#239 |
Drives: 2015 FR-S Release Series 1.0
Hi, I will be installing this kit on my FR-S soon and will be running it with an Openflash UEL header, quad tip TRD cat-back, and Maxflow BOV on 93 octane pump gas.
My goals for the tune are 250hp/200lb-ft torque and I will running the 3.48" pulley. Will I be able to reach these numbers on the stock fuel system? I will not be running e85. Also does anyone know if the stock fuel system will be able to handle the 3.125" pulley on 93? |
#240 | |
Thupercharged
I would skip the maxflow bypass valve, mine is sitting on a bench quietly 3.125" pulley on 93 is fun, I am currently running it
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#241 | |
Drives: 1992 Nissan Skyline GTS-t Type-M
Doing pump, rails, injectors w/e85 in the spring |
#242 |
Drives: 2013 Firestorm FRS
We've got an FRS in the shop with the Vortech being installed! I'll have some photos up in a bit
#243 |
Drives: 13 BRZ Limited WRB
I am on Vortech - been about 10k now.
On my 2nd motor, after a bad tune last year detonated and bent a rod. These are my details - -Engine & Drivetrain- Vortech Supercharger Kit Gates Serpentine Belt Open Flash Tablet Vortech S/C Tune Perrin Oil Cooler Perrin Radiator Hoses Mishimoto Radiator Radium Dual Catch Can Kit Open Flash Tablet UEL Header P&L Overpipe P&L Catted front pipe Perrin 3.0" Cat-back Exhaust (Resonated) Perrin Crank Shaft Pulley Perrin Lightweight Accessory Pulley Kit Driveshaft Shop Aluminum Driveshaft MTEC Shifter Springs Nameless Performance Engine and Pulley Covers - Custom Subaru Logo Engraved Painted all fluid caps WRB (former) P&L Catless Header (former) EcuTek with Perrin NA Tune (former) EcuTek with Perrin Vortech Tune (former) Perrin Inlet Tube (former) Perrin Cold Air Intake (former) K&N Air Filter -Chassis & Suspension- 25% 3M Tint all around Grimmspeed Hood Struts Racecomp Engineering Tarmac Zero Coilovers Whiteline Crossmember Mount Insert Bushings Whilteline Rear Camber Adjust Kit Cusco Power Brace Cusco Strut Tower Brace Cusco Battery Tie Down Perrin Rear Sway Bar - 16mm Perrin Poly Endlinks Perrin Master Cylinder Brace Perrin Transmission Support Perrin Steering Rack Lockdown Perrin Rear Shifter Bushing (former) Grimmspeed Strut Tower Brace -Wheels & Tires- ARP Extended Studs --Street Setup-- Enkei RPO3 17x8 48mm Offset Silver Dunlop ZII 245/40/17 Tires Muteki Blue Lugs --Track Setup-- Enkei RPF1 17x9 45mm Offset Gold Dunlop ZII Star Specs 255/40/17 Muteki Black Lugs -Brakes- Carbotech XP10 Front, XP8 Rear race pads Stoptech Steel Brake Lines Motul RBF 600 Race Brake Fluid -Audio- Pioneer AVH-X8500BHS JL Audio XD500/3 Amp JL Audio C5-653 3 way components JL Audio 10W3v3 Subwoofer Integrity Concepts Subwoofer Enclosure -Misc- Raceseng Shift Knob Raceseng Front Tow Hook w/ GoPro Mount Raceseng Rear Tow Hook Toms' Clear JDM Tail Lights GTR Lighting 3rd Brake light F1 Style Flasher LED Turn signals
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 Last edited by Gopherboy6956; 06-13-2016 at 12:36 PM. |
#244 |
Drives: GBS BRZ
#245 |
The current one? Shiv @ OFT
Previous one was the stock Perrin tune that came with my kit (good, but way rich) One that killed my 1st motor was Full blown Motorsports (ironic) in Minneapolis.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#246 | |
Drives: GBS BRZ
Thanks. I'm about to get the same pulley and have shiv etune it. Have you had it on a dyno by chance? |
#247 | |
On the stock Perrin Ecutek, i was at like 242whp, with the FBM tune i was at 276whp/199tq We did just recently get a Dyno here in Fargo, so after i get this tune sorted out (still in progress, and going to add E85 soon) then i'll hit the dyno again.
#248 |
Drives: 2013 FRS- Hot Lava
I'm on this kit (OFT300), open flash header, open flash tablet, tuned by Shiv. We're at 4 revisions and should be done soon. Total of about 2000 miles on the kit but I also split my time between 3 FR-S's so none of them get many miles. Overall very happy.
I have not had this car dynoed but relative to my evo, I would estimate 240~250whp range on a dynojet. Not a "fast" car in any sense of the word but it makes for an entertaining drive to work. |
#249 | |
Looking forward to seeing how it works on E as well.
#250 |
Anyone having issues with their Serp. Belt walking 1 notch off the pulleys?
When i went to replace my squeaky belt (seems to be annually) it was 1 spline off (towards rear of car) so i put the new one on, got it all situated and checked it over the next few weeks - was good to go. This last weekend i was racing, and was just checking around the SC (it get's spitty out the vent when on the road course) and i noticed the belt had walked back 1 notch again. I figure there must be some slight alignment issue, but i dont know what on earth a guy can adjust to make this stop happening. Any ideas? This only happens on the crank pulley and the water pump pulley. (Photo shows new belt installed correctly for reference)
#251 |
Thupercharged
Which Gates racing belt are you running?
2013 FRS
#252 |
Gates K060975RB
| STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 04:16 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 02:05 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:50 AM |
| Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 02:58 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
