Old 01-05-2016, 12:54 PM   #15
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I like this one too, but I still like the one I have a little bit more. That being said, this would be the only other one I would consider
Old 01-05-2016, 05:01 PM   #16
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Would do 10/10
Old 01-05-2016, 08:00 PM   #17
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
I like it bit some questions.
Does the White part of the RPM glow when the lights are on?
Temperature/coolant, are those accurate min/max numbers?
Lastly, if you do make these. Please make sure to include the little triangle next to the gas icon. On most if not all cars, it points to which side the gas lid is on when pulling into a petrol station.
YamahaR86 is offline   Reply With Quote
Old 01-06-2016, 02:41 AM   #18
JW89225
Drives: E92
Originally Posted by DIM View Post
I'd be really interested if it had the 86 logo or the Toyota lettering instead.
Sent from my SM-N915P using Tapatalk
It would be possible to have GT86 lettering or FRS letter or BRZ lettering. I think I would leave it up as optional. The only other option might be letter buyer choose km/h or mph for the dials. However, I am leaning toward having a hybrid dial to cut down on cost of having to produce different templates. But, we will see how things goes.
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
The Following User Says Thank You to JW89225 For This Useful Post:
JoeHK (01-10-2016)
Old 01-06-2016, 02:43 AM   #19
JW89225
Drives: E92
Thanks for the heads up on the gas lid pointer, I am working to make the white parts of the RPM glow when lights are on. However, it might end up too intense for driving at night, so I may change it to have a bluish hue glow like on the new Lexus F Sport models.
I have the basic template out, and will be testing how the lights work with such dramatic change. But rest assure, I aim to make everything work perfectly.
2013 Scion FR-S 6AT
Old 01-06-2016, 04:33 PM   #20
nova.86
Legendary Member
nova.86's Avatar
Drives: HyperBlue BRZ
Looks great, I'd definitely be interested, BRZ option & bluish hue glow would look amazing
Looking forward to the finalizing and options!
nova.86 is offline   Reply With Quote
Old 01-07-2016, 11:39 AM   #21
thunderlights
I like where this is going but heres an idea, whynot make some actual use of the speedometer on the left. Its completely useless and the space could be taken up by othee gauges or a screen. Would be expensive but innovative to this platform.
Sent from my SM-G850W using Tapatalk
thunderlights is offline   Reply With Quote
Old 01-07-2016, 12:24 PM   #22
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Pretty sure other companies have tried but you're essentially messing with a one piece unit if you want to get rid of the speedo on the left to add something else. In that case, they'd have to build a whole new instrument cluster so that each part is separate and can be taken out/removed.
Old 01-07-2016, 01:20 PM   #23
thunderlights
Ah i just looked a picture of it dissassembled and i see what you are saying. I was thinking of removing the needle and that section of overlay and putting a screen on top. Not sure what would become of the various lights that in that spot though. They would have to rewired into the screen, and i dont have the knowledge to know if its even possible. Anyways its getting a little off topic, but it would very interesting to see.
Old 01-07-2016, 02:18 PM   #24
SHIFTEVO
Drives: Lightning Red
God damn that is amazing....
SHIFTEVO is offline   Reply With Quote
Old 01-08-2016, 12:55 AM   #25
JW89225
Drives: E92
Most recent revision. Still got more fine adjustments to go before I call it acceptable. I am going after OEM like quality. The next update will probably after I consult with some "professional" friends. Nothing is set in stone yet, so expect some minor changes here and there such as fonts and layout etc.
In the mean time enjoy!
2013 Scion FR-S 6AT
The Following 2 Users Say Thank You to JW89225 For This Useful Post:
DustinS (01-08-2016), PandaSPUR (01-08-2016)
Old 01-08-2016, 01:23 AM   #26
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Very nice.
My only gripes/critiques right now:
1. The glow around the RPM seems a bit odd/dirty. The red should also be darker. But that seems more like a printer/material quality issue than a design issue.
2. That FR-S lettering feels out of place since theres nothing to light it up
- Maybe replace the "Sport S+" lettering with FR-S, BRZ, etc?
3. Same goes for that lil graphic above the RPM needle pivot point. I haven't seen that before, whats the purpose?
4. The font for the RPM looks a bit off to me as well, not sure why though. Again, might just be a printer/material quality issue.
Old 01-08-2016, 04:40 AM   #27
Antuono
Drives: 2014 BRZ
Can you just get rid of the left side MPH. Would be cool if you could mount some other gauges there Ie. boost, oil pres ect.
Antuono is offline   Reply With Quote
The Following User Says Thank You to Antuono For This Useful Post:
ck-GT86 (01-08-2016)
Old 01-08-2016, 05:38 AM   #28
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
I'm in! This looks clean
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
F/S: FR-S instrument cluster MissDeb Audio/Visual, Electronics, Infotainment, NAV 5 04-08-2014 04:02 PM
led cluster help Grip Ronin Cosmetic Modification (Interior/Exterior/Lighting) 12 02-14-2014 12:29 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
BRZ cluster on FRS? Shipwreck Electronics | Audio | NAV | Infotainment 6 03-07-2013 11:09 AM
New Lexus ES leaked. Who said it's Camry of Lexus? Dark Other Vehicles & General Automotive Discussions 25 02-24-2012 01:34 AM
