Old 01-01-2016, 10:13 PM   #3375
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Oooh I need info...
Chevron ExtraMile
Location
G & M Oil # 122
13900 Palm Dr./Two Bunch Palms Trail
Desert Hot Springs, CA 92240
Lunatic is offline   Reply With Quote
Old 01-01-2016, 10:59 PM   #3376
wrbrz?
Drives: WRB BRZ
Different (expensive) fuel pump, or hydramat, or both.
An external surge tank was always available, but i DO NOT recommend one in a street car. It is a fire hazard.
Any more info on this set up?
  • Which hydramat is the best fit / size for the stock fuel tank?
  • Which replacement fuel pump is recommended?
  • Are any additional components required to fit the hydramat?
Currently running E85 and at my favourite track (Phillip Island), I have starvation after only 6 laps from a full tank. If I run back to back sessions, I have starvation in pretty much every corner.
I'm trying to avoid going to a surge tank, which seems to be the default option in Australia.
wrbrz? is offline   Reply With Quote
Old 01-02-2016, 02:36 AM   #3377
CSG Mike
CSG Mike's Avatar
- depends on your situation, but we generally recommend the huge one (30x15 or something?)
- Denso
- Magnets
The question is, what is the actual *cause* of your starvation?
Old 01-02-2016, 06:48 AM   #3378
wrbrz?
Drives: WRB BRZ
- Denso
- Magnets
Thanks!
My understanding (based entirely on reading this forum) is that it is caused by the siphon on the left side of the car sucking in air once the fuel has sloshed to the right side.
Should the Hydramat be installed to connect to this siphon?
This makes sense to me, because I only have problems at higher fuel levels (above 3/4's of a tank) at turn 12 of Phillip Island:
Apex speed is around 160km/hr (~100MPH) and I usually experience starvation straightening out at roughy 175km/hr (~110MPH)
You can sort of see it in this video, right before I shift to 5th.
[ame="https://www.youtube.com/watch?v=in_H5UULhqg"]Phillip Island - 2015 10 30 - Fuel starvation issues Subaru BRZ - YouTube[/ame]
If this will solve the problem, I will go ahead and order everything.
Old 01-02-2016, 09:19 PM   #3379
CSG Mike
CSG Mike's Avatar
Thanks!
It sounds to me like you have a different issue; at 3/4 of a tank, even turning the car sideways completely, would not starve the pickup.
Are you NA? What fuel pump are you on?
Old 01-03-2016, 12:41 AM   #3380
wrbrz?
Drives: WRB BRZ
I find it very odd too.
All stock fuel pump, running E85 and NA. Running either NT01's or Hankook Z221 mediums.
There are at least two others who are reporting the same problem.
My thought was that 3/4 tank was the point where there is just enough room for the fuel to move away from the pickup for a second, to take in a little air.
I haven't opened my fuel tank to know how true that is though.
Could it be that E85 is too much for the stock fuel pump in these conditions?
Old 01-03-2016, 09:32 PM   #3381
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Did CSG release their tire results? The last time I was on track my PSS were getting greasy half way through 25 minute sessions and I'm trying to decide what to use for a dedicated HPDE set with a bit of autocross duty
the new guy is offline   Reply With Quote
Old 01-04-2016, 01:02 AM   #3382
uncivilised
Drives: 86 GT
I am one of these people. It got to the point that I was only getting 2 laps from a full tank around winton raceway.
Left corners only, Right corners are cherry so I cant see the pump being the issue. It gets worse when i step up from z222 RS3s to z221 TD softs.
I even ghetto rigged a second fuel pump on the siphon side of the tank to force fuel into the siphon hose to fill the cup where the original pump sits. (this was all in the tank. nothing external)
This seemed to work for one session then had the same issue again on the next few sessions. (probably the ghetto setup)
I have been speaking to people who have made something but no exact details yet. I wont be doing any more track days unless this issue is fixed.
example video
the hydromat idea on the siphon side makes sense though. may give that a try if other avenues don't work out.
uncivilised is offline   Reply With Quote
Old 01-04-2016, 04:59 AM   #3383
CSG Mike
CSG Mike's Avatar
? Tire results for?
While we're always running different tires, it's not for the expressed purpose of comparison to determine a "best" tire. Most tires have an ideal circumstance, that doesn't always suit everyone's needs/preferences/style/etc.
Old 01-04-2016, 05:01 AM   #3384
CSG Mike
CSG Mike's Avatar
The strange part to me, is that on long extended lefts with boosted cars, that are on gas, we don't have this issue, and the rate of consumption is approximately similar, if not higher, on the boosted car.
Have you ever logged fuel pressures?
Old 01-06-2016, 05:19 AM   #3385
wrbrz?
Drives: WRB BRZ
I wish I could. I don't know if it's possible with an openflash tablet, or without a separate sensor.
Although I can't imagine it would shown anything other than the fuel pressure dropping, considering how much worse the same symptom gets as the fuel level gets lower.
Just speculation though without data.
Old 01-06-2016, 08:44 AM   #3386
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Anyone recall the location of a thread that did a oil viscosity vs oil pressure comparison? I want to say it was by CSG, GSpeed or Velox.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 01-06-2016, 09:58 AM   #3387
DarkSunrise
DarkSunrise's Avatar
You're probably looking for this thread:
http://www.ft86club.com/forums/showthread.php?t=91820
2022 BRZ Build
2013 FR-S Build
Old 01-06-2016, 01:45 PM   #3388
Bramick
Bramick's Avatar
That's it.. Thanks
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
