won't be the same, the location of the outside shoulder should be the same.
225/45/17.
^^^ This all day long for a car that's going to see double duty as a DD and track bitch.
Ignore everything I said above and just run this size. Or get two sets of rims/tires.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
