Old 01-06-2016, 01:07 PM   #15
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by shellslinger View Post
I think if you're still under warranty it might be a good idea just to bring it to the dealership.
All i've got is the squeak -- No bad feel. Looks like i'll have to put the spring back in if i take it in.
Warranty goes until 60k miles correct?
EDIT: Should mention that I only have a squeak/creak whenever letting up on the pedal. Pushing the pedal down there is no sound or strange feel.
ajcarson11 is offline   Reply With Quote
Old 01-06-2016, 01:40 PM   #16
shellslinger
Drives: Whiteout FRS
Yes, 60k miles. Not sure about that but I would put the spring in if you can. Yeah mine started out that way where it would make a sound going up but it eventually started to squeak pushing down on the clutch as well.
shellslinger is offline   Reply With Quote
Old 01-06-2016, 01:42 PM   #17
ajcarson11
Good to know. Did you have your entire clutch/transmission replaced as well?
If I take it in, I suppose I should pull the mtec springs so I could use them again if the transmission gets replaced. Bummer.
Old 01-06-2016, 01:52 PM   #18
shellslinger
They left the clutch and transmission alone but they did replace the throw out bearing and few other little items associated with it. Yeah I would just let them fix it. I'm just not positive about just greasing the clutch fork will resolve the issue permanently.
Old 01-06-2016, 01:53 PM   #19
ajcarson11
Right.
I may try to lube it and then if I start experiencing the squeak when pushing the clutch down I will take it in while under warranty.
Thanks for your input!
Old 01-06-2016, 03:39 PM   #20
reeves
My clutch's been squeaky for the last 30K+ miles now lol .. hope it's nothing major.
Old 01-06-2016, 05:35 PM   #21
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
FInally made an appointment few weeks out to have it checked out. I've had the squeak for a while now but the feel of the clutch pedal is very annoying. I just hope they don't give me the whole "you have modded your car blah blah" or "it's going to cost $xx to diagnose and then we can say if it will be covered etc."
"Don't be a don'ter, do be a doer" - Johnny Wu
ap5512 is offline   Reply With Quote
The Following User Says Thank You to ap5512 For This Useful Post:
Ultramaroon (01-07-2016)
Old 03-17-2016, 01:05 AM   #22
jdrmoney
Drives: 2013 BRZ WRB limited MT
I recently noticed a noise coming from my clutch once I push in the clutch pedal (disengage the clutch). I believed it to be the throw out bearing. I called the dealership because my car is still under warranty and they said since this is a wear item it will not be under warranty and I would have to pay to have it fixed. Which who knows how much that cost. He put it as the breaks wear and if they need replaced that is not covered under warranty.
I have access to a full shop and decided to do the job myself. 2 hours later transmission was out and the throw out bearing rattled and was hard to turn. Also when I moved the clutch fork back and forth it squeaked like hell.
Ordered a new throw out bearing and Lucas Red N Tacky #2. Going to install it this weekend and grease everything to see if it stops.
Also upgrading the transmission oil and while I am at it the differential oil as well.
Car has just over 52K miles and the transmission oil was black. Should drive a lot better once I am done. I will post an after actions report of my findings. Possibly a video of the old throw out bearing and clutch fork making noise and after I grease it up.
jdrmoney is offline   Reply With Quote
The Following 3 Users Say Thank You to jdrmoney For This Useful Post:
jacjac3 (03-18-2016), JDKane527 (03-17-2016), zonda (03-17-2016)
Old 03-21-2016, 12:11 AM   #23
jdrmoney
Thumbs up After actions
I have installed everything back in the car yesterday and drove it around and I can't hear anything from the clutch anymore. She is as quite as you could possibly get.
This is the video I took of before and after the grease. [ame="https://www.youtube.com/watch?v=2sJr6hQ3SgU"]https://www.youtube.com/watch?v=2sJr6hQ3SgU[/ame]
The Following 10 Users Say Thank You to jdrmoney For This Useful Post:
aegisdrgn (12-24-2016), ap5512 (03-21-2016), ARTBRZ (03-21-2016), axelo (03-21-2016), C4RBON (09-01-2016), Cheeky (04-09-2019), dhuang (06-07-2016), kthxbai (10-13-2016), PandaSPUR (01-15-2017), Tt3Sheppard (03-21-2016)
Old 03-21-2016, 12:55 AM   #24
gravitylover
That looks like a tough spot to get to without dropping the tranny. That's the most definitive picture I've seen yet of the problem though. Thanks for showing it!
Old 03-21-2016, 01:07 AM   #25
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Mine had chunks missing off of TOB.
Old 03-21-2016, 11:31 AM   #26
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Thanks for posting this video it really helps. I think my main issue was the squeaky clutch fork.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 03-21-2016, 02:14 PM   #27
ap5512
ap5512's Avatar
@jdrmoney - where did you buy the TOB and how much was it? Also, how difficult was it to remove the tranny and everything associated to do this job (granted you have the right tools)?
Old 03-23-2016, 05:08 PM   #28
jdrmoney
I bought the TOB from a Subaru dealership online. It was $48 with shipping.
It took me a little over 2 hours to drop the transmission and another 3 to put in back in because I took the clutch fork off and cleaned everything to put new grease on. Along with changing the differential oil.
For reference I used this service manual located here: http://www.ft86club.com/forums/showthread.php?t=35279
It gives you everything you need to know to complete the job. Even where to grease and the torque specs for everything. The only thing I didn't replace was the transmission/differential drain and filler plug gaskets. Which I believe are somewhere around $8-$11 per piece. I have just been checking the plugs for leaks and none so far.
Best of luck if you decide to DIY, wasn't too hard but I have dropped a few transmissions in the passed. It makes a difference if you get the car on a lift. I did a few with the car on the ground and no transmission jack.
ap5512 (03-24-2016), funwheeldrive (01-04-2018), JB86'd (05-13-2016)
Squeaky clutch V1B Engine, Exhaust, Transmission 24 06-16-2016 04:48 AM
Squeaky Chair Selvedge Issues | Warranty | Recalls / TSB 19 01-30-2015 05:49 AM
FR-S and the clutch is slipping. Where can I get it fixed in Cincinnati? rinnamon Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 08-08-2014 10:56 AM
RED FR-S with DG Squeaky Clean Hamza7 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 02-01-2014 02:48 AM
Squeaky Panel?? Dispect Scion FR-S / Toyota 86 GT86 General Forum 25 01-08-2013 04:56 AM
