Old 01-02-2016, 09:40 PM   #15
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Originally Posted by xFury View Post
Well, a good practice to do is to clean the area first before installing. Just did mine recently and noticed that it had a lot of crap around the stock gasket and the socket that hold the unit.
Clean it out with some tissue and water to make sure I got out all the dust, sand, etc. and I use tighten it enough to were I can't move it anymore with pressure.
It's not just about the crap. It's the gasket themselves. Valenti cheaped out on that part for some reason.
I compared the gasket from OEM to Valenti and it's half of what OEM is and it's thin.
What I did to solve my condensation issues and eventually water issue is to take the gasket from the OEM and "doubled up". Haven't had an issue since.
YamahaR86 is offline   Reply With Quote
Old 01-03-2016, 06:05 PM   #16
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
Good point. When I compared the Valenti I got a few weeks back, the Gasket looks a tad bit bigger than the OEM gasket. Maybe they came out with a 2nd version or something with a "Better" gasket.
Hopefully it doesn't leak or condense, or Might have to look into Ninja Gasket.
xFury is offline   Reply With Quote
Old 01-03-2016, 07:13 PM   #17
PNW FRS
PNW FRS's Avatar
No problem with my Valentis...
Not one occurrence of condensation with my Valenti tail lights... and I'm in the PNW. That said, my rig is garaged at night so maybe that is the difference; no constant exposure to moisture.
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 01-03-2016, 07:33 PM   #18
Irace86
Drives: BRZ + Ducati M796
Back in the day my headlights on my Toyota had a hole in the back that had a cut-off curved-down rubber hose. I dont know why but they were never 100% sealed because of that hose. Hazing with time and mild condensation during certain times of the year was normal.
Irace86 is offline   Reply With Quote
Old 01-04-2016, 01:35 AM   #19
Babel
Babel's Avatar
Drives: 2015 BLACK BRZ
Two months with mine and no issue. Mine came with gaskets bigger than OEM.
Babel is offline   Reply With Quote
Old 12-06-2017, 09:48 PM   #20
Daver
Thread Necro!
I have condensation in only one of my Valentis. I feel like I have tightened them both down equally, just hand tightened. Unsure why I got it on one side. I’d like to first get the condensation out, without removing the taillight (because I soldered in the 3rd brake light and modded the flasher, my first time soldering and I don’t think I’ll have enough slack if I cut out and solder again, nit to mention I shrink wrapped and then taped the shit out of it for a good clean install)
can’t even remember the overseas site I bought from to try a return.
Anyone have an idea on how I could get it out of these, AND how to prevent again? I tried packing damp rid In the back of the cavity to no avail. Wondering about a hair dryer or even a dehumidifier in my trunk. The car will be sitting in dry garage over the winter so maybe it will get better? But I’d still like to prevent again.
Th and y’all!
Daver is offline   Reply With Quote
Old 12-07-2017, 07:12 PM   #21
RickyBobby
Drives: 2013 Firestorm FR-S AT
I think the main reason for condensation in the Valenti tail lights is that the bolts are not torqued properly. They should be hand tightened and then torqued to 39 in.lb. I have had mine on ~1 1/2 years with no water leaks or condensation.
Installation instructions:
http://www.ft86club.com/forums/showp...ostcount=14623
RickyBobby is offline   Reply With Quote
Old 12-08-2017, 01:15 AM   #22
Poodles
Drives: 2015 Series.Blue
Keep in mind that 39in/lbs is actually far looser than normal hand tight from a ratchet!
Old 12-08-2017, 08:06 AM   #23
RickyBobby
Actually it's not. I was surprised after I hand tightened the bolts to what I would consider tight enough how many more turns it took to get to 39 in.lb of torque.
Old 12-08-2017, 03:48 PM   #24
Daver
OK, Thanks guys. Im going to check the torque, any thoughts on if the condensation will clear out of there while it sits a couple months in the dry garage? Or am I stuck taking em off and Drying out?
Old 12-09-2017, 12:53 AM   #25
Poodles
Doubt that as 39in/lbs is a little over 3 ft lbs. Most 3/8 drive ratchets are over 6 inches long, so under 6 lbs or pressure on the ratchet would be tight.
39in/lbs is attainable with a screwdriver...
If they're over torqued, they may have damaged the gaskets and/or bent the metal that the studs go through. There was a TSB on how to fix them somewhere...
Old 12-09-2017, 08:18 PM   #26
dvniemela
dvniemela's Avatar
If you have a spare oven or know of someone with an oven they don't bake in, you can place the tail lights in there on a low temp for 10ish minutes and it will remove all condensation.
dvniemela is offline   Reply With Quote
Old 12-10-2017, 10:16 AM   #27
RickyBobby
OP,
Google is your friend. https://www.google.com/search?q=how+...hrome&ie=UTF-8
Old 12-14-2017, 02:20 AM   #28
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
I have owned just about every brand tail light for our platform except for Intec, Valenti Revo V2, and Buddyclub. and each of them had either condensation or a problem with the plastic warping (Tom's clear lens). The only way I fixed the condensation was buying the new foam gaskets from the 2016 model, and then putting molding clay where the tail light meets the trunk on the inside of the trunk. Running Valenti for 1 year and 1/2 now and no problems so far.
Instagram: @battleship_86
It's more than a hobby it's a lifestyle.
KungFuWaffle is offline   Reply With Quote
Valenti Taillights!!! husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 11-07-2013 11:56 AM
Changing color of Valenti taillights Harmsy Cosmetic Modification (Interior/Exterior/Lighting) 1 09-22-2013 08:48 PM
WTB Valenti Taillights ASAP Froylavin Exterior Parts (Aero, Lighting, Etc.) 0 08-03-2013 05:10 AM
Valenti Red Chrome Taillights MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 1 07-29-2013 08:22 PM
Condensation in taillights are covered under warrenty cjdriiiiift Northwest 1 10-24-2012 10:40 PM
