Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 12-15-2015, 04:27 AM   #29
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Originally Posted by Ryan86 View Post
@86 South Africa
Yes I have the Delicious Tuning Flex Fuel kit Stage 2.
I found best power on E75, dyno attached.
No guess work needed with mixing Ethanol and you can use any fuel available
93,95,98.
Im sure you will be extremely happy with your choice.
Just to clarify... what does stage 2 entail/include?
Obviously the flexfuel + tune, but full exhaust?
I've ordered the headers/OP only because I can't find a sound I like for a reasonable amount of money for the rest of the exhaust.
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-15-2015, 04:56 AM   #30
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
I suggest the following, based on 15 cars we have done and dyno tested in DBN, all producing similar results on various fuels
Good drop in filter - K&N, Blitz, AFE. If you opt for a CAI Takeda or Skunk 2
Header - UEL for mid torque gain, EL more top end power. UEL has best sound
Overpipe - found no improvement, but if combo set won't hurt
Exhaust - BRZ exhaust from Subaru has proved to be very good and Toyota don't seem to give a problem as its supplied by Subaru.
Ryan86 is offline   Reply With Quote
Old 12-15-2015, 06:17 AM   #31
86 South Africa
Thanks will see if I can get a drop in filter.
(OP was part of the header package).
I don't like the sound of the BRZ/Subaru exhaust. Just doesn't do it for me.
Check out youtube... some good info and tests on CAI's - interestingly, they do nothing for power at all. The filter helps, but the 86 has such a good base design they literally didn't find any HP changing the design (not on NA cars anyway)
I like driving!
The Following User Says Thank You to 86 South Africa For This Useful Post:
ShaunWRX (12-15-2015)
Old 12-15-2015, 01:31 PM   #32
ShaunWRX
ShaunWRX's Avatar
Drives: 2014 Toyota 86
Originally Posted by Dammod View Post
We will be releasing a flex fuel kit next year - been testing and refining it for a while now but will "announce" it when we happy to release it to the public.
You know what to do when you're ready to release it
Satin White Pearl 2014 Toyota 86 High
ShaunWRX is offline   Reply With Quote
The Following User Says Thank You to ShaunWRX For This Useful Post:
Dammod (12-17-2015)
Old 12-17-2015, 05:40 AM   #33
Dammod
Dammod's Avatar
Drives: .
Will let you know.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
Old 12-31-2015, 12:25 PM   #34
Rossi
Drives: Toyota 86
Octane Boosters will they give you more power
Agreed, LM is more convenient.
You buy E95 in 25+ L Containers and then you could decanter into a smaller 5L, get to the petrol station, pop the E95 in then fill up so it mixes nicely so not tooo bad.
I would run it permanently if not tuned for the reasons Steve mentioned but the stock ECU is pretty aggressive in detecting knock and retarding timing.
Hi Dammod,
Where do you buy the E95 from?
Thanks
Rossi is offline   Reply With Quote
Old 01-06-2016, 05:12 AM   #35
Dammod
Dammod's Avatar
Drives: .
Originally Posted by Rossi View Post
Hi Dammod,
Thanks
Either Protea Chemicals: http://www.proteachemicals.co.za/
OR
Rolfes Chemicals: http://rolfesza.net/index.php/joomla/content-views
The Following User Says Thank You to Dammod For This Useful Post:
Vic_RSA (01-08-2016)
Old 02-21-2016, 04:15 AM   #36
86 South Africa
I've used rolfes. Good quality ethanol, just a bit of a pain to get cos they're in Germiston.
They only deliver on R5,000+ orders and don't deliver to residential addresses.
Gonna see if protea is more helpful in that regard.
I like driving!
Old 04-06-2016, 03:49 PM   #37
Silver86K
Drives: Silver 86
Howzit,
Lets say I have E95/E5 and want to mix it with 95 what would the best mixing ratio be? And do I just run is with a normal 95 tune?
Silver86K is offline   Reply With Quote
Old 04-07-2016, 03:42 PM   #38
86 South Africa
Originally Posted by Silver86K View Post
Howzit,
Do you have a flexfuel kit or an ethanol tune?
If not it is not a good idea to try and use ethanol in a normally tuned car...
I like driving!
Old 04-07-2016, 06:16 PM   #39
Silver86K
Drives: Silver 86
I have a Ethanol tune
Old 04-08-2016, 06:29 AM   #40
86 South Africa
Then you should try to stick close to the ethanol ratio your car was tuned on. So if it was tuned on e85, then try and keep to similar (there is generally a margin, so it's not like running e70 is going to blow you up, but don't push your luck too much! Most of the US guys tend to run between e60 and e85). Ask the guys who tuned/mapped your car what content they used.
I assume you need to switch maps between e?? tune and normal petrol tune?
I decided it was more worthwhile to just go full flexfuel. It costs more up front, but then I don't need to switch maps or worry about the ethanol content. The bluetooth link tells your phone what ethanol you're running anyway and I can run from 0% right up to 100% which is pretty cool. So far I've run up to e70 and it's awesome
I like driving!
Old 04-09-2016, 06:50 AM   #41
Silver86K
Drives: Silver 86
Thanks for the input, the tune I have is E85, but all I ever see in places selling E95, so is there mixing ratios to achieve E85 from E95 with 95 ron?
Old 04-09-2016, 12:52 PM   #42
86 South Africa
Ah, now I understand.
You could probably run e95, but it's a percentage, so just dilute with normal petrol until you get to 85%
Assuming 100L of fuel, you already have about 5L with e95, so roughly 10L of normal fuel will get you close to e85 (not exactly cos it's mixed into e95, but close enough).
So that's about 5L for every 50L tank.
I like driving!
I give up tahdizzle Scion FR-S / Toyota 86 GT86 General Forum 20 11-07-2014 06:20 PM
What happens when you give an FRS 750 hp. Cjymiller FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 50 08-21-2013 12:19 AM
I give up Ben_G CANADA 26 07-19-2013 11:05 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
Which would you give up? ant08 Scion FR-S / Toyota 86 GT86 General Forum 45 03-31-2012 05:32 AM
