Old 01-05-2016, 02:10 AM   #1
gMit
Drives: Pearl BRZ
Tomei headers - why no cat?
Hi All.
So I've been in the market for some new headers down here in Australia, and the Tomei UEL sounds amazing to me. The only problem is that it is catless.
Laws where I live in Australia are quite strict about emissions and removing cats. It would be most defiantly illegal if I put a set on my BRZ.
So i guess my question is, why has Tomei not released a catted version of their UEL header?
Also, does anyone know of a similar sounding header with a cat?
Cheers!
gMit is offline   Reply With Quote
Old 01-05-2016, 02:37 AM   #2
steve99
Drives: FT86
Originally Posted by gMit View Post
Hi All.
Cheers!
Their is little power gain in these cars with just bolt on bits.
Adding a catted header without a tune any gain will be very small.
Even a catless header without tunes gains are small.
Their are very few catted headers for these cars as gains are less and cost is generally higher due cost of cat.
eg
http://www.ft86speedfactory.com/ft86...l#.Voti89IrKAk
https://jdlautodesign.net/shop/ft86-...length-header/
I believe the fine is big for having No cats at all but if you leave the second cat in system, the one in front pipe you should avoid that problem.
Just be prepared to swap back the stock header for a test.
a good option in australia is the PSR header/ovepipe combo.
http://www.prospeedracing.com.au/pro...scion-frs.html
you going to need a tune or an o2 spacer to stop the P0420 CEL
see the Basic bolt on Mods guide link below
Old 01-05-2016, 10:37 AM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Another thing that I have seen is, due to spacing it would be pretty difficult to get a rumbly uel header to fit a cat in before the overpipe connection, there simply wouldn't be space. All of the catted uel headers really aren't very uel.
Sent from my Glade Air Freshener
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 01-05-2016, 11:39 AM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
OP if you want a need trick to pass a visual inspection (if you guys have those) is to gut your OEM cat. You get almost the same gains as a aftermarket header and it looks OEM. You will get a CEL if you don't tune it and fail smog tests but its free?? Wont be UEL though.
Old 01-05-2016, 02:32 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Cost.
It makes the product more expensive without any gains (other than satisfying a requirement to have a catalytic converter), and without actually being tested by your local smog agency it's pretty useless.
-alex
Old 01-05-2016, 06:46 PM   #6
Ashikabi
Ashikabi's Avatar
Tomei don't give a f*ck. That's why. Jkjk, they are very performance oriented and cats don't meet that standard, and the above mentioned cost. It's illegal here too but unless you have inspections, no one knows
Old 01-05-2016, 07:06 PM   #7
Ammunition
Ammunition's Avatar
Drives: 2014 Scion FR-S
Hi All.
Cheers!
Unfortunately, adding a cat means that the header will be more expensive due to additional material and time in the manufacturing process. Factoring in that, and that a catless header is still (while beneficial) is going to give you minimal gains, it's not surprising that many companies don't invest the time in creating a catted header option to appeal to a small niche that is willing to pay a higher price than that of the catless header, for less gains (although with understandable reason).
Tomei is already priced very competitively for a full titanium set-up, so again the fact that they don't offer a catted version of their header(s) doesn't surprise me. Perhaps you could look into a tune along with a Tomei header to trick the engine from firing any codes? I'm not sure how helpful that would be to you, and I'm going to assume you've already considered this option; technically removing the cat in the header is illegal in most places in the United States as well, but the authorities are probably stricter about that stuff where you are.
JDL has introduced a catted version of their UEL as of last year I believe - personally, I'm looking into this option as well for the sake of eliminating some of the torque dip, while not having to worry about dealing with emissions, etc. I inquired with Jesse at JDL with regards to their catted UEL awhile back, and he told me that the catted version of their UEL will only yield a difference of 5 peak HP at most over that of their uncatted version, so take that for what you will.
Ammunition is offline   Reply With Quote
Old 01-05-2016, 07:14 PM   #8
KendallH
Drives: 2013 FR-S Base, 1997 Jeep Wrangler
You live in Australia. Isn't it almost illegal to even drive a car there now?
KendallH is offline   Reply With Quote
The Following User Says Thank You to KendallH For This Useful Post:
86kahl (01-05-2016)
Old 01-06-2016, 01:07 AM   #9
gMit
Drives: Pearl BRZ
I guess I never thought of it like how you've all been describing it. It makes sense then.
Some say in 5 years time it'l be illegal to drive and only public transport will be available (Joking).
But in all seriousness, I wouldn't be surprised. The way the Governments are ruining driving is astounding.
Tomei Headers with ??? Fritz zozobrado Engine, Exhaust, Transmission 9 01-22-2019 01:50 AM
WTB Tomei EL Headers Kriser Want-To-Buy Requests 1 01-14-2015 05:25 PM
WTB Tomei Type 80, Tomei UEL headers Justin91M Want-To-Buy Requests 1 12-19-2014 12:42 PM
Wtb tomei Uel headers!!! Hmongfrs Want-To-Buy Requests 2 10-27-2014 01:57 PM
