Old 12-31-2015, 11:31 AM   #197
ajc209
Drives: GT86 Cosworth
Originally Posted by JerryIII View Post
Same boat here lowered the compression 10:1 forged internals ect. And also had Sharif tune mine would also like to get more power then .1 bar but is is a start
Presumably your losing some power on the lower compression with just the stage 2 pulley too.
if you have injectors and fuel pump to suit i'd get a new crank pulley engineered to boost it to 350hp and call it a day.
Obviously its untested territory though.....
Sent from my GT-I9300 using Tapatalk
ajc209 is offline   Reply With Quote
Old 12-31-2015, 11:38 AM   #198
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Originally Posted by weederr33 View Post
Woah, that's interesting. Essentially instead of a smaller SC pulley, we'd upgrade the crank pulley? So with the 10% smaller pulley, would larger injectors and and upgraded fuel pump be required?
my current plan is to go smaller on the SC pulley by 10% in addition to replacing the crank pulley with something about 5-7% larger which will roughly make a 3:1 ratio on the SC to crank
the slight increase in crank pulley should mean no need to change the other drives
and with just the 10% pulley on its own there's no need to uprate the injectors or fuel pump or change the tune although it probably can't go much further
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (12-31-2015)
Old 12-31-2015, 11:42 AM   #199
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I feel as though 320-330 would be the perfect medium for this car. Any more power and it would be a bit silly.
MS, CSCS, TSAC-F, CPT
Old 12-31-2015, 12:52 PM   #200
ajc209
So thats spinning the sc at about 22k rpm. Thats about 290 ish whp?
I think alot of people will be tempted to run that on stock internals.
Do you have any idea how long the stock rods would last at that power or is it a case of how long is a piece of string.
Old 12-31-2015, 02:16 PM   #201
Matt@Cosworth
the trouble with the stock sintered rod is they are a complete lottery, they are essentially a big mass of cracks just waiting to happen and the extra load can push them into the dangerous part of the SN (fatigue life) curve so they could last 10,000 more cycles or 1000,0000 more cycles
unlike a proper material you cannot predict the fatigue point with any great accuracy
which is why we settled on the cylinder pressure figure we did
Old 12-31-2015, 02:28 PM   #202
Matt@Cosworth
I'd agree with that as after this point you're into breaking drive-shafts, transmissions etc
well I say that now,
whats the saying ; power corrupts ? and absolute power corrupts absolutely
I remember when I had my TVR Cerbera ( 350Bhp) that seemed very rapid for about 3 weeks and you then get used to it and start feeling ' I could do with a bit more'.......
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
killboy (01-03-2016), weederr33 (12-31-2015)
Old 12-31-2015, 02:32 PM   #203
weederr33
weederr33's Avatar
Haha! That is very true. Of course, I'm pretty comfortable with the 280 right now. It is a happy medium for me.
Old 12-31-2015, 03:11 PM   #204
ajc209
At least with the sc its quicker than the average diesel exec.
I have to admit, 330hp seems a bit low if im going to the effort and expense of adding uprated internals though.
No hope of a pulley kit offering the full power the sc is capable of?
Old 12-31-2015, 05:08 PM   #205
CSG Mike
CSG Mike's Avatar
There's a little knob cast in the block that's in the way... are you shaving it off?
Old 12-31-2015, 05:16 PM   #206
ajc209
Happy New Year Folks! I'm sure ill be too drunk to post in 2 hours time..
The Following User Says Thank You to ajc209 For This Useful Post:
Freeman (12-31-2015)
Old 12-31-2015, 06:01 PM   #207
weederr33
weederr33's Avatar
It may seem a bit lack luster, but for me, the internals would just help the longevity. But still give you the opportunity to upgrade as needed. Maybe twincharge the engine? haha
Old 12-31-2015, 07:50 PM   #208
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
I would also be interested in the smaller pulley, but ideally would want the internals as well for peace of mind.
muckypuppy is offline   Reply With Quote
Old 01-01-2016, 06:18 AM   #209
Matt@Cosworth
thanks for the heads up, I'll check if its removal is required
Old 01-01-2016, 10:53 AM   #210
Adam (NoVA)
Drives: 2015 WR Blue BRZ
That's why we often refer to boost as the dark side
Adam (NoVA) is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 02:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 11:26 AM
