Old 01-02-2016, 10:40 AM   #211
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by ajc209 View Post
At least with the sc its quicker than the average diesel exec.
I have to admit, 330hp seems a bit low if im going to the effort and expense of adding uprated internals though.
No hope of a pulley kit offering the full power the sc is capable of?
Sent from my GT-I9300 using Tapatalk
we'll see, the main scene is that you will need to go to 8 ribs to be able to drive it a max speed under load
Matt@Cosworth is offline   Reply With Quote
Old 01-02-2016, 04:27 PM   #212
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So to truly bring out this supercharger, you'd need a pulley kit for the entire engine or just the crank pulley? Would that effect the engine in any negative ways? As well, there have been many debates on the harmonic dampener that the stock crank pulley is (supposedly). Would you guys address this as well?
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
JerryIII (01-02-2016), killboy (01-03-2016)
Old 01-03-2016, 03:46 AM   #213
Matt@Cosworth
there's a few options
1) just 10% smaller pulley on the SC nose - no other changes required, works with our stock tune too
2) 10% smaller on the SC nose + 7% on crank pulley (we would modify a stock pulley to keep the vibration damper aspect) - this is the point where new guts are required for long term reliability
3) above + 15% on crank, 8 rib wide & all pullies changed to accommodate the 8 ribs and water pump and alternator pulley resized to restore the original crank pulley gearing.
The Following 4 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (01-03-2016), JerryIII (01-03-2016), killboy (01-03-2016), weederr33 (01-03-2016)
Old 01-03-2016, 07:43 PM   #214
weederr33
weederr33's Avatar
So... what would this new pulley cost?
JerryIII (01-04-2016), killboy (01-04-2016)
Old 01-04-2016, 07:14 AM   #215
Matt@Cosworth
dunno yet
I'll get some quotes in
The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post:
JerryIII (01-04-2016), killboy (01-04-2016), weederr33 (01-04-2016)
Old 01-06-2016, 11:42 PM   #216
weederr33
weederr33's Avatar
So with Option 3, what do you suspect the output would be? Or would different internals vary the power (i.e. 9:1 vs 10:1 compression)?
The Following User Says Thank You to weederr33 For This Useful Post:
killboy (01-06-2016)
Old 01-07-2016, 07:09 AM   #217
Matt@Cosworth
should be about 380Bhp with a 10.5:1 ratio
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
killboy (01-07-2016)
Old 01-07-2016, 07:15 AM   #218
ajc209
Drives: GT86 Cosworth
That'll be nearly enough to match your TVR power/weight. Would be fun/scary to try that on primacies
ajc209 is offline   Reply With Quote
Old 01-07-2016, 01:44 PM   #219
weederr33
weederr33's Avatar
380 is a bit much for me, but that is pretty awesome
Old 01-07-2016, 02:00 PM   #220
ajc209
And I've heard they've spun these tvs chargers quite a bit faster than their rated max without any issues ;-)
Old 01-07-2016, 02:11 PM   #221
JerryIII
Drives: Subaru BRZ
I have a set of GFB light weight pulleys is that bad ?
JerryIII is offline   Reply With Quote
Old 01-07-2016, 02:38 PM   #222
weederr33
weederr33's Avatar
I don't see why it would be bad? I have the Perrin crank pulley, water pump, and alternator pullies, too.
Old 01-07-2016, 02:58 PM   #223
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Note he said bhp, not whp. That would translate to about 320whp I figure.
killboy is offline   Reply With Quote
Old 01-07-2016, 03:10 PM   #224
ajc209
Personally I wouldn't mess with crank damping with an sc installed.
I dont think these cars loose 60hp in the drivetrain. Perhaps 40hp.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
