Old 01-01-2016, 05:31 PM   #1723
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Astroboy View Post
I really need your help with an issue I'm having. You see, I recently installed my clutch by myself, and now, i hear a gear grinding noise Every time I decelerate is this normal?
Sent from my LG-D850 using Tapatalk
Like when you let off the gas?
Is there any way to get a vid of the noise?
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 01-01-2016, 05:32 PM   #1724
Astroboy
Astroboy's Avatar
Drives: None
Yes when I let off the gas. There's a video of an s2000 on YouTube that sounds like the issue I'm having. I'll post it here if I can right now.
Astroboy is offline   Reply With Quote
Old 01-01-2016, 05:34 PM   #1725
Astroboy
Astroboy's Avatar
Drives: None
Here it is.
Old 01-01-2016, 05:46 PM   #1726
protpibe
protpibe's Avatar
I can't really tell from that video. Mine doesn't rattle on deceleration , only at idle when the ac kicks in and the idle drops.
Did you Lube the spline shaft properly?
The Following User Says Thank You to protpibe For This Useful Post:
Astroboy (01-01-2016)
Old 01-01-2016, 05:49 PM   #1727
Astroboy
Astroboy's Avatar
Drives: None
Yes, minimal as stated
Old 01-01-2016, 05:55 PM   #1728
Astroboy
Astroboy's Avatar
Drives: None
I can upload a video tomorrow I
When I take it to work. I'll upload it around 9am. I torqued it to spec. I did try to resurface the oem flywheel with a dermal type machine that is used for sanding and such... I don't know if the sound is normal or if I really did fuck up.. 😔
Old 01-01-2016, 08:51 PM   #1729
Astroboy
Astroboy's Avatar
Drives: None
Could it be the fluid I put in the transmission? I used 75w90 mobil 1 LS fluid just to get it started and see if it works. The guy working at the autozone I bought it from said that manual transmissions can take the LS fluid.
Old 01-01-2016, 08:58 PM   #1730
protpibe
protpibe's Avatar
[tQUOTE=Astroboy;2496135]Could it be the fluid I put in the transmission? I used 75w90 mobil 1 LS fluid just to get it started and see if it works. The guy working at the autozone I bought it from said that manual transmissions can take the LS fluid.
Sent from my LG-D850 using Tapatalk[/QUOTE]
Without hearing it, it's hard to say for sure, but I would definitely consider that fluid a possibility. I'm not sure what the difference is in a fluid meant for a limited slip differential, but I'm not sure what that guy was thinking in recommending it lol.
Old 01-01-2016, 09:00 PM   #1731
Astroboy
Astroboy's Avatar
Drives: None
Without hearing it, it's hard to say for sure, but I would definitely consider that fluid a possibility. I'm not sure what the difference is in a fluid meant for a limited slip differential, but I'm not sure what that guy was thinking in recommending it lol.[/QUOTE]
Autozone workers... You know them.
Old 01-02-2016, 08:15 PM   #1732
Astroboy
Astroboy's Avatar
Drives: None
Here it is protpibe. You here it good only two times, right in the beginning.
Old 01-29-2016, 03:51 PM   #1733
solus
Drives: 2014 Scion FRS (Ultramarine)
Just want to say I hit 15k miles on this kit the other day... no issues.
8PSI daily, E85 flexfuel, OEM fuel injectors, DW300c pump. AVO oil cooler and breather tank. 2.5 OP and Catted front pipe, perrin 3' catback, and Turbosmart BOV.
solus is offline   Reply With Quote
The Following 4 Users Say Thank You to solus For This Useful Post:
bumppinKota (01-31-2016), Draco_PR23 (02-05-2016), Jonde875 (02-02-2016), MisterSheep (02-05-2016)
Old 02-05-2016, 06:27 PM   #1734
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Been considering getting a turbo kit for my car for some time. Looks like this one has the boost levels I am going for on the stock tune (7psi) been cross shopping this kit with the SBD kit just because this kit may seem to be a little more reliable than the SBD kit? I've been looking at the SBD because of the 3k price tag. But If I can get something that runs a little less boost for more reliability I'm okay with waiting and paying more.
Been following this thread for awhile and all of you guys seem to be loving your kits. Just looking in the long run who's racked up the most miles and how many people have had catastrophic failures?
Instagram: trevor.parque
Old 02-07-2016, 11:51 PM   #1735
Astroboy
Astroboy's Avatar
Drives: None
Anybody got p0171? I recently had to change my ecu because I had the dreaded p0018 code. Drove my car 100 miles with not a single light came on, and then out of the blue I get the TCL and CEL pop up again. I thought it was the p0018 again and was about to lose it. Then I realized it was p0171 so i don't know whether to feel relief or not. Any suggestions? Last mod I did was a clutch swap
Old 02-08-2016, 12:27 AM   #1736
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Are you heat wrapped or coated headers and over pipe?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 01:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 05:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
