View Poll Results: What Exhaust set-up should the FT come with?
Single Exhaust - 1 exit 86 36.60%
Single Exhaust - 2 exits (2 mufflers) 71 30.21%
Single Exhaust - Centre 15 6.38%
Dual Exhaust 63 26.81%
Voters: 235. You may not vote on this poll
Old 01-23-2011, 03:16 PM   #1
KiingDavid
Drives: Lexus IS 300
Exhaust system: dual or single
Concept pictures suggest that the FT is equipped with dual exhaust. Although this setup is aesthetically pleasing, I think its unnecessary. First off its a 4 cylinder, a single exhaust should be sufficient. Iirc, the 4 cylinder audi a4 and the hyundai gen coupe and some othersn come with it and its nice and all but it adds cost and weight without any significant performance gain. Well I'm sure 20-30 extra lbs below the centre of gravity won't have any noticeable negative affect (it might actually help in lowering the cg) but COST! I'm sure many of us who get this car will be thinking of mods and let's face it, many of us (although I'm sure some of u are) aren't made of money, and if it is a true dual exhaust then its gonna cost nearly twice as much. And I already think those brand name exhaust systems are over priced: its just a length of steel tubes. But that's besides the point.
What are your views on what the FT should come equipped with: duals or singles?
Ok I've added a poll. place your votes =D
KiingDavid is offline   Reply With Quote
Old 01-23-2011, 03:20 PM   #2
Dimman
Kuruma Otaku
Dimman's Avatar
It's just split into dual exits at the end like an S2000.
Because titanium.
Old 01-23-2011, 03:27 PM   #3
dalli
dalli's Avatar
Drives: Toyota
I like to see duals on the car because of symmetry.
dalli is offline   Reply With Quote
Old 01-23-2011, 04:12 PM   #4
KiingDavid
if thats the case i hope the exhaust piping run on the right alongside the drive shaft to balance out the weight of the driver as much as possible. but knowing its a japanese/european production where its rhd it'll be on the left.
Old 01-23-2011, 05:50 PM   #5
Dimman
Kuruma Otaku
Dimman's Avatar
I wouldn't worry about how the exhaust will affect Right-Left balance. Different driver weights would affect it more.
And don't let no fatties in the passenger seat! Heh.
Because titanium.
Old 01-23-2011, 06:55 PM   #6
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
LMAO! So true.
For me, I like dual looks... but only need one, so I'll vote for single exhaust.
Old 01-23-2011, 07:49 PM   #7
70NYD
70NYD's Avatar
Drives: RX8 S1
the thing is the size of the muffler is what makes most of the weight, most of the time when there is dual exhausts (one pipe branching to 2 tips), the muffler is only slightly larger than if it was for single exhaust. i prefer dual as i like symmetry
70NYD is offline   Reply With Quote
Old 01-23-2011, 08:25 PM   #8
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Single. Less complicated, cheaper, and highly unneccessary on a boxer engine IMO - and a single can look beasty if done correctly (Supra )
IMO dual exhaust should only be used on V (or W)-layout engine's. There is no real reason to use them otherwise.
Snaps is offline   Reply With Quote
Old 01-23-2011, 08:49 PM   #9
70NYD
70NYD's Avatar
Drives: RX8 S1
if the exhaust is a single with single muffler with 2 exists its not complicated and only slightly cheaper and heavier (for the extra pipe from muffle to out)
Old 01-23-2011, 09:05 PM   #10
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
honestly, i don't really care, as long as it looks good.
my MR2 came with a dual-exit muffler, and now it has a single exhaust on it.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 01-23-2011, 09:31 PM   #11
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I am hoping for a single, if the car is designed to have a single it wont look as unbalanced when I change it to an aftermarket single.
chulooz is offline   Reply With Quote
Old 01-23-2011, 10:07 PM   #12
Matador
hashiryu
Drives: Mk4 Supra
Pretty much this. The weight difference would be negligible.
A flat engine and a V would share that commonality. Two different banks. So not a very good example.
Matador is offline   Reply With Quote
Old 01-23-2011, 10:28 PM   #13
70NYD
70NYD's Avatar
Drives: RX8 S1
Oh wait brainwave
Single in the centre that way it's "lighter" simpler and symmetrical
Prefferably mounted inside the bumper with a proper diffuser underneath
Old 01-23-2011, 10:32 PM   #14
alexmotrix
rookie drifter
Drives: 1987 ae86, 1985 celica gts
most of 4 cylinders dual exhaust can use a camaro sport muffler and will cost around 30$ more than the same quality/size muffler with single exit.... not a big matter... but I like a lot middle exits like mini cooper S, the turbo versions have the muffler in the center of the car, verrry cool looking and weight distribution
alexmotrix is offline   Reply With Quote
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 10:16 PM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
