Old 01-05-2016, 10:47 PM   #1
soilent
Drives: 2022 BRZ Premium
Switching to LEDs. Do I need CANBUS bulbs?
I see a lot of sites that say both CANBUS and non CANBUS are compatible. Just wondering if either is necessary. Anyone here have any issues with just regular generic LEDs in their car? Looking to replace all interior and most of the exterior lights. Thanks.
soilent is offline   Reply With Quote
Old 01-06-2016, 06:53 AM   #2
P3tras
Drives: Subaru BRZ '13 WRB
I am using cheapest regular LED bulbs, they work great. No need for can-bus ones.
Edit: That only applies for interior and number plate lights. For turn signals you need to replace flasher relay or buy high power consumption LED lights (basically ones with built in resistor for higher power consumptions to avoid hyper-blinking)
P3tras is offline   Reply With Quote
Old 01-06-2016, 11:54 AM   #3
JakeRogue
JakeRogue's Avatar
Drives: 2014 Monogram FR-S
If I may recommend, I went with Diode Dynamics for my switchbacks (FR-S), rear signals, and reverse lights, everything plug and play, no problems at all
You may need a relay flasher for turn signals (LEDs in general use less power so you get hyperblink.
JakeRogue is offline   Reply With Quote
The Following User Says Thank You to JakeRogue For This Useful Post:
pfaffendorn (01-06-2016)
Old 01-06-2016, 08:27 PM   #4
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
JakeRogue,
I am thinking of using brighter bulbs also, especially to get more light to the rear and up higher. The Diode Dynamics kit looks interesting as a way to do that, and if that's what you went with, did you run into any idiosyncrasies about how the bulbs work? I'm imagining using switchback LEDs which would give me an amber blinker with a bright white backup in the turn signal lamps. That seems to be a way of avoiding moving the blinker into the red taillight, which I'd like to avoid. Any advice from somebody who's done it, for somebody who can't find too much detailed info? Thanks in advance for any heads-up you can pass along.
David.
pfaffendorn is offline   Reply With Quote
Old 01-06-2016, 08:52 PM   #5
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
Originally Posted by pfaffendorn View Post
JakeRogue,
David.
The rear turn signal is not dual filament. It only does one color and functions as a blinker. It doesn't function as both the rear turn signal and reverse lights. I currently have the tail as turn module and really like it. Now the old turn signals function as reverse lights. It's much brighter.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
Old 01-06-2016, 09:22 PM   #6
JakeRogue
JakeRogue's Avatar
Correct. You can get switchbacks in the front only.
Old 01-06-2016, 09:33 PM   #7
Euro7R
Drives: 2013 Subaru BRZ
I'm running canbus and non-canbus leds, no issues.
Euro7R is offline   Reply With Quote
Old 01-06-2016, 09:36 PM   #8
NahumCC
Drives: 2013 FR-S 10 Series
JakeRogue,
David.
Joyride is correct. You can't do it that way. Get the turn as tail kit from diode dynamics along with there bright LED to turn the old turn into a reverse light. It'll give you more than enough light. As you can see below, the upper reverse lights from diode dynamics are putting out way more light than the Valenti bar LED's below.
NahumCC is offline   Reply With Quote
The Following User Says Thank You to NahumCC For This Useful Post:
Old 01-06-2016, 11:42 PM   #9
JakeRogue
JakeRogue's Avatar
I will also say that upgrading the reverse lights to super bright LEDs on the bottom does add quite a bit of light at the bottom and was enough improvement for me. Stage 3 from Diode Dynamics & I'm quite pleased.
Old 01-07-2016, 10:10 PM   #10
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Nothing lighting wise on our cars need to be canbus compatible, because we have no warning lights if say the bulbs go out regardless. Also only thing I would get canbus is HIDs because they seem to run better like the ones from diode dynamics do they dont flicker or flash at a rapid rate and look 100% oem in my winjets.
Old 01-07-2016, 10:33 PM   #11
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
I've gone with Diode Dynamics on all my cars, he'll answer your questions make sure you are equipped right. He's probably in the best position to answer this. Not sure if he is even on this forum though?
GeorgeJFrick is offline   Reply With Quote
The Following User Says Thank You to GeorgeJFrick For This Useful Post:
Diode Dynamics (01-08-2016)
Old 01-07-2016, 11:28 PM   #12
FRSBRZGT86FAN
@Diode Dynamics is on the forum I've used all there products on my car so far except for turn signals because I did that before I heard about them
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
TapTurn flasher - convenience signaling for LEDs or stock bulbs! scottmcphee Exterior Parts - Lighting 120 09-22-2017 01:45 PM
BRZ Sun Visor LEDs (Or white bulbs) Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 12 11-26-2012 04:57 PM
