Drives: Toyota 86
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open
Hi All,
Was driving yesterday, and my CEL came on, I did drive hard, 1-3 rd gear changing at 7000rpm and then the light came on, I went home, pulled the code with my ELM and got this: "CEL P0351 Ignition Coil "A" Primary Control Circuit/Open" Anyone else have this experience? I have been going through some posts on the FT86 Forum regarding this, I cleared the code and did 2 trips today but didn't push the car past 4000rpm. No CEL if it does come up again I'm going straight to the dealer. I have been reading some guys are saying they get the code once they hit 7000rpm in 3rd/4th gear. Car has 67000kms on it, no previous issues in the last 3 years of owning it at all. Stock ECU Tune as well. Car is 100% stock other then a exhaust and a drop in filter. Thanks |
#2 |
Platinum Member
Drives: Toyota 86 Vortech SC
I don't know what the CEL is, but it sounds like an ignition coil problem which shouldn't be a big issue.
However, I can put your conscience at rest and assure you that hitting 7000rpm in 3rd/4th gear is not a problem. Our cars aren't made of glass... My quick sums tell me that my car's been beyond 7000rpm in 3rd/4th about nine thousand times. That's about 1000 laps on racetracks @ 6x per lap = 6000, plus (say) 3/4 times every time I drive it (5 times/week) for 3 years = 2800
#3 | |
Drives: Toyota 86 - Charcoal Grey
Ever since driving this car I find myself red-lining other cars more often too :/. When I rented a bakkie to move furniture, the thing was so damn slow that red-lining was the only way to get it around. So our cars aren't made of glass, but would you say driving an Etios the same way every day is a good way to get the engine to blow up? |
The Following User Says Thank You to LostSalad For This Useful Post: | Rossi (01-02-2016) |
#4 | |
Drives: Toyota 86
Hi, Thanks for the response, yeah no I am not afraid to push the car hard, I have heard this engine is one of the strongest Subaru have built in terms of not being "like glass", I drive the car hard on a frequent basis and haven't had any problems ever until now. Some of the posts I have read have said that when this code comes up and is cleared it comes back when passing 7000+rpm, so will put it to the test and see how it goes. I have cleared it and if it comes back will take it straight to Toyota! PS your car is a machine! |
The Following User Says Thank You to Rossi For This Useful Post: | Fish Eagle (01-02-2016) |
#5 |
Thanks
Just replace the coil pack.
Not sure what warranty you got out there but it's under the bumper to bumper, not the powertrain. Over here I think I paid ~$90 USD for the part. But I had to buy a small 1/4" ratchet to fit and get to it.
#6 | |
Platinum Member
![]() More seriously, I think modern engines are very robust, but also very delicate. They need good care, good fluids, and respect like never revving a cold engine - then yep, I think they can do that. But don't ask me for my engineering degree - I got that at the Capt Morgan school ![]()
#7 | |
Drives: FT86
But has been known to be ditry connector at coil pack or bad spark plug. Unlikely its injector seal as you usually get firecracker poping at intake. You could probably do coil pack yourself if its out of warantee. Leave the cel active if you take it to toyota. If you do take it to toyota make sure they update your ecu calid to latest for your car Will likely be ZA1JA01G , i dont think you guys got A02G but it is compatable with 2012 cars.Anything older like 700G 900G or A01G did not have the transient ingnition retard enabled, can contribute to di seal fail |
The Following User Says Thank You to steve99 For This Useful Post: | JouMaSeHoes (01-12-2016) |
#8 | |
Drives: Toyota 86
I agree completely on the fact that they need good care and good fluids! If you look after it, it will remain happy. |
#9 | |
Drives: Toyota 86
I will monitor it and see what happens! Car is sounding fine, drives fine and no cel again, I did push it to 7400 rpm in 1st/2nd and 3rd about twice and nothing came up. Maybe just a bad connector? When my car went for a service just after I got it they did a software upgrade and I am sure I got the new cal ID. Thanks for all the help guys! |
#10 | |
Drives: FT86
#11 | |
Drives: Toyota 86
Would you suggest I take it to Toyota and get it sorted straight away? I did clear the code unfortunately, my car is just daily driver, I don't track it at all |
#12 | |
Drives: FT86
Most of the scanners will clear current and stored codes so their will be no record for service techs. |
#14 |
Drives: Toyota 86
I had exactly the same problem 3 weeks ago...took off and as the engine reached 7000 rpm the engine managment light came on.
I picked the same code but did not clear it. Took it to Toyota and they ordered a new coil after viewing the fault. part is on back order and will arrive mid January. They cleared the code and it has not come back again. |
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open | romin | Engine, Exhaust, Transmission | 468 | 11-26-2021 04:05 PM |
Has anyone resolved their ignition coil CEL issues? (P0351, P0352, etc.) | edward | Issues | Warranty | Recalls / TSB | 41 | 11-06-2017 07:48 AM |
Open "power with key" slot in fuse box | Ashikabi | Electronics | Audio | NAV | Infotainment | 0 | 09-15-2015 10:52 PM |
Turbo "cooldown" before ignition off? | gdrider77 | Forced Induction | 32 | 04-01-2014 01:26 AM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
