go_a_way1, MisterSheep
Old 12-29-2015, 10:17 PM   #12685
D_Thissen
D_Thissen's Avatar
Just imported this! [IMG][/IMG]
Old 12-29-2015, 11:03 PM   #12686
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Originally Posted by fatalelement View Post
Long time no post, but took my car to Streets of Willow on Wayno's e85 tune. It was, of course, amazing. However, in terms of event hosts, compared to Speed Ventures, ExtremeSpeed is real bad. No organization, very little info on the website, and they basically refused to flag anyone for any reason.
In the advanced group, several cars spun multiple times per session causing near accidents, and no flags were thrown. Several of the same cars had 3-4 offs per session, no flags were thrown. No one talked to these people at all. Wildly unprofessional and dangerous to me. People also ignored point-by in front of the crews in the point-by groups, and no one cared or flagged them despite speeches that suggested they were very harsh about this during the morning meeting.
I do not recommend ExtremeSpeed.
Sent from my Nexus 6P using Tapatalk
Isn't it run by the same fat clown who ran that disaster known as Subiefest?
Old 12-30-2015, 01:12 AM   #12687
s14sleepyeyez
Drives: 2013 Argento Scion FR-S
WHAT DID YOU DO TO YOUR FRS TODAY?
Did this the other day but late to post.
Prime Coils (New revised front coils are coming)
Work Meisters S1R's
s14sleepyeyez is offline   Reply With Quote
The Following User Says Thank You to s14sleepyeyez For This Useful Post:
lukey86 (12-30-2015)
Old 12-30-2015, 02:04 AM   #12688
Iceman
Iceman's Avatar
Drives: GT86
Installed some carbon thingy:
Youtube channel: https://www.youtube.com/c/ÓscarFaraday
IG: @oscarfaraday
Iceman is offline   Reply With Quote
The Following 4 Users Say Thank You to Iceman For This Useful Post:
Choco (01-02-2016), Josue Cafe FR-S (01-06-2016), MisterSheep (12-30-2015), MJones_RB (12-30-2015)
Old 12-30-2015, 03:06 AM   #12689
Vision86
Drives: 2015 86
The weather finally cleared up and it was a sunny day so took a drive down some windy backroads. Don't think I'll ever get tired of having the windows down, some music playing and some curvy roads.
Vision86 is offline   Reply With Quote
Old 12-30-2015, 05:18 AM   #12690
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
If so, that would explain a ton hahaha
fatalelement is offline   Reply With Quote
The Following User Says Thank You to fatalelement For This Useful Post:
KR-S (12-30-2015)
Old 12-30-2015, 01:24 PM   #12691
Magoo
Magoo's Avatar
Drives: 2013 Scion FRS
Hit some debris on the freeway. No idea what I hit.
[IMG]damage by Terry McGrew, on Flickr[/IMG]
Magoo is offline   Reply With Quote
Old 12-30-2015, 10:36 PM   #12692
twag4
Drives: frs
Installed whiteline roll center correction kit, caster/bump steer correction bushings, front control arm bushings rear position, and every single bushing in the rear suspension along with SPC control arms. I didn't change the rear lower control arm bushings located on the axle support/hub/knuckle as Toyota put a cross axis bushing in that location already. The SPC bushings have cross axis bushings installed at the inner position too. Win!!! I was surprised, a polyurethane bushing would be a downgrade in that location so I left it. For those that don't know, a cross axis bush is like a heim joint but it has seals and is greased. It lasts much longer than a heim because of the grease.
twag4 is offline   Reply With Quote
Old 12-30-2015, 11:16 PM   #12693
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
And?! DRIVING IMPRESSIONS PLEASE!
Originally Posted by humfrz
I'm old and lazy
Old 12-30-2015, 11:29 PM   #12694
jayhoang
jayhoang's Avatar
Drives: 2014 Scion FRS
Installed the Craft Square mirrors tonight... Here are a few pics.
http://www.lifewithjson.com
Instagram: jayhoang
jayhoang is offline   Reply With Quote
The Following 3 Users Say Thank You to jayhoang For This Useful Post:
02.ACCORD.DUDE (12-30-2015), Lorico (01-01-2016), Reign (01-01-2016)
Old 12-30-2015, 11:48 PM   #12695
twag4
Drives: frs
I have to get it aligned in the morning. Then, I will let you know!
Old 12-31-2015, 02:32 PM   #12696
twag4
Drives: frs
Well it is raining here, I mean really raining. I am not able to go out and really push the car, but wow! The steering is much more responsive. I had previously installed Perrin steering rack lockdowns, but this is way more noticeable than the lock downs. Both front control arm bushings in both arms have been replaced. The forward ones are the Whiteline anti dive/caster correction bushings(KCA434), and they seem to work well. They also increase caster, which in turn has increased the weight required on the steering wheel at turn in. When I previously installed larger wheels and tires, the turn in became lighter. I really wasn't pleased with that at the time. The caster correction seems to have solved that. I also added the roll center correction kit. I cannot accurately quantify which of the two mods helped the front the most, but I can tell you that the sum of the two mods is noticeable improvement. The new bushings in the back really have calmed the rear end down. I can really feel each shock doing its job now. I never felt like my car was bouncy before, but I can really feel that it has way less bounce now. At installation with the rear shock disconnected, the individual arms really articulate smoothly now. With the old stock rubber bushings, they were loaded and lacked range of motion. There was rubber band effect due to the rubber bushings. The polyurethane bushings do not do that. While feeling very connected due to the obscene use of less compliant polyurethane in the rear suspension, it really rides better. The shocks get to do their jobs. There is an intersection in my town that has wicked tire grooves in the cross traffic pavement from heavy truck traffic. My car would kind of stutter and jutter over them when I caught the green light and went through the intersection at 45mph. Today I had a green light and the car stayed firmly connected to the road, and was very compliant. Every aspect of driving is much more instantaneous in regard to suspension. The steering is immediate and responsive, with amazing feedback. The ride is much more planted without harshness. The car doesn't wander at highway speeds now like it used to. It never did it badly- just a little, but now it doesn't do it at all. I am highly satisfied with the results.
I do have two issues with the car now though. I wanted -1.5 camber in the front and -1.25 in the rear. Because of the anti dive/caster correction bushings in the front, I could only get -1.3 camber in the front with the SPC camber bolts. I plan on going with Tein mono flex coil overs as one of my last two suspension upgrades, so the camber plates they come with will solve that. In the rear, the camber can only be adjusted down to -1.4 because there isn't enough adjustment in the elliptical toe arms. If they took it to -1.25 camber, the toe had no adjustment left and became excessive in regard to my wishes. Adjustable toe arms will solve that. I know many of you think that -1.25 is too little negative camber out back, but my car is first and foremost a daily driver. It is supercharged, and high performance 245/40 17 tires don't last that long as is. At -2 degrees in the rear and -1.5 in front like I was running, I am getting considerable long term tire wear on the inside of the tread. I would like to slow that down a bit as $650+ for tires is expensive to me. If I can make them last a bit longer without compromising handling too much- I can live with that compromise. All in all, I am really happy with the upgrades.
Forgot to mention that I am lowered on Eibach pro springs.
The Following User Says Thank You to twag4 For This Useful Post:
Clipdat (12-31-2015)
Old 01-01-2016, 12:16 AM   #12697
dv_tm
Drives: 2015 Scion FR-S
New Matte Black Emblems
Decided to take the Injen Intake off yesterday and drive with the stock for a week or two. Still debating on getting a Perrin right now. Also a pic of the Invidia Catless exhaust I installed like 2 days after I bought the car
dv_tm is offline   Reply With Quote
Old 01-01-2016, 03:51 AM   #12698
KR-S
Sporadic Member
KR-S's Avatar
As soon as it came in, I put a Broadway Type-A mirror in my FR-S.
Here's a crappy night shot:
