Old 01-06-2016, 12:11 AM   #57
funwheeldrive
Originally Posted by alex345 View Post
I know this has probably been answered but is it possible to remove the trd logo with acetone or something?
I don't think it would be possible without it looking messed with.
Since this thread got bumped, I figured that I would give an update. The piece has stayed on very well, even though it has been in the rain, and I wash my car often. It still looks great, and hopefully it does for years to come.
The Following User Says Thank You to funwheeldrive For This Useful Post:
MisterSheep (01-06-2016)
Old 01-06-2016, 12:18 AM   #58
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Here's mine just for bumps sake
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
sato (06-02-2018), SkAsphalt (01-06-2016)
Old 01-06-2016, 09:31 AM   #59
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Sadly the "TURD" (not a typo) logo kills it for me...
Cockatoo is offline   Reply With Quote
Old 01-06-2016, 11:00 AM   #60
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Originally Posted by Cockatoo View Post
Sadly the "TURD" (nots not a typo) logo kills it for me...
?? It does say TRD.. I assume you do not respect TRD?
Old 01-06-2016, 11:15 AM   #61
Cockatoo
TALLY FT86
Cockatoo's Avatar
TRD is fine, I just dont have any TRD parts on my car.. but I wouldnt want this piece with any company logo on it.
Old 01-06-2016, 11:49 AM   #62
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
I covered the logo with a piece of gloss black body wrap material and you'd have to know its there to see it.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
funwheeldrive (01-06-2016)
Old 01-06-2016, 12:30 PM   #63
Cockatoo
TALLY FT86
Cockatoo's Avatar
Care to share a pic?
Old 01-06-2016, 01:37 PM   #64
FLYFISHR
FLYFISHR's Avatar
Needs to be washed again but here's the picture
The Following 2 Users Say Thank You to FLYFISHR For This Useful Post:
funwheeldrive (01-06-2016), SkAsphalt (01-11-2016)
Old 01-06-2016, 03:59 PM   #65
funwheeldrive
I'm not a fan of company logos, but if I'm going to have any on this car it's going to be TRD. I'm planning on only buying TRD parts in the future for my build.
Old 01-06-2016, 04:30 PM   #66
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Honestly the only way to do it.
Let me know how your cars turn out. Definately dig the TRD parts for this car.
I like things that look oem, some may argue that "TRD products are overpriced" but hey, it's your money and your car why the hell care about what others think
Instagram: trevor.parque
Old 01-06-2016, 07:40 PM   #67
GT86-Ian
GT86-Ian's Avatar
Drives: Toyota GT86
PDF File of translated fitting instructions, well sort of.
http://www.filedropper.com/ms346-18001-2
GT86-Ian is offline   Reply With Quote
Old 01-06-2016, 08:20 PM   #68
weederr33
weederr33's Avatar
I wish I had some english instructions when putting mine on....
Old 05-26-2018, 12:25 AM   #69
Deadline
Drives: Toyota 86
Post English Instructions for the MS346-18001 TRD Aero Stabilizing Cover
I am very late to the game on this thread, but maybe someone else can use the help as well.
I found English language instructions...sort of...it's a decent effort translation:
http://www.billswebspace.com/MS346-18001-2.ja.en.pdf
I have a 2017 Toyotas 86. Perfect fit.
Bottom line, I used 2 of the large spacers (there are two sizes) doubled up. One set in the center, and one each on the sides about 10 cm from the edge of the trunk each. (3 total). Part of the Aero Stabilizer slides under the trunk and the part you see has a bump. I stuck the three spaces onto the stabilizer itself on the vertical bump, standing upright, in order to have consistent spacing from the trunk edge (they are sticky but come off very easily).
Step 1: Open your trunk and clean the glass from the bottom edge to about 3 inches up.
Step 2: Line up the stabilizer with the bottom edge of the glass. Apply the spacers to the stabilizer. Move it out of the way.
Step 3: Wipe down the clean part of the glass that the stabilizer will cover with the included 3M primer wipe. Two are included in the package. You should only need one (if they aren't old or expired). Allow 10 minutes to dry.
Step 4: Close your trunk.
Step 5: Remove about 1-2 inches of the stabilizers glue paper (whatever it's called) starting at the center, moving outward. Leave the 4 paper ends exposed. You will need to be able to pull them off later.
Step 6: Fit the stabilizer into the trunk groove. Make sure the gap on the left and right side is even. Open the trunk slightly while holding the stabilizer in place to make sure it is aligned with the glass in case the spaces aren't lined up properly. (I am a bit paranoid so I triple checked, but it shouldn't be necessary.) Close the trunk completely. The spaces should hold it in place.
Step 7: Double check the left/right spacing to be sure it's even. Press down in the center, on the TRD label, to hold it in place as you remove the 4 strips of paper. I removed the two at the top first, pressed down to make it stick, then the bottom two, and pressing down to make it stick, starting from the center, moving outward on both sides at the same time.
Step 8: Remove the spacers. They should come off effortlessly.
Let it set in overnight.
I hope this helps. The directions, even in English, are not great. It really is simple and maybe I went into too much detail, but you only get one shot at it.
Deadline is offline   Reply With Quote
The Following 5 Users Say Thank You to Deadline For This Useful Post:
Cheeky (08-15-2018), funwheeldrive (06-03-2018), Myriad (05-25-2020), sato (06-02-2018), StraightOuttaCanadaEh (05-26-2018)
Old 05-27-2018, 01:43 PM   #70
ELLSSUU
Drives: FR-S, 951, Venza, Accord, MDX
Anyone have the cheapest place to get this piece?
ELLSSUU is offline   Reply With Quote
AERO Kit for sale (Factory Toyota AERO Kit) GTS86 Exterior Parts (Aero, Lighting, Etc.) 28 02-11-2017 09:34 AM
JDM Toyota Aero Stabilizing Fins - Poll Beyer Subaru Cosmetic Modification (Interior/Exterior/Lighting) 31 05-05-2015 11:42 PM
Toyota aero stabilizing fins (smaller unpainted version) switchlanez Cosmetic Modification (Interior/Exterior/Lighting) 9 04-28-2014 01:07 AM
The cover store car cover for sale. FRSfan111 Northwest 2 06-21-2013 05:49 PM
Under panel to go between factory aero panels - cover exhaust and d-shaft? Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 10-22-2012 08:02 PM
