| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: '06 Cayman, ‘23 BRZ Sport-Tech
720Form GTF1 17x8.0 +35
720Form GTF1 17x8.0 +35, 15.5lbs, Michelin Pilot Super Sport 225/45-17, aluminum lug nuts & hubcentric rings.
I've never been a big fan of black rims on a white car because they never come out well in photos. These ones look better in real life, with the accents machined into the sides of the spokes. |
#2 |
#3 |
I spent a lot of time thinking about what wheels and tires to get. I don't track the car and so balance and feel are more important to me than ultimate grip. I really wanted a lightweight wheel and tire package without breaking the bank. I was really tempted by the Continental ExtremeContact DW because they are light and I could go wider for the same weight. The 17x9 rims weigh a pound more but the 245 CECs area pound lighter (on paper) than the 225 MPSS. In the end, I decided to keep things relatively narrow, only 10mm wider than stock. I really like the combination. With the +35 offset, the steering is a bit heavier than stock but I think the feel is even better and it still doesn't tramline. It has much better grip than stock but it still has that throttle adjustable balance. Weight is down by ~3.3 lb per corner and even with the stiffer sidewalls the ride is no worse than stock. They sure are noisy though!
#4 |
Drives: 2014 Subaru BRZ LTD 6MT
Honestly, those MPSS, from what I understand, run pretty wide. Probably nearer to a 235. So you got some good grip. So close to buying these wheels.
Stock suspension? And are the hubcentrics necessary, or just make things easier? |
#5 | |
The hubcentric rings are necessary. I had aftermarket rims on my old Intergra without them and I always had a lot of vibration. The rings are cheap and easy, so just get them. I think the GTF1s are a great value for a light wheel. The MPSS have been great so far, wet and dry, except for the day it snowed a bit. I was a bit ambitious and put them on a week too soon! |
| The Following User Says Thank You to Talus1 For This Useful Post: | ajaxthebetter (05-21-2015) |
#6 |
Drives: 14 FRS Whiteout
What size tire are you running?
#7 |
First post
#8 |
Not a troll
I'm super stoked for mine to come in. Unfortunately, stock is so scarce, the shop I ordered from could only guarantee to be able to get two wheels in and said "We'll see about getting the other two".
| The Following User Says Thank You to Cole For This Useful Post: | D_Thissen (01-01-2016) |
#9 |
#10 |
Hahaha! No worries, we will just say you're hung over from New Years.
#11 |
As I recall, the 17x8 GTF1s were out of stock at 1010Tire last fall/winter as well. I ordered mine from them in the spring and got them from the Toronto warehouse in just a couple of days. It was painless, except having to deal with Purolator.
Anything worth doing is worth doing twice...
| 720Form GTF2 18x9 +35 | Canehda | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 07-18-2016 01:25 PM |
| WTB: 720Form GTF1 or GTF2 wheels | sachu | Want-To-Buy Requests | 1 | 02-27-2015 12:49 PM |
| WTB: 720Form GTF1 or GTF2 or Rota Titan | sachu | Want-To-Buy Requests | 0 | 02-26-2015 08:11 PM |
| 17x9 +35 720Form GTF1 installed! | BRZZZZZZZZZZ | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 06-27-2014 07:12 PM |
| XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop | AGM6789 | AUSTRALIA | 17 | 11-10-2012 05:10 AM |
