#32327 | |
Hit the road and I'm gone
Even having accurate dB levels won't tell the whole story, though, because the frequency spectrum also determines at least some of the quality. That is why "fart cans" are so annoying; they emphasize one frequency at the expense of everything else. The speaker industry does something very close to what you're describing, measuring dB's at a specific distance under a specific set of repeatable conditions (anechoic chamber, set power input level), etc. Frequency response is also taken. In the case of speakers, there is also the use of a Fast Fourier Transform to gain information in the time dimension, but it would not be necessary for this idea. Ideally, you'd want a standard temp (27C) for the test, but it should have minimal impact on the dB rating of a muffler! Just not in the snow, as it will MUFFLE the sound to a certain degree. I'm talking to you now, Tcoat. If you are in a quiet area, outdoors, you can probably ignore any background noise as sound decreases in intensity at the square of the distance. The volume of the muffler simply will swamp any background noise.The data could be presented as dB at a specified distance (1 meter is used a lot for loudspeakers but that won't work with a dual exhaust...) and an averaged frequency response curve. Two sets of measurements could be used; dB/freq spectrum at idle and peak dB in neutral. Several vrooms at idle could be collected and the peak volume found. You could also have an average volume at peak throttle or a set RMP (5000?). Getting all the various exhaust combinations together for measurement is the big problem. Seriously, guys, if you want to do this sort of measurement, I pretty much know exactly how it can be done. I also know about several audio-related software tools that could help capture and make sense of the data. All you would need is a laptop, the appropriate software and a calibrated microphone (and these are getting cheaper all the time). Is the goal to avoid getting pulled over by the CHiPs, or is it to have the loudest possible exhaust system?
Slip, slidin' away.
![]() Last edited by babydriver; 12-30-2015 at 01:24 PM. |
| The Following User Says Thank You to babydriver For This Useful Post: | jawn (12-30-2015) |
#32328 | |
Slip, slidin' away.
| The Following User Says Thank You to babydriver For This Useful Post: | Tectoniic (12-30-2015) |
#32329 |
Drives: 2013 Pearl White 6MT
Hmmm
My ass hurts from doing weighted lunges and duck walks |
#32330 | |
You guys are way over thinking this. We are not looking at fine tuning the placement of high fidelity speakers here just a close enough reading of an exhaust. Although I can see that this project is doomed from the start I will do up MY findings and post them. I will not however, debate my methodology or results as they are what they are and I am satisfied they are as accurate as possible in a non controlled setting.
#32331 |
That's fair, but I hope you'll state the methodology along with the results.
Slip, slidin' away.
#32332 |
Will provide the complete methodology but like I said will not debate it's merit or short comings. I did a lot of prep to try and find a easy method that anybody could do (with the understanding it is not controlled) since I know that everybody else does not have access to the $10K worth of test equipment I do.
#32333 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Special_K (12-30-2015) |
#32334 |
It'd be kinda hard to breathe, though.
#32335 |
Drives: 2014 Scion FRS
have a Store meeting in the next 45 minutes
finding out with we are closing down shop or if the company is being sold off should be interesting |
| The Following User Says Thank You to WhiteFRS69 For This Useful Post: | MisterSheep (12-30-2015) |
#32336 |
Drives: 2015 CWP BRZ Limited
| The Following 2 Users Say Thank You to jawn For This Useful Post: | Tcoat (12-30-2015), Ultramaroon (12-30-2015) |
#32337 | |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
| The Following 2 Users Say Thank You to MisterSheep For This Useful Post: | Tcoat (12-30-2015), WhiteFRS69 (12-30-2015) |
#32338 | |
Drives: 2014 Monogram Raven
Black is not a color, it's a part time job!
#32339 |
#32340 |
In space, no one can hear your muffler scream.
Slip, slidin' away.
| The Following 3 Users Say Thank You to babydriver For This Useful Post: |
| h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) — General Topics | 53 | 11-21-2014 11:46 PM |
| Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
| random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
| The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
