Old 01-01-2016, 03:37 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Aftermarket Headlight Peeling
I had replaced my headlights with after market ones (Spec-D) 6 months ago. The headlights started to slowly lose it's UV coating and peel. I did some research on the issue and apparently it's pretty common for aftermarket.
OEM does peel eventually but it takes longer, even "brand name" headlights like Spyder does it as well.
It's pretty embarrassing every time I looked at it and considered replacing the lens with OEM ones. I found a couple of threads saying to use the "Headlight restorer kit" and I finally had some time off this week to do it. It pretty much involves sanding, polishing, and last is to apply a new UV clear coat.
Can see the results below and I'm happy about it.
YamahaR86 is offline   Reply With Quote
The Following User Says Thank You to YamahaR86 For This Useful Post:
go_a_way1 (01-01-2016)
Old 01-01-2016, 03:53 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I will most definitely be doing this in the spring. What kit did yoy buy?? My headlights are peeling too haha. Thanks for sharing
Old 01-01-2016, 04:32 PM   #3
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I went with the [ame="http://www.amazon.com/gp/product/B00429NKWK/"]Sylvania 46135387715SYLVANIA Headlight Restoration Kit[/ame] for $20
Really easy to follow as I've never done this sort of thing before. Kit includes everything and I got it because it was recommended and it has an included UV Clear Coat that other kits don't.
Steps are tape, prep with the spray, wet sand with 400 grit, 1000 grit, 2000 grit, hand polish with the liquid, prep and then clear coat it.
Took me a few hours because I wanted to be thorough but I think it doesn't take long since it's mostly for the hazy/yellow headlights and ours are just peeling the old UV coat.
Old 01-01-2016, 06:10 PM   #4
_gt86_user
Inactive
Drives: .
They will keep peeling, even more so when you continually polish them the lens they use are not the best..never had them but worked there for years so I would see all the defects and even the ones that worked well always peeled pretty quick even if the car was garaged.
_gt86_user is offline   Reply With Quote
Old 04-19-2017, 09:46 PM   #5
Hawker271
Drives: Scion FR-S 2013
How is it holding up! Mine are peeling so bad too. What's the worst that could happen if they keep peeling
Hawker271 is offline   Reply With Quote
Old 04-20-2017, 08:12 AM   #6
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Prepare to repeat this step every 4 months.
If you can take them to a shop to get them clear-coated it will last much longer.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-16-2021, 05:37 PM   #7
Jasper
Jasper's Avatar
Drives: 2023 GR86
Tip: 2K Clear Coat is what shops/manufacturers use.
Jasper is offline   Reply With Quote
The Following 2 Users Say Thank You to Jasper For This Useful Post:
Israel Moore (04-20-2021), RToyo86 (04-20-2021)
Old 04-20-2021, 03:53 PM   #8
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
my winjets became quite yellow in 2 years and that was after restoring them myself a couple of times after which I've just given up lol so yep it won't be long especially if you live in a sunny state. I would pay extra for aftermarket ones if they came with glass covers lol..but then again considering how many windshields i've gone through, maybe that isn't such a a great idea xD
HKz is offline   Reply With Quote
Old 04-20-2021, 04:08 PM   #9
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
+1 for 2k. For a high impact zone 1k clear sucks. It's way to soft and will get peppered by debris and look like crap quickly.
RToyo86 is online now   Reply With Quote
Old 04-21-2021, 11:12 PM   #10
Decep
Drives: 2013 FR-S Series 10
Coat them and maybe PPF them.
I just applied Cerakote ceramic coating to my OEM ones, see how it holds up. I wish i'd have done PPF but by the time i'd bought my car it was 3 years old anyways.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
OEM Wheels are peeling Bevans555 Issues | Warranty | Recalls / TSB 23 08-24-2017 02:04 PM
Steering wheel peeling teamturbo Issues | Warranty | Recalls / TSB 44 09-06-2014 05:50 PM
Steering wheel peeling? ikeryder13 Issues | Warranty | Recalls / TSB 2 07-24-2014 12:44 PM
Mirror peeling SubaSteve Issues | Warranty | Recalls / TSB 3 11-16-2013 11:25 PM
Anyone else experience paint peeling? euroshowoff Issues | Warranty | Recalls / TSB 9 08-23-2013 11:39 AM
