Old 01-04-2016, 02:45 PM   #85
8R6
8R6's Avatar
Drives: FRS
@Ultramaroon 's old torque wrench ......
You see, Ultramaroon, I figure it this way. The old torque wrenches may have lost some of their tension ...... but, we have lost some of our wrenching strength ....... so, I figure it all equals out .....
[picture of hot girl]
i stopped reading this thread after this post.
8R6 is offline   Reply With Quote
The Following 2 Users Say Thank You to 8R6 For This Useful Post:
humfrz (01-04-2016), Ultramaroon (01-04-2016)
Old 01-04-2016, 05:16 PM   #86
Focus, Panda. Just consider it a commercial break.
...or a PSA.
8R6 (01-04-2016), KR-S (01-04-2016)
Old 01-04-2016, 05:19 PM   #87
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by FRSBRZGT86FAN View Post
Actually, the reason why they don't make a valve like this from the factory is because it costs more.
-alex
Old 01-04-2016, 07:30 PM   #88
MrDinkleman
Drives: 2016 Oceanic, "base" model
-alex
True. The factory does not want you tinkering with maintenance so why would they make it easier for you? As a dealer service tech, you put the car on a lift so having a Fumoto valve will only save you what, 30 seconds?
But this discussion about the Fumoto valve did make we think about why nobody makes a remote oil drain kit. That would be even better than the Fumoto valve. Because the flat four engine is so short and sits so far back, it is the most PITA of all my cars for me because I have to slither so far under the car to get access to the drain bolt (which almost cancels out how easy it is to get the oil filter).
So, instead of a drain plug, install a banjo bolt and fitting and a tube or a 90* AN elbow with braided steel line that goes to the front of the car... Hmmm... I wonder if that would work...
MrDinkleman is offline   Reply With Quote
Old 01-05-2016, 12:19 PM   #89
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Well as long as you're going to all that work, you might as well run another line and put an oil cooler on the end. Put a Fumoto valve at the low point near the wheel well, and you can drain the oil by simply turning the wheels hard to one side, and sliding a drain pan behind the wheel.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 01-05-2016, 01:53 PM   #90
G-awesome
Drives: 2015 Firestorm Scion FRS
how much muscle did you put to screw the bolt back on? That's insanely tight to strip the threads off. That has to be double the torque to screw on lug nuts.
Simple solution: fumoto valve! Screw it on once and don't strip the threads off the first time and you'll never worry about stripping off the oil pan bolt ever again!
G-awesome is offline   Reply With Quote
Old 01-07-2016, 02:03 PM   #91
SHIFTEVO
Drives: Lightning Red
Hope it's just the plug and that can be fixed...when I was a rookie I cracked my tranny case because the washer felt off and I didn't notice!
GL
SHIFTEVO is offline   Reply With Quote
Old 05-30-2020, 10:27 PM   #92
sroby
Drives: 2015 Firestorm 08/05/15
That fumoto valve it's so RICE. Why would any one need to drain their oil without tools. Damn honda ricer scrubs ricing up and down the street. Makes me sick. You'd think it was a rice factory or something
Agreed partner. How difficult is it for somebody to get their lazy ass under the car take off the panels use old fashioned hand tools and change the damn oil. Just Damn. They need to learn about the machine underneath them. No way in hell I’d trust the fugimoto valve long term.
sroby is offline   Reply With Quote
Old 05-30-2020, 10:29 PM   #93
sroby
Originally Posted by zberz View Post
These valves look dangerous. I'll stick with a magnetic plug.
Sent from my SGH-T999L using Tapatalk
Agreed thank you somebody besides myself
Old 05-31-2020, 12:19 AM   #94
soundman98
ProCrastinationConsultant
soundman98's Avatar
I love my fumoto valves. And I've barely used them
damage, oil change
FR-Sandwhich: Total or not total? Joshwahhhs Scion FR-S / Toyota 86 GT86 General Forum 51 10-03-2015 08:11 PM
Looking for a set of OEM BRZ DRL Strips s0sl0w Cosmetic Modification (Interior/Exterior/Lighting) 7 04-13-2015 09:18 PM
What headlights to pair with LED strips? l0aded Cosmetic Modification (Interior/Exterior/Lighting) 4 06-24-2014 04:37 PM
Rubber Strips on the top of the car zackcp04 Scion FR-S / Toyota 86 GT86 General Forum 3 05-31-2014 10:44 PM
RGB LED strips help BadLuckZN6 Cosmetic Modification (Interior/Exterior/Lighting) 1 01-21-2014 01:21 PM
