#29 |
Drives: Devolving WR Blue 6 Spd BRZ Limited
I'm not a big fan of the J hooks though. They make a noise on the street like a playing card in the spokes of your bicycle. I have some deep grooves that formed at the points on each end of the J's. Smooth rotors for me when it finally comes time to replace them. Fortunately, Essex has both available.
__________________ Jim Pomroy Hi Jim, Just wanted to let you know that I got the same groove and occasional brake "shudder/vibration" with my ap sprint kit when using aggressive cl sintered pads. I switched to ferrodo pads and no more groove and fantastic performance with better longevity. I think the sintered pads were making too much heat causing more issues than the added stopping power was worth. I like the ferrodo pads aside from noticing they tend to chunk up on the leading edge which i think is partly due to design.... No tapered edge like you see from some other manufacturers. |
#30 |
Drives: World Rally Blue BRZ
Thanks OP! This will be awesome data for justification on the AP kit purchase!
![]() Clearly the hero we all deserve |
#31 |
Drives: 2014 BRZ SCCA STU endurance car
Damn, that's some seriously impressive life from a set of rotors.
#32 |
Drives: White BRZ
This is an excellent thread. OP, thanks for initiating it.
I seem to be getting about 15 days out of the OE rotors with Carbotech xp12, but I'm not as fast as the OP. OE tires as well (which I like, even though it's an unpopular sentiment). No significant 'heat checking' - those are the small cracks, right? Why use titanium shims? Do they keep heat out of the fluid? I don't even run shims with my xp12. Finally, does the AP setup fit behind the OE wheels? |
#33 | |
Drives: 2013 SWP BRZ
AP setup requires spacers up front with OEM wheels.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
#34 |
Drives: White BRZ
My rotors are not heat checking, but I do see some obvious wear. Because of this, I have been replacing them at the same time as the pads. Maybe I'm too quick to replace. Should I just wait until they're at min thickness?
#35 |
Post up pictures of both the inside and outside, and i can let you know.
#36 |
Drives: White BRZ
Thanks Mike, that's very kind of you. It will take a while until I can get pictures, but I'll definitely take you up on this.
#37 |
CAR-AHOLIC
Drives: 2018 BRZ Ts - CWP
Well, I just got into my AP Endurance kit. I have been bugging CSG Mike with a bunch of little questions. Mainly, because he lets me. Sorry about that Mike.
But so far the kit is great except i am having to get use to a little squeal. However, it seems to be getting better over time. I swapped from XP8s to XP10s. Which leads me to my question here to all the track rats here that run this kit. When you need to swap pads, what trick or technique are you using to press the pistons back into the caliper. I am sure you could use some plastic or wood and use channel locks, but i would rather not. I have a brake caliper kit, and i am sure I may be able to do something with it. But i bet some of you guys here have smarter ways of doing things, without the risk of marring up the calipers or worse damaging the pistons. Thanks for the help in advance.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger Last edited by brzaapi; 02-24-2016 at 09:50 AM. |
#38 |
JHerbert Racing
Drives: 2013 Scion FRS
Sub'd - Future AP Sprint user. I <3 spread sheets
#39 | |
Drives: '22 BRZ
Since I don't actually own a set (nor do I own an AP BBK yet) I've gotten away with using a paint stirrer stick broken in half with a C-clamp. One half of the stick to protect the caliper, the other to push the pistons in. Slightly tedious on the 4 piston calipers I've done it on, but it works. |
| The Following User Says Thank You to DocWalt For This Useful Post: | brzaapi (02-24-2016) |
#40 | |
CAR-AHOLIC
Thank you sir. yeah that is essentially what i did, and have done in the past. But i thought maybe there is some little genius trick that someone on the forum here could share.
Daily: Audi TT RS DD/4WD - Colorado ZR2 Bison - Mallett Supercharger |
#41 | |
#42 | |
Drives: 2023 BRZ
| What does it cost you to race? (Cost of racing) | rice_classic | Tracking / Autocross / HPDE / Drifting | 63 | 12-27-2013 09:54 AM |
| Benefit BBQ 11/16 12-3pm for our FOOD DRIVE. | VTR Performance | Northwest | 0 | 11-13-2013 05:11 PM |
| Benefit of dark wax? | Barbarian | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 07-18-2013 05:31 PM |
| 2014 WRX benefit the 86? | SanDiegoFRS | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 02-18-2013 09:50 PM |
