Old 11-24-2015, 12:12 PM   #505
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
I'd also like to announce that we have found a fix for the warm start bug some folks were having. None of the current tunes have this issue, and if you car is afflicted, please email me directly for an update to your map.
Sincerely,
Zach
Old 11-24-2015, 03:03 PM   #506
Utopia Be
Drives: BRZ 6MT
Originally Posted by sales@delicioustuning.com View Post
Hello,
We can make this tune to work quite well for you. When you're ready, we can go over more details and build a tune around your custom kit.
Sincerely,
Zach
Thanks Zack, So ill order 105mm pulley, and we will continue with you!
Btw, its posible to add AEM water/meth kit to the tune?
Utopia Be is offline   Reply With Quote
Old 11-24-2015, 03:06 PM   #507
DeliciousTuning
We really don't support water/meth kits on these cars, or any cars really. If you want to go with an alternative fuel, we recommend either E85 with Flex Fuel (preferred) or unleaded race gas.
Sincerely,
Zach
Old 12-15-2015, 08:42 PM   #508
DeliciousTuning
Update:
You guys asked for it, and now we have it. Overboost protection is now standard on all Flash & Go tunes for turbo applications! For existing customers that would like overboost protection added to their current tunes, please email me directly at sales@delicioustuning.com.com . For new customers, this will come as standard on your order based off of your desired boost levels on the ordering form. We can also set this up as a dynamic overboost protection based on ethanol content, to work hand in hand with our boost control based off of ethanol content.
Happy Holidays!
Sincerely,
Zach
The Following 5 Users Say Thank You to DeliciousTuning For This Useful Post:
civicdrivr (12-22-2015), clayrush (12-15-2015), Crazypinoy9 (12-16-2015), solus (12-15-2015), xkalelx (12-23-2015)
Old 01-05-2016, 12:02 PM   #509
DeliciousTuning
Happy New Year!
We are working on some new developments this year and to give you an idea here are some pictures. This is to improve the safety features of your built engine and forced induction applications.
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
itsibarra (01-05-2016), kask2_6.0 (01-10-2016)
Old 01-05-2016, 01:16 PM   #510
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by DeliciousTuning View Post
Happy New Year!
Cheers,
William Knose
For those of us who are not familiar, what is this exactly? Fuel cut-off switch?
Old 01-05-2016, 02:15 PM   #511
DeliciousTuning
We are incorporating a Fuel Pressure Sensor kit into our tunes, especially high horsepower cars and Flex Fuel cars. The Fuel Pressure can be monitored by the ECU and if the fuel pressure drops too low (at varying thresholds), it will cause the ECU to go into limp mode and throw a Check Engine Light notifying the driver.
Cheers,
William Knose
The Following 4 Users Say Thank You to DeliciousTuning For This Useful Post:
BigFatFlip (01-05-2016), dp1 (01-05-2016), LS1M (01-05-2016), maxjedi (01-06-2016)
Old 01-07-2016, 07:17 AM   #512
Utopia Be
Drives: BRZ 6MT
Hello dear Delicious Tuning,
I have an Jackson Racing SC with stock pulley.
And i have decided to get your tune!
I have some questions before geting it...
If you can answer them it will give me the push to get it now!
1. Does this tune already comes with RaceROM so no more purchases needed?
2. Im going to change the Intercooler for a bigger one and shorter tubes lenght (top exits from cooler)
similar to Greddy turbo kit, so will your provided free data log and update work with it?
3. Can i use Blow off Valve to Atmosphere?
youre saying that no MAF sensor needed...
If yes, so where you recomend to put it? before the Intercooler of after?
I think that is all what i want to know!
Thank you for your great tunes!
The Following User Says Thank You to Utopia Be For This Useful Post:
Yoda (01-07-2016)
Old 01-07-2016, 12:11 PM   #513
DeliciousTuning
Hi,
1. Yes all of our Flash & Go Tunes comes with RaceROM support. We take full advantage of the custom RaceROM tables available to us. We also allow you to choose how you would like to setup RaceROM custom features such as AutoBlip, Flat Foot Shifting, Launch Control, Custom Traction Control, Boost Cut and more.
2. Yes you can use a Blow Off Valve to atmosphere as the MAF is not used at all in our tunes. We are pure speed density tunes which uses only the MAP sensor for load calculations through our custom VE table.
As for location of the BOV, usually we suggest near the intercooler and make sure to use at least 11-12 pound spring since anything lower will cause surging at idle.
As an FYI we have found one of the most drivable kits on the market to be the GReddy Kit, and this is because it does not have a BOV in their kit.
We would even suggest to not run a BOV at all, since this will offer better drivability and more power between shifts.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Utopia Be (01-07-2016)
Old 01-07-2016, 12:46 PM   #514
Utopia Be
Drives: BRZ 6MT
Hi,
Cheers,
William Knose
I already have HKS original BOV, i paid a lot fot it, so i would like to install it, haha, and i think that running W/O BOV can damage the Rotrex charger...
Any way, when i purchase, i get one extra e-tune update? Becouse the setup od the Jackson Racing kit will be a little different becouse of the shorter intercooler tubes.
Old 01-07-2016, 03:13 PM   #515
DeliciousTuning
I believe I sent you a private message on this one. We can definitely accommodate any customization you do to your kit.
Sincerely,
Zach
Old 01-16-2016, 01:43 PM   #516
enivid
enivid's Avatar
Drives: WRB JR BRZED
Cheers,
William Knose
What's the Eta for release date?
enivid is offline   Reply With Quote
Old 01-17-2016, 12:10 PM   #517
Calum
That Guy
Drives: 2013 asphalt FRS MT
Cheers,
William Knose
Any chance of adapting that to work as an oil pressure sensor?
The Following User Says Thank You to Calum For This Useful Post:
Bykov (01-17-2016)
Old 01-19-2016, 12:20 PM   #518
DeliciousTuning
Calum (01-21-2016)
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
