Old 10-26-2015, 05:51 PM   #43
redlined600
redlined600's Avatar
Drives: Fr-s
Not that one specifically but others like it. IMO a full string setup like smart strings is far more valuable for two reasons.
1 one can roll the car
2 it gives thrust angle.
I like the longacher camber gauge because it can be calibrated to true zero on any surface. It's also very robust and well made.
I correlated the actual camber to the marks on my camber plates so I can make adjustments on the fly.
redlined600 is offline   Reply With Quote
Old 11-19-2015, 04:41 PM   #44
redlined600
Drives: Fr-s
I was going through my album and thought I'd post up a couple pics of the rollbar after it was all done.
I do still need to make a bracket for the radio amp, I just have it out for now.
Test fitting the rear panels, what aa pita!
Primed
And done.
Old 11-20-2015, 10:04 AM   #45
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Looks good. I would move ditching those OEM seats and getting proper buckets with proper harness pass throughs up the list.
Old 11-20-2015, 10:16 AM   #46
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Looks awesome. Nice build and pickup.
JazzleSAURUS is offline   Reply With Quote
Old 11-20-2015, 10:09 PM   #47
redlined600
Drives: Fr-s
Agreed. I have it all, just need to find time to install it. The car is in storage until spring at this point.
Old 01-06-2016, 04:21 PM   #48
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Always enjoy talking with ya on the forums, and love the build you've done. My plans are roughly the same in both the short term and long run.
How did your RE71Rs hold up to autox and tracking? I'm picking up a set of 17x9 Koseis wrapped in 245 71Rs this weekend, and plan to use them for this year's season of autocross as well as about 3-5 track days.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-06-2016, 07:21 PM   #49
redlined600
Drives: Fr-s
Thanks.
My use last year was roughly:
30 autox runs
~450 miles of track time (3 days)
~1500 street miles
I flipped the tires part way through the season.
There is probably almost 40-50% in the middle but the edges aren't great. One has very little treat left, two days at Road America really put a hurt on the left outsides.
Depending on your setup and how easy you are or are not on tires, one set might not last thre season.
Old 01-06-2016, 08:46 PM   #50
redlined600
Drives: Fr-s
I bought in on the new race capture kickstarter.
Obd2 Canbus+GPS+accelerometer+gyro
If they deliver, it will be here in time for spring.
Old 01-07-2016, 10:31 AM   #51
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am looking forward to seeing people getting these. I am still holding off on what direction I want to go till I see them in person.
Old 01-07-2016, 01:41 PM   #52
redlined600
Drives: Fr-s
I'm a bit skeptical that it will be everything they claim it to be but I really like the idea of pulling things like wheel speeds and steering angle from CANBUS as well as having an actual accelerometer built in.
In addition, if it really takes off and people are openly sharing their data via Podium, it could conceivably make everyone faster.
I still autox enough to make the AIM solo DL a non-starter, for strictly track that would likely be my choice.
Old 01-12-2016, 02:06 PM   #53
redlined600
Drives: Fr-s
I was thinking about headers the other day which led to a bit of data analysis. I made histograms out of the rpm data from an autox run and track lap to get an idea of where I'd like the power band to be.
One lap from road America (I need to pull +Long G only data to see if it differs much)
For auto x I took it one step further and only used data while long. G was positive. In other words, only data while under acceleration was taken into account. I also tracked total time spent accelerating and time spent at WOT. It should be noted this was a very short course, 33s.
All in all this was an interesting exercise, and gives me a solid idea of what to look for when it comes time to start shopping for a header.
Old 01-13-2016, 10:45 AM   #54
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Makes sense to me with the slower speeds, more corners, and less shifts of an AutoX track. I should plot these as well.
Old 04-17-2016, 08:51 PM   #55
redlined600
Drives: Fr-s
It's been a long winter and I finally got the car out of storage. While I have a lot planned, and this was last on the list, I had a few hours along the other day and felt the need to fab something so I whipped up this battery hold down.
Short list for this year:
-New oil cooler hoses/ mounting
-Seat and harness install
-Highflow cat in the mid pipe
-Exhaust
-Whiteline sub frame bushings(on the way)
-Corner balance
I'm also in process of making a new string alignment jig. Pretty close to finishing that up.
Had another kid in November so future progress and events will slow down for a bit.
Old 05-31-2016, 11:51 PM   #56
redlined600
Drives: Fr-s
One of the things I wasn't very happy with was the mounting of the oil cooler. I always felt mounting it to the bumper beam would be a better/safer solution than the bottom tray.
New mounts with shrouding/support brackets.
Mounted
Should be ready to roll very soon.
Once this is wrapped up, I can do alignment and drop the race seats in.
Still no race capture.....
The Rebirth of an Italian FlowForm_Wheels Other Vehicles & General Automotive Discussions 16 06-01-2014 11:46 AM
Trackday GPS Recommendation milhouse Tracking / Autocross / HPDE / Drifting 12 03-24-2014 12:19 PM
Trackday at ORP jblmr2 Northwest 6 02-21-2014 05:30 PM
2nd trackday in FR-S icemang17 Tracking / Autocross / HPDE / Drifting 4 09-24-2012 04:40 PM
1st trackday in FR-S icemang17 Tracking / Autocross / HPDE / Drifting 10 09-01-2012 10:02 PM
